HP Flat Panel Monitor L1755 Product Specifications
Product description
The HP L1755 Flat Panel Monitor is the highest performing HP 17-inch flat panel monitor, offering leading-edge technology and excellent display features for workstation and business PC users and high-end performance applications such as financial trading, graphic arts, digital content creation, and CAD.
Product features
Feature
specification
Panel type
Active matrix TFT (thin film transistor); anti-glare/anti-static coatings
Cabinet colors
Carbonite
43.2 cm (17 in)
Dimensions (h x w x d)
Panel only without stand
  • 30.1 x 40.9 x 7.3 cm (11.8 x 14.4 x 2.9 in)
Unpacked with stand
  • With stand raised: 42.2 x 36.5 x 21.1 cm (21.2 x 14.4 x 8.3 in)
  • With stand lowered: 40.9 x 36.5 x 21.1 cm (16.1 x 14.4 x 8.3 in)
Base area (footprint)
  • 21.1 x 30.9 cm (8.3 x 12.2 in)
Packed
  • 9.2 kg (20.2 lb)
Unpacked with stand
  • 6.7 kg (14.7 lb)
Panel only (without stand)
  • 3.7 kg (8.1 lb)
Bezel width
13 mm left and right, 14 mm top, and 15 mm bottom
Resolution supported
Native resolution
  • 1280 x1024 @ 60 Hz (analog)
  • 1280 x1024 @ 60 Hz (digital)
Maximum resolution
  • 1280 x1024 @ 75 Hz (analog)
  • 1280 x1024 @ 75 Hz (digital)
All VESA modes
  • Up to 1280 x1024 @ 60 Hz, 75 Hz
Video input
Plug and play
Yes - supports VESA DDC2B; PC2001 compliant
Input signals - two connectors
  • One 15-pin mini D-sub analog VGA
  • One DVI-I (VGA analog or digital)
Viewing angles (typical)
Up to 176o horizontal/176o vertical (10:1 minimum contrast ratio)
Brightness
Up to 250 nits (cd/m2)
Contrast ratio
Up to 1000:1 (typical)
Response rate
25 ms (rise + fall)
Pixel pitch
0.264 mm
Frequency range
Horizontal frequency
  • 30 to 82 kHz
Vertical frequency
  • 56 to 75 Hz
Color depth support
16.7 million colors
User programmable modes
Plug and play
Yes
On-screen control
Size and positioning, contrast, brightness, clock, clock phase, selectable color temperature, serial number, mode displayed, sleep timer, input selection, factory reset, individual color contrast, full-screen resolution
Video cable
VGA to VGA, DVI-D to DVI-D, and DVI-I to VGA
Ergonomics
Tilt range
  • -5o to +35o
Swivel range
  • + and - 50o horizontal swivel
USB 2.0 hub
Self-powered; one upstream, four downstream ports (cable included)
Power consumption
Maximum
  • < 60 W
Typical
  • < 40 W
Power saving mode
  • < 2 W
Off mode
  • 0 W (when master power switch is in the off position)
Power cable length
1.8 m (70 in); non-captive
Temperature
Operating
  • 5o to 35o C (41o to 95o F) (non-condensing)
Non-operating
  • -20o to 60o F (-4o to 140o C)
Humidity
Operating
  • 20% to 80%
Non-operating
  • 5% to 90%
Options
HP Desktop Access Center
Features integrated microphone/headset jacks, dual function headset for phone/PC support, a MultiBay slot for adding an optical drive (sold separately), and four USB ports for easy integration of third-party digital solutions. Sold separately.
HP Compaq 7000 Series Ultra-slim Desktop Integrated Work Center Stand
Allows mounting of a 15-, 17- or 19-inch HP flat panel monitor and an HP Compaq dc7100 Ultra-slim Desktop PC on a single stand for the convenience of an "all-in-one" form factor. Sold separately.
HP Flat Panel Speaker Bar
Powered directly by the monitor, seamlessly attaches to the monitor's bezel to bring full multimedia support to select HP flat panel monitors. Features dual speakers with full sound range and external jack for headphones. Sold separately.
Accessories
VGA to VGA cable, DVI-D to DVI-D cable, DVI-I to VGA cable, USB cable, user CD-ROM with Pivot Pro software
Compatibility
VESA Video Signal Standard (VSIS) Compliant video cards have been tested and proven compatible for use with the HP L1940 Flat Panel Monitor. Recommended for use with HP products.
Kensington lock-ready
Yes
VESA external mounting
Yes (standard 4 hole pattern, 100 mm); base must first be removed
Approvals and certifications
Australian ACA Approval, Canadian Requirements/CSA, CE Marking, China CCIB/CCEE Approval, CISPR Requirements, Eastern European Approvals, Energy Star Compliant, FCC Approval, German Ergonomic (TUV and GS Mark), ISO 13406-2 Compliant (Pixel Defect Guidelines), Mexican NOM Approval, MPR-II Compliant, PC2001 Compliant, PC99 Certified, S. Korean MIC Approval, Taiwan BSMI Approval, TCO 99 or 03 depending on region (emissions, ergonomics, environment), TUV-Ergo, UL Listed, VCCI Approvals, Microsoft Windows Certification
Compatibility
VESA Video Signal Standard (VSIS) Compliant video cards have been tested and proven compatible for use with the HP L1755 Flat Panel Monitor. Recommended for use with HP products.
Panel specifications
Panel
Panel type
43.2 cm (17 in) maximum viewable maximum viewable
Screen opening (W x H)
33.9 x 27.2cm (13.4 x 10.7 in)
Viewing angle (typical)
176 degrees horizontal/176 degrees vertical (10:1 minimum contrast ratio)
Brightness (typical)
Contrast ratio (typical)
Response rate (typical)
25 ms (typical, rise + fall)
Pixel pitch
0.264 mm
Color depth support
16.7 million colors
On-screen display (OSD) controls
OSD controls
Buttons or switches
  • Power on/off
  • 3-button OSD
  • second level OSD buttons include dual-input switch, dedicated auto adjust switch
Languages
English, French, German, Spanish, Italian
User controls
  • Size and positioning
  • Brightness
  • Contrast
  • Clock and clock phase
  • Selectable color temperature
  • Serial number display
  • Mode display
  • Sleeper timer
  • Input selection
  • Factory reset
  • Individual color contrast
  • Full screen resolution
Signal interface/performance specifications
30 to 82 kHz
Vertical frequency
56 to 75 Hz
Native resolution
Analog
  • 1280 x 1024 @ 75 Hz
Digital
  • 1280 x 1024 @ 60 Hz
Maximum resolution
Analog
Digital
Preset VESA graphic (non-interlaced)
640 x 480 @ 60 Hz, 72 Hz, 75 Hz
720 x 400 @ 70 Hz
800 x 600 @ 60 Hz, 72 Hz, 75 Hz
1024 x 768 @ 60 Hz, 70 Hz, 75 Hz
1280 x 1024 @ 60 Hz, 75 Hz
Preset MAC mode
832 x 624 @ 75 Hz
1152 x 870 @75 Hz
Preset VGA mode
SUN mode
1152 x 900 @ 76 Hz
Fail safe mode
Yes (limits out of range signal messages)
Maximum pixel clock speed
140 MHz
Yes, 15
Anti-glare
Yes
Anti-static
Yes
Asset control
Yes (accessible on HP Compaq Business Desktops featuring Intelligent Manageability)
Default color temperature
Yes (6500k, 9300k, SRGB, Custom User)
Video input specifications
Video input
Plug and play
Yes (supports VESA DDC2B; PC2001 compliant)
Self-powered USB 2.0 hub
One upstream, four downstream ports (cable included)
Input signal
Two connectors
  • One 15-pin mini D-sub VGA
  • One DVI-I (VGA analog and digital input)
Input impedance
75 ohms + and - 10%
Sync input
Separate sync (HSYNC/VSYNC); composite sync, sync on Green (activated through on-screen display)
Video cable
  • VGA to VGA
  • DVI-I to VGA
  • DVI-D to DVI-D
Video cable length
2.0 m (78 in)
Factory preset display modes
Preset
Pixel Format
Horizontal Freq (KHz)
Horizontal Polarity
Vertical Freq (Hz)
Vertical Polarity
Pixel Clock (MHz)
Source
1
640 x 480
31.469
59.940
25.175
VGA
2
640 x 480
37.861
72.809
31.500
VESA
3
640 x 480
37.500
75.000
31.500
VESA
4
720 x 400
31.469
70.087
28.322
VGA
5
800 x 600
31.469
60.317
40.000
VESA
6
800 x 600
48.077
72.188
50.000
VESA
7
800 x 600
46.875
75.000
49.500
VESA
8
832 x 624
49.726
+ and -
74.551
+ and -
57.284
MAC
9
1024 x 768
48.363
60.004
65.000
VESA
10
1024 x 768
56.476
70.069
75.000
VESA
11
1024 x 768
60.023
75.029
78.750
VESA
12
1152 x 870
68.68
75.06
10.000
Mac
13
1152 x 900
71.71
76.05
105.561
Sun
14
1280 x 1024
63.98
60.02
108.000
VESA
1280 x 1024
79.97
75.02
135.000
VESA
Electrical specifications
Power
Internal power supply
Auto-ranging, 90 to 265 VAC
Input power
100 to 240 VAC
Nominal current
1.5 A maximum
Frequency
50 to 60 Hz
Average
33 W when displaying standard office software
Typical power consumption
< 40 W
Maximum
< 60 W
Power saving
< 2 W
Off mode
Power cable length
Physical specifications
Dimensions (H x W x D)
Unpacked with stand
Packed
  • 9.2 kg (20.2 lb)
Unpacked with stand
  • 6.7 kg (14.7 lb)
  • 3.7 kg (8.1 lb)
Tilt range
-5 to + 35 degrees
Swivel range
+ and - 50 degrees horizontal swivel
Height adjustable
Yes (13 cm/5.1 in adjustment range)
Pivot rotation
Yes, 90 degrees
Base
Ships detached and is removable after installation
Software overview
Pivot Pro software
Pivot Pro software from Portrait Displays, Inc. interacts with the PC's native graphics driver to enable seamless portrait screen redraws with a simple mouse-click or keyboard command. Pivot Pro supports 90-degree portrait and landscape views. Language support is available in English, Japanese, French, German, Spanish, Italian, and Traditional and Simplified Chinese.
Environmental specifications
Temperature
Operating
  • 5 to 35 degrees C (41 to 95 degrees F)
Non-operating
  • -20 to 60 degrees C (-4 to 140 degrees F)
Humidity
Operating
  • 20 to 80% non-condensing
Non-operating
  • 5 to 95%
Altitude
Operating
  • 0 to 4,000 m (0 to 13,000 ft)
Non-operating
  • 0 to 12,192 m (0 to 40,000 ft)
