Evo Notebook N800w - Installing a PC Card
Removing a PC Card
  1. Windows XP Use the Safely Remove Hardware icon in the taskbar to notify Windows that you are removing the card. Windows will then notify you that the card can be removed.
  2. Windows 2000 Professional Select the Unplug or Eject icon in the taskbar, then stop the card you plan to remove. A message displays when the card can be safely removed.
  3. Press the PC Card eject button.
  4. Remove the PC Card.
Inserting a PC Card
  1. With the connector facing the notebook and the label facing up, push the PC card into the PC card slot, aligning the card on the two guide rails within the slot.
  2. Gently push the card into the slot until the card is seated.
Country: Flag Thailand
