HP PSC 2400 and 2500 Photosmart All-in-One Series - Front Panel Overview
Use the image and table below to locate and identify the function of the buttons on the HP PSC 2400 and 2500 Photosmart All-in-One series front panel.
Figure : Front panel
Number
Function
1
Up Arrow
Use the four arrow buttons to navigate through the displayed menus.
2
OK
Select menu options, settings, or values.
3
On
Turn the all-in-one on or off.
4
Copy
Select the copy function. Press Copy a second time to show the Copy menu with options for making copies.
5
Left Arrow
Navigate through the displayed menus. The Left Arrow may also be used to lower or reduce some counts and settings values.
6
Fax
Select the fax function. Pressing Fax a second time will show the Fax menu with options for sending faxes.
7
Setup
Access the menu system for reports, settings, and product maintenance.
8
Slideshow
Display all photos on the photo card in a slide show on the color LCD display.
9
E-mail
Upload the displayed photo to the computer as an e-mail attachment. The e-mail is ready to be sent when an e-mail address is entered.
10
Color LCD display
Displays the contents of photo cards, settings information, product function menus, and status messages.
11
Cancel
Stop any task, exit a menu, or exit settings.
12
Scan
Initiate a scan to the computer. A destination for the scan must be selected.
13
Right Arrow
Navigate through the displayed menus. May also be used to increase some counts and settings values.
14
Select the photo card functions. Press Photo a second time to show photo printing options.
Down Arrow
16
Rotate
Rotate the displayed photo 90 degrees clockwise each time it is pressed.
17
Proof Sheet
Press Proof Sheet when a photo memory card is inserted to show the Proof Sheet menu. The Proof Sheet menu allows you to print and scan proof sheets.
18
Numeric Keypad
Enter fax numbers, number of copies, settings values, or text (for fax header information).
19
Black and Color Start buttons
Press Black to start a black and white fax, copy, scan, or photo print.
Press Color to start a color fax, copy, scan, or photo print.
Country: Flag Thailand
