Compaq iPAQ H3000 Series - Windows Media Player for Pocket PC
Use Windows Media Player for Pocket PC to listen to digital audio files. To switch to Windows Media Player, tap , Programs, then Windows Media Player.
    Figure : Windows Media Player
  1. Active playlist
  2. Track information
  3. Skip back
  4. Shuffle playlist
  5. Stop
  6. Indicates the progress of the current track
  7. Skip forward
  8. Play/Pause
  9. Repeat playlist
  10. Volume
Using Windows Media Manager for Pocket PC
Use Windows Media Manager for Pocket PC on the computer to create digital audio files in Windows Media format and to transfer audio content to your Compaq iPAQ H3000 or storage card. With Windows Media format, you can create high-quality audio for your Compaq iPAQ H3000 without using large amounts of Compaq iPAQ H3000 memory.
You can transfer the following media formats to your Compaq iPAQ H3000 for use with the Windows Media Player: ASF (Advanced Streaming Format), WMA (Windows Media Audio), MP3 (MPEG Audio Layer 3), and WAV (waveform).
Windows Media Manager is included in the Extras folder on the ActiveSync CD. You must install Windows Media Manager on your computer to copy and convert digital audio files.
What is packaged content?
Packaged content is digital music that has been encrypted for distribution to prevent unauthorized access to copyrighted content. Windows Media Player for Pocket PC cannot play packaged content without a valid license. First use Windows Media Player on the computer to obtain packaged content that has a license that allows transferring the content to your Compaq iPAQ H3000. Then, use Windows Media Manager for Pocket PC to transfer the packaged content and its license to your Compaq iPAQ H3000 or storage card. To successfully transfer packaged content, your Compaq iPAQ H3000 or storage card may require a hardware serial number.
You can play packaged content until the license expires. During license download, you will be informed of the terms of the license. License terms can be for an unlimited time, a set amount of time, or a set number of playbacks. A license can support content being copied to a Compaq iPAQ H3000 or storage card an unlimited number of times or one time only. Terms are entirely dependent on the content provider.
Using the Playlist Manager
Use the playlist manager to set the track playback order. All My Music is the default playlist. It contains all digital audio files available for playback on your Compaq iPAQ H3000 and storage card. To see a list of recently selected playlists, tap Select Playlist. To create or edit playlists, tap All Playlists.
