Evo Notebook N620c Series - Specifications
  US
Metric
Dimensions (HxWxD)
14.1-inch TFT panel display
1.2 x 12.1 x 9.8 in
3.1 x 30.7 x 25.0 cm
14.1-inch LCD, 1 SODIMM
4.5 lb (with weight saver)
5.2 lb (with MultiBay drive)
2.04 kg minimum
2.36 kb typical
Stand-Alone Power Requirements
Nominal Operating Voltage (Li-Ion)
14.4 V (8-cell)
Average Operating Power
14.4 W
Peak Operating Power
55W
Power in suspend mode
< 400 mW
Power in hibernation mode
< 60 mW
Power Supply
Rated Input Voltage
90 to 264 VAC (auto-switching)
Rated Input Current
1.6A
Rated Frequency
47 to 63 Hz
Temperature
Operating
50°F to 95°F
10° to 35°C
Non-operating
14° to 140°F
–10° to 60°C
Relative Humidity
Operating
10% to 90% relative humidity, non-condensing
Non-operating
5% to 95% relative humidity, 101.6°F
38.7°C Maximum wetbulb temperature
Shock
Operating
10 G, 11 ms, half-sine
Non-operating
60 G, 11 ms, half-sine
Vibration
Operating
0.5 G zero-to-peak, 10 to 500 Hz, 0.25 oct/min sweep rate
Non-operating
1.0 G, zero-to-peak, 10 to 500 Hz, 0.5 oct/min sweep rate
Maximum Altitude (unpressurized)
Operating
0 to 10,000 ft
0 to 3048 m
Non-operating
0 to 30,000 ft
0 to 9144 m
Heat Output
Operating (max)
65 W
Industry Standards & Certifications
EnergyStar Compliant
Yes
ACPI
2.0 (sections applicable to notebooks)
DirectX
8.1
DMI/SMBIOS
Ver. 2.3.1
Microsoft WHQL Certification
Yes (for preinstalled OSs)
PCxx
PC 2001
PXE
PXE 2.1
ISO Certifications
Yes
WBEM
Supported (required for WFM)
WFM
2.0
RPL
2.73
OnNow
Yes
PCI
2.1
Plug & Play
Yes (support may vary by OS)
Audio
Battery
CardBus
Communications
Diskette Drive
Fast Infrared (FIR)
Hard Drive
I/O Subsystems
MultiPort
Optical Drives
PCMCIA
Power
Processor
System Board
USB
