HP iPAQ Pocket PC h5400 Series - Hardware Specifications
System specifications
System feature
HP iPAQ h5400 series
Processor
Intel PXA250 (400 MHz), 32K caches
Memory
64 MB SDRAM or greater
ROM
48 MB or greater
SD Storage
Memory card and SDIO ready
Transflective color TFT, 240 x 320 pixels, 64Kcolor support, .24-dot pitch
LED Backlight
Multi-level brightness adjustment, light sensor for automatic adjustment of brightness level
Audio
Speaker, 3.5 mm stereo headphone and microphone jack
Infrared
IrDA, data transfer up to 115.2 Kb per second and Universal Remote Control for control of home entertainment units
Bluetooth
All models
Fingerprint Reader
Thermal swipe technology
Communications
Communication port, Expansion Pack connector
Indicators
three-mode alarm notification: Flashing green LED, tone, pop-up message; Chargeactive: flashing/solid amber LED; Bluetooth active: flashing/solid blue LED; WLAN active: flashing green LED; WLAN enabled but not connected: flashing amber LED
Battery
1250 mAh Lithium Polymer removable/rechargeable with internal memory backup battery, support SD/MMC type standard
Physical specifications
U.S.
Metric
Length of the unit (without WLAN antenna)
5.23 inches
133.0 mm
Length of the unit (with LAN antenna)
5.43 inches
138.0 mm
Width
3.30–3.03 inches tapering
84.0–77.0 mm tapering
Depth
0.63 inches
15.9 mm
7.26 ounces
206 gm
Operating Environment
Environment
US
Metric
Temperature
Operating
Non-operating
32 to 104 degrees F
-22 to 140 degrees F
0 to 40 degrees C
-30 to 60 degrees C
Relative Humidity
Operating
Non-operating
10 to 90%
10 to 90%
10 to 90%
10 to 90%
Maximum Altitude
Operating
Non-operating
0–15,000 ft
0–15,000 ft
4,572 meters
4,572 meters
Country: Flag Thailand
