HP Designjet Printers - Printing/Plotting from ArchiCad
Printing or Plotting from ArchiCad
When printing from ArchiCad (9), there are two options to send the file to the printer. One option is to "Print" the job, and the other is to "Plot" the job.
Printing the file will use the Windows default driver (should be driver for .
Plotting the file will use a driver that is included with the program, rather than the HP driver, and it will always output in the HP-GL or HP-GL/2 language.
Any Designjet printers that do NOT support HP-GL/2, will not be able to use the "Plot" option from the ArchiCad application (i.e. Designjet 500 without an HP-GL/2 card).
