    We are upgrading our website
HP Compaq Business Desktop dx2000 Microtower - Product Specifications
System specifications
Attribute
Specification
Processors
Intel Pentium 4 Processor with Hyper-Threading Technology:
2.80A GHz with 533 MHz system bus 1 MB L2 Advanced Transfer Cache
2.80E GHz with 800 MHz system bus 1 MB L2 Advanced Transfer Cache
3.0E GHz with 800 MHz system bus 1 MB L2 Advanced Transfer Cache
Intel Celeron with MMX Technology:
2.60 GHz with 400 MHz system bus 256 KB L2 Advanced Transfer Cache
2.80 GHz with 400 MHz system bus 256 KB L2 Advanced Transfer Cache
System Memory - Single Channel Configurations
128 MB DDR SDRAM PC2700 (333-MHz) non-ECC
128 MB DDR SDRAM PC3200 (400-MHz) non-ECC
System Memory - Dual Channel Configurations
256 MB (2 x 128) DDR SDRAM PC2700 (333-MHz) non-ECC
512 MB (2 x 256) DDR SDRAM PC2700 (333-MHz) non-ECC
1 GB (2 x 512) DDR SDRAM PC2700 (333-Mhz) non-ECC
256 MB (2 x 128) DDR SDRAM PC3200 (400-MHz) non-ECC
512 MB (2 x 256) DDR SDRAM PC3200 (400-MHz) non-ECC
1 GB (2 x 512) DDR SDRAM PC3200 (333-Mhz) non-ECC
Physical specifications
Attribute
Specification
Height
35.5 cm (14.0 inches)
Width
18.0 cm (7.1 inches)
Depth
39.0 cm (15.4 inches)
System Net Weight (not including packaging)
10.5kg
System Gross Weight (including packaging)
14kg
Electrical specifications
Attribute
Specification
Power Supply
250 watt ATX Power Supply – PFC / non-PCF with a 115v/230v line switch (varies by country/region)
Rated Line Frequency
50-60 Hz
Operating Voltage Range
90 to 132VAC, or 180 to 264VAC
Rated Voltage Range
100 to 127 VAC, or 200 to 240VAC
Operating Line Frequency Range
47-63 Hz
Maximum Rated Power
250W
Power Supply Fan
80-mm power supply fan - variable speed for optimum acoustics
Power Conservation Energy Saver
  • Energy Star compliant APM 1.2 support
  • Screen blanking
  • Hard drive Idle mode
  • System Idle mode
  • Blue Angel compliant (<5w in S5 - power off)
  • ~2 watt power consumption in ES mode - suspend to RAM (S3) (instantly available PC)
  • Processor/Cache memory power-down (S3)
Environmental specifications
Attribute
Specification
Ambient Air Temperature
Operating: 10 to 35 degrees C at sea level with an altitude de-rating of 1.0 degrees C per every 300 m (1000 feet) above sea level to a maximum of 3000 m (10,000 feet), no direct sustained sunlight. Maximum rate of change is 10 degrees C/Hr. The upper limit may be limited by the type and number of options installed.
Storage: -30 to 60 degrees C (Maximum rate of change: 20 degrees C/Hr).
Humidity
Operating: 10 to 90% relative humidity (Rh), 30 degrees C maximum wet bulb temperature, non-condensing.
Storage: 5 to 95% relative humidity (Rh), 38.7 degrees C maximum wet bulb temperature, non-condensing.
Altitude
Operating: 0 to 10,000 feet - This value may be limited by the type and number of options installed. Maximum allowable altitude change rate is 1500 ft/min.
Non-Operating: 0 to 30,000 feet (Maximum allowable altitude change rate is 1500 ft/min).
Shock
Listed are the levels of shock the product can withstand with NO damage being incurred. The values represent peak input acceleration during an 11ms half-sine shock pulse.
Operating: 3 G
Non-Operating: 20 G
Vibration
Listed are the levels of vibration the product can withstand with NO damage being incurred. The values represent a flat random vibration input acceleration profile across the given frequency range.
Operating: Random vibration at 0.000215 G²/Hz, 10 to 300 Hz (0.25 G nominal).
Non-Operating: Random vibration at 0.002041 G²/Hz, 10 to 500 Hz (1 G nominal).
Acoustic Noise
Listed are the declared A-WEIGHTED SOUND POWER LEVELS (LWAd) and declared average desktop seated operator position A-WEIGHTED SOUND PRESSURE LEVELS (LpAm) when the product is operating in a 23 degrees C ambient environment. Noise emissions were measured in accordance with ISO 7779 (ECMA 74) and declared in accordance with ISO 9296 (ECMA 109).
IDLE (Fixed disk drive spinning): LWAd = 4.3 Bels, Desktop Average LpAm = 32 dBA
FIXED DISK (Random write): LWAd = 5.0 Bels, Desktop Average LpAm = 40 dBA
CD-ROM (Sequential reads): LWAd = 5.4 Bels, Deskside Average LpAm = 44 dBA
Audio specifications
Integrated ADI AD1888 Audio
Attribute
Specification
Type
Integrated
AC '97 Stereo Codec
Yes
OPL3 FM Synthesis Support
Yes
Sound Blaster Compatibility
Yes
Audio Jacks
Mic-In (20-K ohm Input Impedance)
Line-In (12-K ohm Input Impedance)
Line-Out (less than 800 ohms Output Impedance, expects at least a 10-K ohm load)
Internal Speaker Amplifier is for Internal Speaker only. External Speakers need to be powered externally.
Headphone-Out (2.5 Ohms Output Impedance, expects at least a 32 ohm load)
Analog Audio
Number of Channels on Line-Out (mono/stereo): Stereo (Left & Right channels)
Internal Audio Speaker Power Rating: 3W
Internal Tuned Port Speaker: Yes
External Speaker Jack: (Line-Out)
Expansion bays and slots specifications
Expansion bays
Bays
Internal
External
Total
Quantity
Two 3.50-inch, half-height
Two 5.25-inch, half-height
One 3.50-inch, half-height
Used
1
1
3
Open
1
2
3
Slots
PCI
Total
Quantity
Three full-height slots on PCA
3
Used
0
0
Open
3
3
Communication specifications
Intel Pro 1000 MT NIC
Attribute
Specification
Connector
RJ-45
Controller
Intel 82540EM Gigabit Controller
Memory
Integrated 96 Kb frame buffer memory
Data rates supported
10/100/1000 Mbps
Bus architecture
PCI 2.2
Data path width
32-bit, 33/66 MHz bus interface
Data transfer mode
Bus-master DMA
Boot ROM support
Yes
Network transfer rate
10BASE-T (half-duplex): 10 Mbps
10BASE-T (full-duplex): 20 Mbps
100BASE-TX (half-duplex): 100 Mbps
100BASE-TX (full-duplex): 200 Mbps
1000BASE-T: 1000 Mbps
Dimensions
6.4 x 4.8 x 0.8 inches (16.3 x 12.1 x 1.9 cm)
Operating system driver support
Microsoft Windows NT 4.0, Microsoft Windows 98, Microsoft 2000, Microsoft XP, Linux 2.2, Linux 2.4
Diskette drive specifications
1.44-MB diskette drive
Attribute
Specification
Dimensions (HxWxD)
17.8 x 101.6 x 139.7 mm (0.7 x 4.0 x 5.5 inches)
0.56 lb (255 g)
Maximum Data Transfer Rate
500-Kbps internal FDD
Operating Position
Horizontal only
Signal Interface
USB Specification version 1.1
Hard drive specifications
5400 rpm SMART III Ultra ATA/100 hard drives
Attribute
Specification
Capacity
40 GB
Dimensions (H x W)
2.5 x 8.9 cm (1.0 x 3.5 inches)
Interface
Ultra ATA/100
Transfer Rate
100 MB/s
Rotational Speed
5400 rpm
7200 rpm SMART III Ultra ATA/100 hard drives 40 GB
Attribute
Specification
Capacity
40 GB
Dimensions (H x W)
Interface
Ultra ATA/100
Transfer Rate
100 MB/s
Rotational Speed
7200 rpm
7200 rpm SMART III Ultra ATA/100 hard drives 80 GB
Attribute
Specification
Capacity
80 GB
Dimensions (H x W)
1.0 x 3.5 in (2.5 x 8.9 cm)
Interface
Ultra ATA/100
Transfer Rate
100 MB/s
Rotational Speed
7200 rpm
Input/Output devices specifications
2004 Standard Keyboard (PS/2 or USB)
Attribute
Specification
Keys
104, 105, 106, 107, 109 layout (depending upon country)
Dimensions (L x W x H)
45.8 x 16.3 x 2.5 cm (18.0 x 6.4 x 0.98 inches)
System interface
USB Type A plug connector
Cable Length
1.8 m (6 feet)
Operating system support
Windows 2000 and XP
2-Button Scroll Mouse (PS/2 or USB)
Attribute
Specification
Scroll Wheel
8 mm
Maximum Rotation Speed
30 mm/s
Switch Type
Light force micro-switch
Cable Length
2 m
Optical drive specifications
48X Max CD-ROM drive
Attribute
Specification
Interface
ATAPI IDE
Data Transfer Rate Sustained
1200 Kbps minimum (audio) Variable (CD) - 3,000 to 7,200 Kbps
Disk Capacity (CD)
650 MB
Dimensions (H x W x D, maximum)
4.3 x 15.0 x 20.3 cm (1.7 x 5.9 x 8.0 inches)
48X/32X/48X CD-RW drive
Attribute
Specification
Orientation
Either horizontal or vertical
Interface Type
ATAPI IDE
Capacity
185 MB (Mode 2, 8cm); 540 MB (Mode 1, 12 cm); 650 MB (Mode 2, 12 cm); 700 MB (Mode 2, 12 cm)
Dimensions - external (W x H x D)
203 x 149.5 x 43.5 mm (7.99 x 5.88 x 1.71 inches)
Maximum Data Transfer Rates
CD-RW Write: 4800 KB/s (32X) Max
CD-ROM, CD-R read: 7200 KB/s (48X) Max
CD-RW read: 7200 KB/s (32X) Max
CD-R write: 7200 KB/s (48X) Max
16X/40X DVD-ROM with +R Read drive
Attribute
Specification
Interface Type
ATAPI
Dimensions - External, Excluding Bezel (W x H)
149.5 x 43.5 mm (5.88 x 1.71 inches)
Disc Capacity
DVD-ROM: 4.7 GB (DVD-5), 8.54 GB (DVD-9), 9.4 GB (DVD-10), 3.95 GB (DVD-R version 1.0), 4.7 GB (DVD-R version 2.0), 4.7 GB (DVD-RW version 1.0 and 1.1), 4.7 GB (DVD+RW), 4.7G (DVD+R)
CD-ROM: 540 MB (Mode 1, 12 cm), 640 MB (Mode 2, 12 cm), 700 MB (80 minimum CD-R and CD-RW), 180 MB (8 cm)
CD-ROM Read: 6000 KB/s (40X) Max
DVD-ROM Read: 21,600 KB/s (16X) Max
48X/32X/48X/16X Combo CD-RW/DVD-ROM
Attribute
Specification
Orientation
Interface Type
ATAPI
Dimensions (W x H x D)
146.5 x 43.5 x 187 mm (5.77 x 1.71 x 7.36 inches) (external, excluding bezel)
Capacity
Read Only Disc: 180 MB (mode 2, 8 cm); 540 MB (mode 1, 12 cm); 650 MB (mode 2, 12 cm); 700 MB (Mode 2, 12 cm); 4.7 GB (DVD-5); 8.54 GB (DVD-9); 9.4 GB (DVD-10)
Writeable Disc: 180 MB (mode 2, 8 cm); 540 MB (mode 1, 12 cm); 650 MB (mode 2, 12 cm); 700 MB (mode 2, 12 cm)
CD-RW write: 1500 KB/s (10X) Max
CD-ROM, CD-R, CD-RW read: 7200 KB/s (48X) Max
DVD ROM read: 21,632 KB/s (16X ) Max
Video specifications
Integrated Intel Extreme Graphics 2
Attribute
Specification
3D/2D Controller
Support is fully compliant with Microsoft standard API such as Direct Draw, GDI/GDI+ and Direct Show
VGA Controller
Integrated
Memory
Graphics memory is shared with system memory. Graphics memory usage can vary from 8 to 64 MB depending on the amount of system memory installed and system load. 16 MB is pre-allocated for graphics use at system boot time. Additional memory is allocated for graphics using Intel's Dynamic Video Memory Technology (DVMT) to balance the optimum amount of memory between graphics and other system use. With a 128 MB system, graphics memory usage will be 8 MB to 32 MB depending on system load. With 256 MB or more, graphics memory usage will be 8 MB to 64 MB depending on system load.
Graphics API Support
Complete Microsoft DirectX support, including DirectX 8.1; complete OpenGL 1.3 support. Compatible with DirectX 9.
Maximum Vertical Refresh Rate
85 Hz at up to 1920 x 1440, 75 Hz at 2048 x 1536. Varies with mode and configuration.
Country: Flag Thailand
