    We are upgrading our website
HP Printers - Network Scanner Connection Error (Windows)
This document is for HP multifunction printers connected to a Windows computer on a wired or wireless network.
When you try to scan, the computer or the scanner is not found or the scan fails. One of the following communication or connection errors displays and the scan fails.
  • An error occurred communicating with the scanning device
  • An error occurred while communicating with the HP imaging device
  • Computer not found
  • No Computer Detected
  • Scan to computer is currently unavailable
  • Scan to computer no longer activated
  • Scan Unsuccessful
  • Scanner not found
  • Scanner Unreachable
  • The scanner could not be initialized
Step 1: Confirm if the issue is also printing-related
The steps in this document resolve communication and connection errors when scanning only.
If the connection error occurs when both printing and scanning, use the following resources to resolve the issue:
  • For wired connections, make sure the cable is connected to the printer Ethernet port and to an available port on the router. If the green link is not steady and the orange activity light is not blinking, restart the router, printer, and computer to resolve any network error states.
If you have a connection issue when scanning only, continue to the next step.
Step 2: Restart devices and check driver scan settings
Restarting the computer and printer can restore the lost scan connection.
  1. Turn off the printer.
  2. Make sure the printer power cord connects directly to an electrical outlet and not through a surge protector or power strip.
  3. Close all running programs on your computer, and then shut down the computer.
  4. Turn on the printer.
  5. Turn on the computer.
  6. Search Windows for your printer model name, and then click the printer name in the list of results.
    • If HP Printer Assistant opens, click Scan a Document or Photo or Manage Scan to Computer, and then make sure the check box is selected next to Automatically start Scan to Computer when I log onto Windows.
    • If HP Solution Center opens, click Scan Settings to view scan connection status, settings, and preferences.
    • If your printer name is not in the results, skip to the step to install the HP software for your printer.
  7. Try to scan.
If the error persists, continue to the next step.
Step 3: Check the network and printer connection status
Make sure your network is working correctly and the printer is ready for scanning.
  1. Make sure the printer is connected to the network.
    • Wireless network connection: On the printer, open the Wireless network or Settings menu to make sure the wireless signal is turned on. Make sure the Wireless icon light is on and steady.
    • Wired network connection: Make sure the cable is connected to the printer Ethernet port and to an available port on the router. The green link light should be steady, and the orange activity light should blink.
      Connect the Ethernet cable to the printer and to the router
  2. Many routers can operate in both 2.4 GHz and 5.0 GHz frequency bands, but not all HP printers support both bands. Make sure the 2.4 GHz router band is enabled and broadcasting. If the router broadcasts separate network names (SSIDs) for each band, connect the printer to the 2.4 GHz band SSID. If the printer supports 5.0 GHz, connect it to the 5.0 GHz band SSID.
  3. On the computer, mouse over the network icon in the notification area to view the network name and status of the connection.
    If you are using a Virtual Private Network (VPN), disconnect from it when trying to scan.
    Example of the network icon showing the network name and connection status
    • If the network shown is not yours (for instance, if you connected to a neighbor's or guest network), you must reconnect to your own network to scan.
    • If the network signal strength is weak, move the computer and printer closer to the router, position the devices away from large metal objects such as bookcases, and move away from devices that emit radio signals such as microwaves and cordless phones.
    • If the network status is not connected, confirm that your network is working correctly, and then check the status again. Make sure a check mark displays next to the network name.
    • If an Airplane icon displays, click the icon, slide the Airplane mode slider to Off, and then connect to your wireless network.
      Image: Example of Airplane mode enabled
  4. Try to scan.
HP provides a free tool called HP Print and Scan Doctor to diagnose and resolve printing problems. Download and run HP Print and Scan Doctor  to quickly and automatically perform several troubleshooting tasks known to resolve this issue. When this link is clicked, HP Print and Scan Doctor is downloaded using your Internet browser's download capabilities.
After the Print and Scan Doctor opens, click Fix Scanning to review a list of issues and fixes.
  1. In the Print and Scan Doctor results screen, view the list of actionable results.
    • If you see white checkmarks, the printer passed the tests.
    • If you see a white wrench, Print and Scan Doctor found an issue and repaired it.
    • If you see yellow exclamation points, the test failed and required user action, but the step was skipped.
    • If you see a red X, follow the on-screen instructions to resolve the issue.
  2. Click Test Scan or Skip.
    • If you click Test Scan, the Print and Scan Doctor launches the HP scanning software to perform a test scan. Follow the on-screen instructions in the scanning software to perform the test.
    • If you click Skip and are not experiencing additional issues, click Quit to exit the tool.
    • If you click Skip and are still experiencing scanning issues, click Support and Troubleshooting for support that is tailored to your scanner, or click HP Support Forum for help from other HP customers.
Step 5: Uninstall the printer software
Resolve scan connection issues by uninstalling the printer software before reinstalling the latest driver.
Do not disconnect the printer from the network when uninstalling the software.
  1. Search Windows for uninstall a program, and then click the Uninstall a program Control Panel setting in the list of results.
  2. In the list of installed programs, click your HP printer name, and then click Uninstall or Yes to confirm the uninstall.
  3. Follow the on-screen instructions to complete the software removal.
  4. Restart the computer.
Continue to the next step.
Step 6: Reinstall the HP software
Go to HP Customer Support to download the most current version of the full feature software for your printer.
As an alternative, you can use the software disc if it supports the operating system installed on your computer.
  1. Turn on the printer.
  2. If your printer is connected to the computer with a USB cable, disconnect the cable from the printer. The software installation prompts you to connect the cable if needed.
  3. If a Let's identify your product to get started page displays, click Printer, type your printer model number, and then click Submit.
    The software results page for your printer displays with the default operating system selected.
  4. If you need to change the operating system, click Change, select your version, and then click Change.
  5. Under the Driver heading, click Download.
  6. During the installation, select the Typical or Recommended type of installation when prompted by the software installer.
Step 7: Check Windows Image Acquisition settings
Windows Image Acquisition (WIA) is a service in the Windows operating system that supports communication between the computer and scanners. If WIA is not activated, scan jobs can fail.
  1. Search Windows for view local services, and then click the View local services Control panel setting in the list of results.
    The Services window opens.
  2. Find Windows Image Acquisition (WIA) in the Name column and look at the Status and Startup type values.
    • If the status is 'Started' and the Startup type is 'Automatic', WIA is running correctly. Skip to the next step.
    • If the status is 'Disabled', right-click Windows Image Acquisition (WIA), click Properties, click the General tab, click Start under the Service status, and then select Automatic from the Startup type dropdown menu.
      If you cannot start WIA, make sure the following services are also Started and set as the Automatic startup type.
      • Remote Procedure Call (RPC)
      • Shell Hardware Detection
      • RPC Endpoint Mapper
      • DCOM Server Process Launcher
  3. Try to scan.
Step 8: Temporarily disable firewall software on the computer
Firewall software helps block threats from outside your network, but some settings or configurations can block communication with network printers. Use the Print and Scan Doctor to identify and temporarily disable firewall software on your computer.
  1. Return to the Print and Scan Doctor, click Network, and then click Troubleshoot Firewalls.
    Image: Click Troubleshoot Firewalls in the drop-down menu.
  2. Click the name of any firewall software on your system that has an Enabled status, and then click Disable.
    Example of the Troubleshooting Firewalls window
  3. Try to scan.
    • If you can scan, consult the firewall software support site to change settings such as security level, trusted zones, and open ports to allow communication with your printer. After changing the settings, re-enable the firewall in the Print and Scan Doctor.
    • If you cannot scan, the firewall software is not causing the issue. Re-enable the firewall in the Print and Scan Doctor, and then continue to the next step.
Step 9: Try other scanning options
Use these workarounds to scan if the previous steps did not resolve the issue. Some workarounds might be unavailable depending on the printer. Try one of the other workarounds if the first method you tried did not work.
Review these frequently asked questions about scan issues.
