HP iPAQ h2200 Pocket PC - How Do I Determine if the Battery Is Charging?
If the battery is charging, the Power Indicator on the front of your iPAQ Pocket PC will flash amber. If the amber light is not on, try disconnecting the AC Adapter and re-connecting it to make sure the connection is not loose. If your iPAQ Pocket PC is charging in the USB Synchronization Cradle/Charger, you can also try removing your Pocket PC from the cradle and reinserting it.
Another way to check whether the battery is charging is to tap Start, Settings, System tab, Power, Battery tab. If the battery is charging, the Main Battery indicator moves from left to right and Recharging state: will say Charging.
