HP Pavilion f1903 Monitor - Product Specifications
This information applies to the HP Pavilion f1903 monitor.
The HP Pavilion f1903 monitor is a liquid crystal display (LCD) 19-inch, high resolution, multi-synchronous color monitor. Multi-synchronous means that the monitor can use a range of video modes. It is optimized for use with HP computers.
Figure : HP Pavilion f1903 flat panel monitor shown with Harman Kardon speakers
The Harman Kardon speaker set is available on select models only. Click here for speaker specifications.
Model number
P9627A
Features
The HP Pavilion f1903 monitor has the following features:
  • Large 19-inch (48.3 mm) viewable area display
  • 1080 x 1024 factory-set resolution, plus full-screen support for lower resolution at a 75 Hz refresh rate
  • Wide viewing angle to allow viewing from a sitting or standing position, or for moving from one side of the monitor to the other side of the monitor.
  • Tilt adjustment capabilities.
  • Removable base for flexible mounting solutions.
  • Multiple video inputs supported:
    • VGA Analog
    • DVI-I supports either Analog or Digital signal input
  • VGA analog and DVI-Digital signal cables included.
  • Plug and Play capability if supported on your system.
  • Onscreen Display (OSD) adjustments for ease of setup and screen optimization. Adjustments are offered in the following languages:
    • English
    • French
    • German
    • Italian
    • Spanish
    • Dutch
  • A CD that includes a User's Guide, an information file (INF), Image Color Matching file (ICM), and an auto-adjustment pattern software.
  • Energy Saver feature for Energy Star compliance.
  • Compliant with the following regulated specifications:
    • EPA ENERGY STAR
    • European Union CE Directives
    • Swedish MPR II 1990
    • Swedish TCO'03
Technical specifications
LCD feature
Specification
Display Size
19-inch (48.3 cm) diagonal and viewable image
Display Type
TFT liquid crystal
Viewable Image Size
19-inch diagonal (48.3 cm)
Tilt
-5 to 20 degrees
Swivel
+35 to -35 degrees
Face Treatment
Anti-glare polarizer with hard coating
Maximum Weight (unpacked)
17.2 lbs. (7.8 kg)
Dimensions (includes pedestal)
Height (minimum):15.8 inches (400.0 mm)
Height (maximum): 20.6 inches (525.0 mm)
Depth: 8.5 inches (215.4 mm)
Width: 16.6 inches (422.5 mm)
Maximum Graphics Resolution
1280 x 1024 (75 Hz) analog and digital modes
Text Mode
720 x 400
Dot Pitch
0.294 x 0.294
Horizontal Frequency (analog mode)
30 to 82 kHz
Vertical Refresh Rate (analog mode)
56 to 76 Hz
Power Source
Input rating: 100-240 VAC maximum
Frequency: 50/60 Hz
Power Consumption
Less than 40 watts typical
Input Terminals
15-pin D-type connector with cable included
DVI-I connector with DVI-D cable included
Temperature Requirements
Operating: 41 to 95 degrees F (5 to 35 degrees C)
Non-Operating: -4 to 140 degrees F (-20 to 6 degrees C)
Relative Humidity
20 to 80 per cent
EMI standard
FCC Class B
EPA Energy Star
As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
Basic warranty
One-year parts and labor, limited warranty.
What ships in the box
Check for the following items. If anything is missing or damaged, consult your retailer immediately.
  • One 19-inch liquid crystal display (LCD)
  • One power cord
  • One video cable (VGA)
  • One DVI-Digital signal cable
  • One quick setup poster
  • One warranty booklet
  • One CD-ROM disc
  • With select models, one set of Harmon Kardon speakers with a DC cable and a DC power adapter.
