- ${title}
- ${title}
- ${title}
- ${title}
HP Designjet EFI Designer Edition RIP - Color Management Deactivated Error
Issue:
The error message "color management deactivated" occurs when printing.
note:The error messages displayed in the program window are preceded by the word "input," "color," "print," or "port" to indicate at which stage of processing the problem occurred.
Solution
Activate color management to process the job.
Cause
This error may occur, for example, if you are trying to print a separated file containing a spot color that is defined in the L*A*B* color space. For printing, L*A*B* data must be converted to CMYK. This is only possible if color management is activated.
Summary
It is not possible to process the current job without color management.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
