HP xw25p Workstation - Specifications
Blade Workstation Specifications
Component
Specification
Processors
(2) AMD Model 252 Opteron processors 2.6GHz
Cache Memory
1MB Level 2 write back per processor
Memory
  • 2048MB (standard) to 4GB (maximum) of 2-way interleaved PC3200 DDR SDRAM running at 400MHz (4x512MB)
  • 4096MB (standard) 2-way interleaved capable PC3200 DDR SDRAM running at 400MHz (4x1GB)
Network Adapter
Two Gigabit NICs (embedded on system board) with WOL and PXE. One additional 10/100 NIC dedicated to iLO Management
Storage Controller
Smart Array 6i Controller
PCI-E Adapter (Mezzanine)
nVIDIA IO4-based Hyper Transport (HT) to PCI-Express mezzanine card that provides a PCI-E x16 connection for the nVIDIA fx540 MXM II graphics card
Graphics Controller
(Mezzanine))
nVIDIA fx540 MXM II graphics mezzanine card with 128MB memory and support for 4 displays
This graphics card provides the high performance graphics support for up to four client monitors. This controller is in addition to the embedded ATI Rage controller on the system board.
Hard Drives
  • 72GB Ultra320 Wide SCSI 10K RPM, single drive
  • 146GB Ultra320 SCSI 10K RPM, single drive
Internal Storage
Up to 600GB maximum (with optional SCSI hard drives).
Optical Drive
None
I/O cable
Included (for diagnostics and local connection)
Form Factor
Plugs vertically into a ProLiant BL p-Class Server Blade 6U Enclosure.
Blade Workstation Client Specifications
Component
Specification
Processors
Intel Celeron D 332 2.8GHz
Cache Memory
1MB Level 2 write back per processor.
Memory
512MB non-ECC PC4200 DDR SDRAM .
Network Adapter
Broadcom NetXtreme BCM5752 Gigabit Ethernet controller (on board).
Graphics
  • nVIDIA Quadro4 280NVS 64MB PCI, VGA, and
  • nVIDIA Quadro4 280NVS 64MB PCI-E, VGA
The client does not use the embedded Intel Graphics Media Accelerator 900. The embedded controller is disabled as soon as a PCI/PCI-E controller is installed.
Hard Drives
none
Diskette Drives
none
Internal Storage
512MB IDE Disk on Module (DOM)
Optical Drive
None
Form Factor
Small form factor (SFF), horizontal or vertical
