HP iPAQ Pocket PC h5100 and h5500 - Setting the Date and Time
When the HP iPAQ Pocket PC is turned on for the first time, it requests selection of the time zone. After setting the time zone, set the time and date on the unit. All three settings are located in the Clock Settings screen and can be set at the same time.
By default, the time on the HP iPAQ Pocket PC is synchronized with the personal computer each time the two devices connect using ActiveSync.
Setting the time for Home and Visiting locations
Separate Home and Visiting location clocks can be set so the HP iPAQ Pocket PC's home clock does not have to be altered when traveling.
  1. From the Start menu, tap Settings, the System tab, and the Clock icon, or tap the Clock icon from the Today screen.
  2. Tap either Home or Visiting.
  3. Tap the Time Zone down arrow, then select the appropriate time zone.
  4. Tap the hour, minutes, or seconds, then use the up and down arrows to adjust the time, or adjust the time by moving the hands of the clock with the stylus.
  5. Tap AM or PM.
  6. Tap OK.
  7. Tap Yes to save the time.
Setting the date
  1. From the Start menu, tap Settings, System tab, and the Clock icon, or tap the Clock icon from the Today screen.
  2. Tap the down arrow by the date.
  3. Tap the left or right arrow to select a month and year.
  4. Tap a day.
  5. Tap OK.
  6. Tap Yes to save the date settings.
The time zone, time, and date must be reset under any of the following conditions:
  • The location time (Home or Visiting) needs to be changed.
  • All power to the HP iPAQ Pocket PC is lost, and all saved settings are lost.
  • A full reset of the HP iPAQ Pocket PC is performed.
Country: Flag Thailand
