    Fix Windows 10 Update Issues
    Are you working from home?
HP PCs - How to Clean Your Computer
This document pertains to all HP PCs.
Learn how to clean your computer to remove dirt and debris and use a CDC-recommended disinfectant on high-touch surfaces like the mouse, keyboard, and touchscreen.
The Centers for Disease Control and Prevention (CDC) recommends cleaning surfaces, followed by disinfection, as a best practice for the prevention of viral respiratory illnesses in households and community settings.
There may be some visible changes to cosmetic finishes of your product over time as a result of the cleaning techniques mentioned in this document.
  warning:
Before cleaning the computer, perform these steps to reduce the risk of electrical shock:
  1. Turn off the computer.
  2. Disconnect the power cord from the computer.
Regular cleaning and maintenance
Clean the vents, ports, screen, and keyboard of your computer.
Home PC cleaning and disinfecting
Use the cleaning guidance and best practices in this section to clean your home laptop, desktop, or All-in-One computer.
Business PC cleaning and disinfecting
Use the cleaning guidance and best practices in this section to clean your business notebook, workstation, desktop, retail point of sale machine, thin client, displays and accessories.
Frequently asked questions about cleaning your HP product
Find answers to frequently asked questions (FAQs) about cleaning HP products safely and effectively.
