Evo Notebook N600c - Installing the Keyboard
Removing the Keyboard
  1. Prepare the computer for disassembly.
  2. Turn the computer bottom side up with the front facing you.
  3. Remove the black M2 x 7 screw that secures the keyboard to the base enclosure.
  4. Turn the computer top side up with the front facing you.
  5. Open the computer.
  6. Slide the four tabs on the top of the keyboard forward 1 .
  7. Lift the top edge of the keyboard and swing it up and forward until it rests on the top cover 2 .
  8. Disengage the keyboard cable from the retaining clips in the top cover.
  9. Release the ZIF connector to which the pointing device cable is attached 1 and disconnect the pointing device cable 2 .
  10. Release the ZIF connector to which the keyboard cable is attached 3 and disconnect the keyboard cable 4 .
  11. Remove the keyboard.
Reverse the above procedure to replace the keyboard.
