    We are upgrading our website
    Fix Windows 10 Update Issues
HP Officejet 5600 All-in-One and the HP PSC 1400 All-in-One Printer Series - Fixing Ink Smears or Streaks
This document is for the HP Officejet 5605, 5607, 5608, 5609, 5610, 5610v, 5610xi, 5615, 5679, 5680 All-in-One printers, and the HP PSC 1401, 1402, 1403, 1406, 1408, 1410, 1410v, 1410xi, 1415, 1417 All-in-One printers.
Problem
The printer is working, but the printed output shows smears or streaks of ink.
Figure : Printout showing ink smears
Step 1: Check your paper
Make sure you printed on fresh, unwrinkled paper. If you are sure you did, go to the next step.
Step 2: Run the clean print cartridges utility
  1. Open the Printer Toolbox. There are two ways to do this:
    • Open HP Solution Center, select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox.
    • If the HP Solution Center method does not work, open Printers and Faxes in the Windows Control Panel, then right-click your printer icon and choose Properties. Click Printing Preferences. Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges, then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
Step 3: Clean the area around the cartridge nozzles
Follow the procedure below to clean the area around the cartridge's nozzles ONLY if you have streaks or smudges in your printed output and you have already performed all three cleaning levels in the Clean Print Cartridges utility.
Do not leave the print cartridges outside the printer for longer than 30 minutes. If a cartridge is left outside of the printer for too long, the ink will dry out and the cartridge will become unusable. Also, be careful not to get any ink on your hands or clothes.
  1. Gather cleaning supplies:
    • Clean distilled, filtered, or bottled water. Tap water may contain contaminants which could damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or paper towel to rest the cartridges on during cleaning.
  2. Remove one of the cartridges and place it on a piece of paper with the nozzle plate facing up.
  3. Examine the area around the nozzle plate. If you see any debris or ink buildup, clean the cartridge as follows:
    If you do not see debris or ink buildup on the print cartridge, do not clean it.
    1. Lightly moisten the lint-free cleaning material with clean water.
    2. Use the swab to wipe clean the faces and edges around the nozzle plate. The area to be cleaned is cross-hatched in the picture below. Replace the cleaning material if it gets dirty.
      Do not touch either the nozzle place (in the center of the cross-hatched area below), or the copper-colored contacts. Touching these parts can cause clogs, ink failure, and bad electrical connections.
        Figure : Cleaning the cartridge
      1. Clean in the cross-hatched area only
      2. Do NOT touch the nozzle plate
      3. Do NOT touch the copper-colored contacts
  4. Repeat the steps above for the other cartridge. Make sure to examine both cartridges, even if the streaks are only one color (streaks in black ink are commonly caused by fibers and debris stuck to the bottom of the tri-color print cartridge). Only clean the cartridge if you see debris or buildup, however. If you do clean the other cartridge, use fresh cleaning material.
  5. Either let the cartridge sit for five minutes or use a new swab to dry the cleaned areas before you reinsert the cartridges.
Step 4: Replace the problem cartridge
If a cartridge replacement was not tried previously to solve this problem, replace the problem cartridge now. Go to Ink Cartridge and Printhead Limited Warrantyto see if the cartridge is covered under warranty.
How to prevent missing lines or streaks
Missing lines and streaks occur when the cartridge nozzles dry out, or when a cartridge is running low on ink.
  • Do not remove the protective tape from a new print cartridge until just before you install it. Once you remove the tape, do not reapply it.
  • After you have removed the protective tape, do not allow anything to touch the nozzles.
  • Print at least once a month to keep the print cartridges in good working order.
  • Always turn the printer off by pressing the button on the printer control panel, rather than by unplugging the printer. Turning the printer off properly allows it to protect the cartridges.
  • If you are removing a cartridge from the printer temporarily (for instance, removing the black cartridge in order to install the photo cartridge), put it in a cartridge protector.
  • If you do not have a cartridge protector and need to remove a cartridge temporarily, put it in an airtight plastic tub. Make sure nothing touches the nozzles. Do not use a plastic bag. If you intend to store print cartridges in a tub for a long period of time, place color cartridges with the nozzles down, and black cartridges with the nozzles up.
