    We are upgrading our website
HP Compaq Business Notebook nc6000 Series - Inserting or Removing a Primary Battery Pack
To prevent loss of work when removing a battery pack that is the sole power source, initiate Hibernation or turn off the notebook before removing the battery pack.
To insert a battery pack, turn the notebook upside down, then slide the battery pack into the battery bay until it is seated.
Figure : Inserting the battery pack
To remove a battery pack, turn the notebook upside down. Then, slide and hold the battery release latch while pulling the battery pack from the battery bay.
    Figure : Removing the battery pack
  1. Battery release latch
  2. Battery pack
