HP Designjet cc800ps, 815mfp, and 4200 Scanner - Accessing Shared Files
The following sections detail how to access the shared files folder on the HP Designjet scanner system from remote computers for a variety of operating systems.
Remote computer with Windows 98
  1. Go to the computer desktop and double-click My Computer.
    Figure : My computer icon
  2. Double-click the Web Folders icon.
    Figure : Web Folders icon
  3. Double-click Add Web Folder icon.
    Figure : Add Web Folder icon
  4. When asked for the location of the folder to be added, type the URL of the HP Designjet scanner shared folder, for example http://scanner_ip/images (where scanner_ip is the IP address of the HP Designjet scanner). To find the IP address of the scanner, skip to the How to find the IP address of the scanner section at the bottom of this document. After you have finished typing the location information, press Next.
    Figure : Add Web folder
  5. Enter a name for the folder.
    Figure : Web folder name
  6. Click the Finish button, you will see all the files in the D:/images directory of the HP Designjet scanner system.
    Figure : Images folder
  7. To view the folder, go back to your desktop, click My Computer and then click on Web Folders. Your HP Designjet scanner system folder has been added. For easy access, you may drag the Web folder to your desktop.
  8. Now you can drag any file or folder from your local computer into the HP Designjet scanner Web folder. HP suggests that you create your files and folders on your computer rather than in the Web folder.
    To delete your Web folder, select it and, while pressing the Shift key, press the Delete key on your keyboard.
Remote computer with Windows 2000
  1. Double-click the icon My Network Places on the desktop.
    Figure : My Network Places icon
  2. The Network Places window opens. Double-click Add Network Place icon.
    Figure : Add network place icon
  3. Enter http://scanner_ip/images, where scanner_ip is the IP address of the HP Designjet scanner. To find the IP address of the scanner, skip to the How to find the IP address of the scanner section at the bottom of this document.
    Figure : Add Network Place wizard
  4. Enter a descriptive name for the link to the HP Designjet scanner system shared folder.
    Figure : Adding network place name
  5. Click Finish to complete the setup.
Remote computer with Windows XP
    Figure : Add Network Place icon
  3. Select Choose another network location and click Next.
    Figure : Network location selection
  4. Enter http://scanner_ip/images (where scanner_ip is the IP address of the HP Designjet scanner). To find the IP address of the scanner, skip to the How to find the IP address of the scanner section at the bottom of this document.
    Figure : Entering address
  5. Enter a descriptive name for the link to the HP Designjet scanner system shared folder.
    Figure : Entering name for link
  6. Click Next to complete the setup.
Remote computer with MacOS X
  1. Select the Connect to server option in the Go menu and type the directory that you want to connect to.
    Figure : Connect to server option
  2. The images folder should now be accessible.
Remote computer with MacOS 8 and 9
In MacOS 8 and MacOS 9 there is no native client to access a Web folder directly, therefore you will need to download a WebDAV (Web-based Distributed Authoring and Versioning) client to access the shared folder. You can, for example, download the "goliath" client from http://www.webdav.org/goliath/ and install it.
Sample screenshots, taken during installation of Goliath, are provided below.
Figure : Goliath Install screen
Figure : Goliath Description screen
Figure : Goliath installer
Figure : Goliath 1.0 screen
Type the HP Designjet scanner's IP address and the directory that you want to connect to.
Figure : New WebDAV Connection window
Finding the IP address of the scanner
You can find the IP address of your HP Designjet scanner by doing the following:
  1. Exit the HP Designjet scan software.
  2. Select Start, Programs, Accessories, then Command Prompt.
  3. Write ipconfig and press Enter, you will get a result similar to the following:
    C:\>ipconfig
    Windows 2000 IP Configuration
    Ethernet adapter Local Area Connection:
    • IP Address. . .. . : 15.180.37.217
    • Subnet Mask . . . .: 255.255.248.0
    • Default Gateway . .: 15.180.32.1
