HP Personal Media Drives - Using the HP Personal Media Drive (Windows ME and XP)
This document applies to the HP Personal Media Drive when connected to a HP or Compaq computer using Windows ME, or XP.
HP Personal Media Drive is an external large capacity hard disk drive designed to store and transfer media files such as digital photos, music, video, and other files.
The HP Personal Media Drive connects and disconnects from a USB 2.0 connector on the front or back of most computers. On some computers, the HP Personal Media Drive fits inside a specifically designed horizontal or vertical drive bay.
Do not set the drive on its side, as it may fall over and cause damage to the drive. Do not set any liquids or drinks on the drive, as spilled liquids can damage the internal electronics. Do not block the airflow around the drive while it is turned on. Do not stack anything on top of the drive, as this can damage or overheat the drive.
Remove the drive from the drive bay before working with recovery, hard drive partitioning, or hard drive formatting software or all data on the Personal Media Drive may be lost.
Inserting the drive into HP computers with a specially designed drive bay
The HP Personal Media Drive is designed fit into certain specially designed drive bays that include an internal USB port and power cable. The HP Personal Media Drive can be inserted and removed from the hard drive bay without turning off the computer (also called warm swappable).
To insert the HP Personal Media Drive into a specially designed HP computer:
  1. Line up the ridges on the bottom of the drive with the two slots on the correct side of the computer drive bay.
  2. Slide the drive all the way into the drive bay until the drive is firmly connected to the internal power and USB cables. Do not force the drive into the bay; it should slide easily into the bay.
    When the computer is turned on, and the drive is inserted correctly, the power LED on the front of the drive is lit.
Connecting the drive to a computer without a drive bay
The HP Personal Media Drive can also be connected as an external hard disk drive using a USB 2.0 cable.
To connect the drive:
  1. Install the software and drivers from the HP Personal Media Drive installation CD.
  2. Plug the round power cable from the power adapter into the back of the HP Personal Media Drive (3).
    Figure : Cable connections between a computer, the drive, and a power source
  3. Plug power adapter into the power cable (4), and then plug the power cable into the wall (5).
  4. Turn on the computer.
  5. Plug the rectangular end of the USB 2.0 cable (1) into an available USB port on your computer. Plug the square end of the USB 2.0 cable (2) into the USB connector on the back of the drive.
    Do not move the computer with the HP Personal Media Drive attached to a USB port. Incorrect handling, such as dropping the drive, can cause data loss and invalidates the warranty.
    The computer may take several seconds to recognize the HP Personal Media Drive.
Finding the HP Personal Media Drive under My Computer
When the drive is connected to a USB 2.0 connector, Windows automatically assigns a hard disk drive letter to it. The assigned letter depends on other storage devices connected to your computer.
To find the HP Personal Media Drive on your computer, do the following:
  1. Click Start, and then click My Computer.
  2. Look for the drive labeled HP Personal Media Drive.
    The default volume label of this drive is HP Personal Media Drive. You can rename the drive from the My Computer window by right-clicking the drive, selecting Rename, and then typing in a new name. HP recommends renaming the drive if you have more than one HP Personal Media Drive.
Installing Drivers and Software
To install HP Personal Media Drive drivers and software:
Only install the applications that are compatible with your language and your computer operating system.
  1. Click Start , click My Computer, and then double-click the HP Personal Media Drive icon.
  2. Open the PMD folder.
  3. Double-click Setup.exe or HPDI.exe.
  4. Select the items you want to install by placing a check in the check box next to the software.
  5. Click Install, and then follow the onscreen instructions to install the software programs. The programs are installed automatically.
  6. After installing the software, restart the computer.
    If available, read the NEWUPDATE file for any updates and changes to the software programs.
Disconnecting the drive safely
To avoid hardware damage and data loss, always disconnect your HP Personal Media Drive safely when it is not saving or transferring data. Do not remove any cables or power cords without first properly disconnecting the drive.
  1. Double-click the Safely Remove Hardware icon in the system tray at the bottom of the desktop. The Safely Remove Hardware window opens. For some computers, this may be called the Unplug Hardware or Eject Hardware icon.
  2. Double-click USB Mass Storage Device. This name may appear differently for some computers.
    USB Mass Storage Device may be listed twice. One may be a memory card reader or other mass storage drives. Look for the HP Personal Media Drive label.
  3. Select your device, and then click OK. A Safe to Remove Hardware message appears in the System tray at the bottom of the desktop letting you know that the device is safe to disconnect.
  4. Click Stop to make sure the HP Personal Media Drive is not active, and then click Close.
  5. Disconnect the drive from the computer.
    If the Safely Remove Hardware function does not allow you to disconnect the drive safely, close all open software programs and documents, and try again.
Troubleshooting the HP Personal Media Drive
Make sure you have the latest Windows service packs and other Windows updates installed on your computer before trying to troubleshoot a drive problem. Service packs are issued to fix bugs, add drivers, and enhance the security features of your system. For more information about how to obtain Updates for Windows refer to the HP support document "Updating Drivers and Software with Windows Update".
Drive can not be found in Windows
Use the following steps to make the drive appear in Windows. Open My Computer and check to see if the drive is listed after completing each step.
  1. Make sure the power adapter is securely plugged into the drive and into a power outlet. If the drive is plugged into a power strip, try plugging it directly into the wall outlet.
  2. Check to see if the drive is on. The power LED on the front of the drive and the light on the power adapter should be lit.
  3. Ensure the USB cable is securely and properly connected to the drive and the USB connector on the computer.
    Use the cable supplied with the drive. Other cables may not work properly.
  4. While the computer is turned on, unplug the USB cable. Wait 10 seconds and then reconnect the USB cable.
  5. Use Device Manager to see if the USB port is available:
    1. Click Start, and then right-click My Computer.
    2. Click Properties and then click the Hardware tab.
    3. Click the Device Manager button.
    4. Click the plus (+) next to Disc drives.
    5. If present, double-click the item for the HP Personal Media Drive.
    6. Check the status of the device by looking in the Device status area on the General tab.
  6. If these steps fail to make the drive appear in My Computer, the USB port is bad or configured incorrectly or the drive is bad.
    Refer to the HP support document USB Device Troubleshooting for further help on troubleshooting USB.
Messages appear about a high-speed device connected to a low-speed port
This is normal. Windows XP displays this message if you have connected the HP Personal Media Device (a USB 2.0 drive) to a USB 1.1 port. The HP Personal Media Device can still be used in this situation, but it will not have the high-speed capabilities that it would have when connected to a USB 2.0 port.
Deleting and Creating Partitions
Partitions are allocated hard drive spaces that can appear as drive letters to Windows. A hard drive needs to have at least one partition before you can store files on the hard drive. Do the following to add or delete a partition on the HP Personal Media Drive:
Deleting Partitions on a hard disk drive destroys all data on the drive. If you have data you want to keep, back up the data before deleting the partition.
  1. Click Start.
    Right-click My Computer and select Manage. The Computer Management window displays.
  2. Click Disk Management (located in the left pane, under Storage).
    The available disks display in the lower right pane.
  3. Right-click HP Personal Media Drive and select Delete Partition. A confirmation window displays.
    Click Yes. The partition on the disk is deleted, and Disk Management shows the disk space as Unallocated.
  4. Right-click the disk and select New Partition. The New Partition Wizard displays. Click Next on all the screens to accept the default options and Finish.
    The wizard creates the new partition and formats it. The formatting process may take 30 minutes or more. During formatting the disk status displays as Formatting. When the disk status displays Healthy formatting is done.
Formatting the HP Personal Media Drive
Formatting a partition on a drive prepares the space for file writing. Do the following steps to format the HP Personal Media Drive:
Formatting a hard disk drive destroys all data on the drive. If you have data you want to keep, back up the data before formatting the drive.
  1. Click Start.
  3. Right-click HP Personal Media Drive and select Format. The Format window displays. Click OK to accept the defaults.
    A confirm window displays. Click OK. The format begins.
    The formatting process may take 30 minutes or more. During formatting, the disk status displays as Formatting. When the disk status displays Healthy formatting is done.
Country: Flag Thailand
