Evo N180 - Installing Memory
Installing Memory
Removing the Memory Expansion Board
  1. Prepare the computer for disassembly.
  2. Turn the computer bottom side up with the front facing forward.
  3. Remove the two PM2.0 x 5.5 screws 1 that secure the expansion cover to the base enclosure (Figure 5-7).
  4. Loosen the two Phillips screws 2 that secure the expansion cover to the base enclosure.
    These two screws are secured to the expansion cover by C clips and should not be removed from the expansion cover.
  5. Lift the left side of the expansion cover and swing it to the right 3 .
  6. Remove the expansion cover 4 .
    The expansion cover is included in the Plastics Kit (spare part number 253944-001).
  7. Spread the retaining tabs 1 on each side of the memory expansion board (Figure 5-8). The board releases and rests at an angle.
  8. Remove the board by pulling it away from the socket at an angle 2 .
Installing the Memory Expansion Board
Reverse the above procedure to install a memory expansion board.
