Compaq Tablet PC tc1100 - Specifications
System and component specifications
Processor
  • Intel Pentium M 733* (Ultra Low Voltage 1.1-GHz processor, 2-MB cache and 400-MHz Front Side Bus)
  • Intel Pentium M 713* (Ultra Low Voltage 1.1-GHz processor , 1-MB cache, 400-MHz Front Side Bus)
  • Intel Pentium M Ultra Low Voltage 1.0-GHz processor with 1-MB cache and 400-MHz Front Side Bus
  • Intel Celeron M 353* (Ultra Low Voltage 900-MHz speed, 512-KB cache, 400-MHz front side bus)
Not available in all regions.
*Intel's numbering is not a measurement of higher performance.
Intel 855PM chipset
Memory
Slot 1 (Factory and HP authorized service provider configurable only):
  • 256-MB 266-MHz DDR Standard with Celeron SKUs (may also use 333 MHz)
  • 256-MB 333-MHz DDR
  • 512-MB 333-MHz DDR Standard with Pentium SKUs
  • 1-GB 333-MHz DDR
Slot 2 (available):
  • 1-GB 333-MHz DDR
External AC Adapter
Weight:
  • 0.62 lb (0.28 kg)
Power Supply (Input):
  • Operating Voltage: 90 to 260 VAC R
  • Operating Current: 1.7 A RMS
  • Operating Frequency Range: 47 to 63 Hz AC
Internal Lithium-Ion Battery Pack
Weight:
  • 0.65 lb (0.30 kg)
Cells:
  • 6-cell Lithium-Ion
Energy:
  • Voltage: 11.1 V
  • Amp-hour capacity: 3.6 Ah
  • Watt-hour capacity: 40 Wh
Battery Re-Charge Time:
  • System in OFF mode or Standby: 3 hours
  • System ON (depending of system power consumption): 3 to 5 hours
Tablet PC Pen(s)
Pen with tether (standard):
  • Dimensions (Length): 5.1 in (130.1 mm)
  • Weight: 0.66 oz (18.7 g)
Pen with eraser (optional):
Internal MDC 56K high speed Modem
Data Mode Capabilities:
  • High speed 56K modem (a-law, mu-law)
  • V.8bis
  • V.80
  • V.44, V42.bis, MNP5 (Compression)
  • V.42 (LAPM, MNP2-4) (Error Correction)
  • V.34 (file date: 10/96)
Fax Mode Capabilities:
  • TIA-578-S (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
Command Set:
  • V.250 (Partial)
  • TIA-602
  • Identification: GMI, GMM, GMR
  • Port control: IPR, ICF, IFC, Iirr
  • Modulation: MS, MR, MA
  • Error control: ES, ER, EB, ESR, ETBM
  • Data compression: DS, DR
  • V.251
Power Consumption:
  • Transfer mode: < 200 mA, maximum
  • Standby mode: 5 mA, nominal
Integrated 10/100 NIC
Ethernet Features:
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • Auto-Negotiation (Automatic Speed and Duplex Selection)
  • HP Auto-MDIX
  • Full Duplex and Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
Power Management:
  • ACPI 1.1 compliant - multiple power modes Situation-sensitive features reduce power consumption
Manageability:
  • PXE 2.0 Remote Boot
  • Statistics Gathering (RMON, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
NIC Device Driver Name:
  • Broadcom 440x 10/100 Integrated Controller
Drivers Available:
  • Microsoft Windows XP, Windows 2000 DOS NDIS2 and ODI
Bluetooth by HP
Form Factor:
  • Integrated USB module
Bluetooth:
  • 1.1 Compliant
Plug and Play:
  • USB 1.1 compliant
  • Microsoft Windows Plug and Play compliant
Data Rates and throughput:
  • 1 Mbps
  • Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
  • Asynchronous Connection Less links 723.2 kbps/57.6 kbps asymmetric or 433.9 kbps symmetric
Security:
  • Full support of Bluetooth Security Provisions
Protocols Supported:
  • TCP/IP
  • IPX/SPX
  • UDP
Physical specifications
Dimensions (H x W x D)
10.8 x 8.5 x 0.8 in (27.4 x 21.6 x 2.0 cm)
3.1 lb (1.4 kg) Tablet PC only
4 lb (1.8 kg) Tablet PC with keyboard
Electrical specifications
Nominal Operating Voltage
14.8 VDC
Peak Operating Power
40 W
Environmental specifications
Temperature
Operating: 50° to 95° F (10° to 35° C)
Non-operating: -4° to 140° F (-20° to 60° C)
Relative Humidity
Operating: 10% to 90% relative humidity, non-condensing
Non-operating: 5% to 90% relative humidity, 101.6° F (38.7° C) maximum wet bulb temperature
Maximum Altitude (unpressurized)
Operating: 0 to 10,000 ft (3,048 m), (14.7 to 10.1 psia)
Non-operating: 0 to 30,000 ft (9,144 m), (14.7 to 4.4 psia)
Safety certifications
Certifications
All necessary regulatory approvals for countries we support including
FCC (47 CFR) Part 15C, Section 15.247 & 15.249
ETS 300 328, ETS 300 8
Low Voltage Directive IEC950
UL, CSA, and CE Mark
