HP Flat Panel Monitor L2035 - Specifications
The table below contains the specifications for the HP Flat Panel Monitor L2035:
Display size
20 inches
51 cm
Display type
TFT LCD
Viewable Image size
20-inch diagonal
51 cm
Tilt
-5 to 25o
Swivel
+35 to - 35o
Face treatment
Anti-glare polarizer with hard coating
Maximum weight (unpacked)
21 pounds
9.5 kg
Dimensions (includes pedestal), Height (maximum)
20.9 inches
531 mm
Dimensions (includes pedestal), Depth
8.3 inches
210 mm
Dimensions (includes pedestal), Width
17.8 inches
453 mm
Maximum Graphics resolution
1600 x 1200 (60 Hz) digital input
or
1600 x 1200 (75 Hz) analog input
Text mode
720 x 400
Dot pitch
0.255 x 0.255 mm
Horizontal frequency
30 to 94 kHz analog input
or
30 to 75 kHz digital input
Vertical Refresh rate
45 to 85 Hz
Power source
100 - 240 VAC, 50/60 Hz
Power consumption
<75 watts
Input terminals
  • 15-pin D-type connector with cable included.
  • DVI-I connector with DVI-D cable included
The table below contains the Environmental Requirements for the HP Flat Panel Monitor L2035:
Operating
Non-operating
Temperature
41 to 95o F
5 to 35o C
-4 to +140o F
-20 to +60o C
Relative Humidity
20 to 80%
5 to 95%
The table below contains the color display values for the HP Flat Panel Monitor L2035:
CIE* Chromaticity coordinates
x (+/- 0.030)
y (+/- 0.030)
Red
0.63
0.34
Blue
0.15
0.110
Green
0.30
0.58
White Chromaticity (6500 K) (9300 K)
0.31
0.34
0.28
0.31
Gamma: 2.2
* Commission International d'Eclairage, 1931 Standard.
