    Windows 11 Upgrade Guide
HP Designjet 500ps printers - Mac OS: Printing to the HP Designjet 500ps from Mac OS X
Issue:
Printing to the HP Designjet 500PS printer from Mac OS X.
Solution
  1. If you do not require PostScript language capability, download the hp inkjet driver v2.6.1 for HP Designjet 500, 500PS, and HP Designjet 800. The hp inkjet driver may downloaded from http://designjet.hp.com.
  2. If you require PostScript language capability, obtain the EFI Designer Edition RIP XL.
If you wish to use the original HP Designjet 500PS PostScript RIP with Mac OS X, results may vary, depending on the version of Mac OS X.
RIP OS
Application OS
Print?
Notes
Mac OS 9.x
Mac OS 9.x or 10.x
Yes
Recommended configuration. For best results, ensure that RIP's AppleTalk name is less than 29 characters. Otherwise, OS X clients may not be able to specify printer features in print dialog box.
Mac OS 10.1.5 classic
Mac OS 10.1.5
Yes
RIP not seen in Print Center of host Mac, nor in Print Center of client Macs. Must create localhost connection, print to file, then drop file in RIP. See document number c00018156.
Mac OS 10.1.5 classic or Mac OS 9.x
Yes
Unable to set up to RIP in Chooser. This applies to both the host Mac and client Macs.
OS X clients must create localhost connection, print to file, then drop file in RIP. See document number c00018156.
OS 9 clients must create a PostScript Translator using Apple's Desktop Printer Utility print to file, then drop file in RIP.
Mac OS 10.2.5 - 10.2.8 classic
NO
RIP software displays "cannot launch CPSI" when it tries to process any spool file, including RIP test print.
NO
Mac OS 10.3.0 - 10.3.4 classic
Yes
Must launch RIP before adding printer to printer setup utility. RIP broadcasts over AppleTalk.
Spool files move from print monitor to RIP.
Yes
Able to select RIP in chooser. Printing is as if RIP and application environments were both OS 9.x
Mac OS 10.3.5 - 10.3.9 classic
Yes
Spool files move from OS X print monitor to RIP. However, spool file does not disappear from OS X print monitor.
Mac OS 10.4.0 - 10.4.1 classic
Yes
RIP not seen in Print Center of host Mac,but is seen in Print Center of client Macs. On host Mac, must create localhost connection, print to file, then drop file in RIP. See document number c00018156.
Yes
The HP Postscript RIP for this printer was designed before Macintosh OS X was released. This RIP has not been ported to Mac OS X, although the RIP will run in Classic under some versions of Mac OS X. A Mac OS X Non-Postscript driver is available for download. A PostScript RIP is also available from Electronics for Imaging (EFI).
