HP Scanjet 7650 Document Flatbed Scanner Series - Install the Scanner Software in Windows
This document explains how to install the scanner software on a computer using a Windows operating system.
Install the software
Follow the instructions below to install the scanner software.
  1. Close all open programs.
  2. Insert CD 1 for Windows in the CD-ROM drive of the computer. The software installation program should display.
    CD 2 (Windows only) contains additional optional software. To determine which software to install, see the onscreen installation instructions.
  3. If the installation program does not start automatically, perform the following steps:
    1. Click Start, then Run. The Run window opens.
    2. In the Open: field, type D:setup.exe(where D is the letter of the CD-ROM drive).
  4. In the main software installation screen, click Install Software.
  5. Select from the following options for the type of scanning you will be doing:
    • Documents, photographs, and graphics
      • Software for documents and photo management and enhancement
      • Can scan slides and negatives
      • Enables front panel scanner buttons
      • Includes TWAIN connectivity to the most popular imaging software programs
      • Requires 265 - 370 megabytes (MB) of disk space
    • Document image scanning with ISIS compatible document management applications (customized business documentation)
      • Use with ISIS- or TWAIN-compatible document management applications
      • Scanner is accessed through document management software on CD 2, or other TWAIN-compliant or ISIS-enabled applications
      • Offers TWAIN contrast and brightness capabilities
      • Offers improved two-sided scanning performance
      • Does not offer front panel scanner button functionality
      • Cannot scan slides and negatives
      • Requires 142 - 243 megabytes (MB) of disk space
  6. After making a selection, click Next.
  7. On the next screen you can select additional software to be installed, if desired, then click Next.
  8. The software installation begins. Installation may take several minutes.
  9. An Install Wizard window opens. Click Next.
  10. Read the License Agreement and then select I accept the terms of the agreement.
  11. Click Next.
  12. In the Select your desired scanning mode screen, select from the following options:
    • Enable Instant Lamp Warm-up (faster scan mode)
    • Use energy saving mode
  13. After selecting the desired option, click Next.
  14. Select Add shortcuts to the Desktop, if desired, then click Next.
  15. A screen opens displaying the location on the computer where the software files will be placed. Click Next to continue with installation.
  16. A prompt will open asking to check for installation updates. Click Yes to download updates from the HP Web site (recommended) or click No to continue with the installation.
  17. If you clicked Yes on the previous screen, the installer will check for updates.
  18. Click Next to complete the sign up form, or click Cancel to continue installation.
  19. If you clicked Cancel on the Sign up screen, a reminder dialog box will open.
  20. Select from the following options:
    • Select Tomorrow to be reminded to sign up the next day or the next time the computer is turned on.
    • Select In a week to be reminded to sign up in a week.
    • Select Don't remind me again to not have the reminder dialogue box open again.
  21. Click OK.
  22. The scanner software installation is complete.
