HP PSC 1400 Series All-in-One - Product Overview
Product overview
Use the images and tables below to identify the components of the HP PSC 1400 series All-in-One.
Product overview
Number
Component
1
Control panel
2
Paper tray
3
Paper tray extender
4
Paper-width guide
5
Print-carriage access/front clean-out door
6
Glass
7
Lid
8
Rear clean-out door
9
Rear USB port
10
Power connection
Front panel overview
Figure : HP PSC 1400 series front panel
Number
Component
1
On/Resume button
Turns the power on or off. In certain situations, such as after clearing a paper jam, pressing this button resumes printing.
2
Check Paper light
Indicates the need to load paper or remove a paper jam.
3
Check Print Cartridge light
Indicates the need to reinsert the print cartridge, replace the print cartridge, or close the print-carriage access door.
4
Cancel button
Stops a job, exit a menu, or exit settings.
5
Copies button
Specifies the desired number of copies.
6
Size button
Keeps the image size as it is (100%) or reduce or enlarge it to fit the size of the paper.
7
Paper Type button
Changes the paper type setting to match the type of paper loaded in the paper tray (plain or photo paper). The default setting is plain paper.
8
Start Copy Black button
Starts a black copy job.
9
Start Copy Color button
Starts a color copy job.
10
Scan button
Starts a scan job.
