    Apache Log4j Update
    Check documents and videos on compatibility, FAQs, upgrade information and available fixes. Windows 11 Support Center
HP ENVY x360 - 15-dr1003nw Product Specifications
9HN10EA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz base with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass with HP Sure View integrated privacy screen, 650 nits, 72% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 2.0; 1 headphone/microphone combo
35.9 x 24.6 x 1.72 cm
2.05 kg
65 W AC power adapter
4-cell, 55.67 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 15 minutes
Video Playback Battery life
Up to 10 hours and 45 minutes
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Country/Region: Flag Slovenia
