HP ProBook 4416s Notebook PC- Overview
Product description
The HP ProBook 4416s Notebook PC boasts a sleek design that packs an array of features normally reserved for more expensive notebooks.
Available in a new Merlot or glossy Noir finish with a morespacious keyboard layout, it delivers refined simplicity with a clean design using the latest AMD processors.
Product features
Feature
AMD RX781 chipset
Processors
  • AMD Turion X2 Ultra Dual-Core Mobile Processor ZM-86 (2.4-GHz, 2 MB L2 cache)
  • AMD Turion X2 Ultra Dual-Core Mobile Processor ZM-84 (2.3 GHz, 2 MB L2 cache)
  • AMD Turion X2 Dual-Core Mobile Processor RM-76 (2.3-GHz, 1 MB L2 cache)
  • AMD Turion X2 Dual-Core Mobile Processor RM-74 (2.2-GHz, 1 MB L2 cache)
  • AMD Turion X2 Dual-Core Mobile Processor RM-72 (2.1-GHz, 1 MB L2 cache)
  • AMD Turion X2 Dual-Core Mobile Processor RM-70 (2.0-GHz, 1 MB L2 cache)
  • AMD Athlon X2 Dual-Core Processor for Notebook PCs QL-66 (2.2-GHz, 1 MB L2 cache)
  • AMD Athlon X2 Dual-Core Processor for Notebook PCs QL-64 (2.1-GHz, 1 MB L2 cache)
  • AMD Sempron Processor for Notebook PCs SI-42 (2.1-GHz, 512-KB L2 cache)
Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
Memory
Standard: 800 MHz DDR2 SDRAM; two slots supporting dual channel memory 1024 MB or 2048 MB.
Maximum: Upgradeable to 8192 MB with 4096 MB SODIMMs in slots 1 and 2.
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Graphics
ATI Mobility Radeon HD 4330 discrete graphics with 512 MB dedicated video memory
  • up to 1024 MB HyperMemory* in units with Windows XP and 2 GB or more of system memory.
  • up to 1280 MB HyperMemory* in units with Windows Vista Business and 2 GB or more of system memory.
Microsoft DirectX 10.1 capable
* Indicates dedicated video memory and shared system memory.
Internal:
  • 14.0 inches diagonal LED-backlit HD anti-glare (1366 x 768 resolution).
  • 14.0 inches diagonal LED-backlit HD BrightView (1366 x 768 resolution).
External: Up to 32 bit per pixel color depth
  • VGA port supports resolutions up to 1600 x 1200 at 75 Hz, and lower resolutions at up to 100 Hz.
  • HDMI 1.3 port supports direct connection to high-definition displays with up to 1920 x 1080 resolution and 7-channel audio with one convenient cable.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Keyboard
The HP spill-resistant keyboard is designed using a Mylar film that minimizes the risk of damage to sensitive components underneath.
The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, and 12 function keys. US and International key layouts are available. Other features include hotkeys for instant access to power conservation and brightness, and 19.05 x 19.05 mm key pitch (center-to-center spacing).
Pointing device
Touchpad with scroll zone, two pick buttons.
Storage
Internal Storage Device : 160/250/320/500 GB 5400 rpm, 160/250 GB 7200 rpm SMART SATA II Hard Drive.
HP 3D DriveGuard : The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Fixed optical drives:
  • Blu-ray ROM DVD+/-RW SuperMulti DL LightScribe Drive
  • DVD+/-RW SuperMulti DL LightScribe Drive
  • DVD-ROM Drive
Expansion card slots
ExpressCard/34 slot Supports ExpressCard/34 (34 mm x 75 mm x 5 mm) card sizes
Media Card Reader Supports SD (Secure Digital), MMC (MultiMedia Card), Memory Stick, Memory Stick Pro, Memory Stick Duo*, xD-Picture card
* Memory Stick Duo Adapters are required and sold separately. Inserting a Memory Stick Duo Card directly into your notebook could damage the memory card and/or notebook.
Power Supply
External 90 W Smart AC adapter
Battery
Primary battery:
  • 6-cell (47 WHr) Li-Ion battery
Power Conservation
  • ATI PowerPlay technology
  • Hibernation
  • Standby
  • ACPI compliance
Software overview
Feature
Operating System
  • Genuine Windows Vista Business 64 bit
  • SuSE Linux
  • Red Flag Linux (PRC only)
  • Genuine Windows Vista Business with downgrade to Windows XP Professional custom installed
Preinstalled software with Windows Vista:
  • HP Recovery Manager
  • HP Help and Support Center
  • HP ProtectTools Security Manager
  • HP QuickLaunch Buttons Software
  • HP QuickLook 2
  • HP Connection Manager
  • HP Wireless Assistant
  • HP 3D DriveGuard, Microsoft Office Ready with 60-day Office Professional 2007 Trial Edition (select models)
  • PDF Complete SE
  • Intervideo WinDVD - DVD Player, Roxio Creator Business (for optional DVD+/-RW and DVD/CDRW drives)
  • McAfee Total Protection*
  • Synaptics Touchpad Driver
  • Microsoft Windows Live Messenger (select models)
  • Webcam Software (with optional 2 MP webcam)
Additional software available from the web: HP SoftPaq Download Manager
* 60 day trial period for McAfee Total Protection for Small Business software. Internet access required to receive updates. First update included. Subscription required for updates thereafter.
Country: Flag Slovakia
