HP Compaq Business Notebook nc6000 Series - Design Overview
This document presents a design overview of key parts and features of the notebook.
The system board provides the following device connections:
  • Memory expansion board
  • Mini PCI communications device
  • Hard drive
  • Display
  • Keyboard and TouchPad
  • Audio
  • Mobile Intel Pentium 4 Processor-M
  • Fan
  • PC card
The notebook uses an electric fan for ventilation. The fan is controlled by a temperature sensor and is designed to come on automatically when high temperature conditions exist. These conditions can be caused by high external temperatures, heavy system power consumption, certain power management/battery conservation configurations, battery fast charging, and some software applications. Exhaust air is displaced through the ventilation grill located on the notebook rear panel.
Failure to properly ventilate the notebook may result in damage to components. To properly ventilate the notebook, allow at least a 7.6-cm (3-inch) clearance on all sides of the notebook.
