HP Compaq Business Notebook nc 6000 Series - Hardware Specifications and Product Features
Physical specifications
Dimensions
Height
3.40 centimeters (1.34 inches)
Width
31.78 centimeters (12.51 inches)
Depth
26.19 centimeters (10.31 inches)
With 6-cell battery pack and Multi-Bay weight saver
2.25 kilograms (4.96 pounds)
With 6-cell battery pack and Multi-Bay DVD-ROM drive
2.46 kilograms (5.42 pounds)
Performance specifications
Stand-alone power requirements
Nominal operating voltage
14.4 Volts - direct current
Maximum operating power
40 Watts
Peak operating power
50 Watts
Temperature
Operating (not writing optical)
0 to 35 degrees Celsius (32 to 95 degrees Fahrenheit)
Operating (writing optical)
5 to 35 degrees Celsius (41 to 95 degrees Fahrenheit)
Non-operating
-20 to 60 degrees Celsius (-4 to 140 degrees Fahrenheit)
Relative humidity (non-condensing)
Operating
10 to 90 percent
Non-operating
5 to 95 percent, 38.7 degrees Celsius (101.6 degrees Fahrenheit) maximum wet bulb temperature
Altitude (unpressurized)
Operating (14.7 to 10.1 psia)
-15 to 3,048 meters (-50 to 10,000 feet)
Non-operating (14.7 to 4.4 psia)
-15 to 12,192 meters (-50 to 40,000 feet)
Shock
Operating
10 grams, 11 millisecond, half-sine
Non-operating
175 grams, 2 millisecond, half-sine
Applicable product safety standards specify thermal limits for plastic surfaces. The notebook operates well within this range of temperatures.
Notebook features
  • Mobile Intel Pentium 4 1.8-GHz Processor-M, with 2.0-MB L2 cache, varying by notebook model.
  • Mobile Intel Pentium M 1.7-, 1.6-, 1.5-, and 1.4-GHz processors, all with 1.0-MB L2 cache, varying by notebook model.
  • 14.1-inch SXGA+ (1400 × 1050) or XGA (1024 × 768) TFT displays with over 16.7 million colors, varying by notebook model
  • ATI MOBILITY RADEON 9600 graphics controller with 64 or 32 MB of video memory, varying by notebook model
  • 60-, 40-, or 30-GB high-capacity hard drive, varying by notebook model
  • 256-MB DDR synchronous DRAM (SDRAM) at 333 MHz, expandable to 2.0 GB
  • Microsoft Windows 2000 or Windows XP Pro, varying by notebook model
  • Full-size Windows 98 keyboard with integrated numeric keypad
  • Dual pointing devices (TouchPad and pointing stick)
  • Integrated Secure Digital (SD) Memory Card flash media slot
  • Support for Multi-Bay device
  • Integrated 10/100/1000BASE-T Ethernet local area network (LAN) NIC with RJ-45 connector
  • Integrated wireless support for Bluetooth LAN and Mini-PCI 802.11a/b/g LAN devices
  • Support for two Type II or one Type III PC Card slots with support for both 32-bit (CardBus) and 16-bit PC Cards
  • External 65-watt AC adapter with power cord
  • 8- or 6-cell Li-Ion battery pack
  • Stereo speakers
  • Support for the following devices in the Multi-Bay:
    • 24X Max CD-ROM drive
    • 24X Max DVD/CD-RW combo drive
    • 8X Max DVD-ROM drive
    • DVD+RW/R and CD-RW combo drive
    • 8-cell Prismatic battery pack
  • Connectors for:
    • SD Memory Card
    • Infrared
    • One Type III PC Card slot
    • Two Type II PC Card slots
    • RJ-11 (modem)
    • RJ-45 network interface card (NIC)
    • Universal Serial Bus (USB) v. 2.0
    • S-Video
    • Parallel
    • External monitor
    • DC power
    • Docking
    • Microphone
    • Stereo speaker/headphone
