swollen battery
 Sign In  /  Register
Welcome,
Sign Out
My Account
Dashboard
Dashboard FAQ
  • Support Home
  • Products
    • Printer Support
    • Computer Support
    • All
  • Software and Drivers
  • Diagnostics
    • Printer Diagonostic Tools
    • Computer Diagnostic Tools
    • Windows Support
    • Print and Scan Doctor
    • HP PC Hardware Diagnostics
  • Contact Us
  • Business Support
    • Create a new case
    • Find an existing case
    • Manage contracts and warranties
    • Register an account
    • MyHPSupport Help
    • Security Bulletins
    • Login Required
  • My HP Account
    • My HP Dashboard
    • HP Account benefits
Experiencing battery swelling?
If you have noticed that your notebook has a slight bulge or no longer sits flat, this may indicate that your battery may be swollen.
Battery swelling is the result of the generation of gases per the normal degradation of the battery cell over time and does not present a safety issue. In order to protect your hardware from potential damage, HP recommends that customers experiencing battery swelling discontinue use of the notebook until the battery can be replaced.
If your original HP battery is under warranty, HP will replace the battery per the terms and conditions of the HP Worldwide Limited Warranty or applicable HP Care Packs. For batteries no longer under warranty, we can help you purchase a certified HP genuine replacement battery.
Learn more about swollen batteries
Replacing your swollen batteries is quick and easy!
Identify your laptop
Collect Information
Connect with an agent
Collect information
1. Identify your product to start
Let us know which laptop is having this battery problem
Enter your serial number
Example: HU265BM18V
This product cannot be identified by serial number alone.
Please provide a product number as well.
Enter your product number
Example: CN123A
Please enter a valid product number
product product
Serial
Description goes here Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip.
Without signing in, we cannot start a case with an agent or help with your battery.
Learn more about battery swelling and why you should consider replacement > *No-cost support options may be available only on select platforms and for a limited time.
See contact options for this product >
Get product details and troubleshooting help >
If your laptop is currently functioning you can find the serial number by using a simple keyboard command
1. From your built-in keyboard, press and hold the Fn + Esc buttons at the same time.
2. An HP System Information pop-up box will appear on your screen with your serial number.
Additional tips for finding your laptop’s serial number
Locate your product's information label
Watch a video
Collect information
2. We need a bit more information to help our agents get started
*Required fields
A photo of your swollen battery, or deformation of the laptop case, is the quickest way to get confirmation of the issue and is relatively easy by using your smart phone to take the picture and then upload your image.
Do NOT attempt to open your battery compartment or remove the battery from your laptop in order to take a photo. An image of the deformed case is all that is required.
By completing and submitting this form you consent to the use of your data in accordance with HP's Privacy statment. Learn more about HP's privacy policy.
Collect information
3. You are all done! An agent will connect with you shortly
Case started
Thanks for starting your case online, an HP Support representative will contact you shortly by phone or by email.
Please note: Battery swelling is not a safety issue. However, in order to protect your hardware from potential damage, HP recommends that customers experiencing battery swelling discontinue use of the notebook until the battery can be replaced.
Case Number for reference: 12345678999
Your case will be available to view at any time within your dashboard (Please allow 2 hours for processing time after the case is created). Here you can check case status and save cases for future reference. Visit your dashboard
Learn more about all the benefits that come with an HP account!
Connect with HP support faster, manage all of your devices in one place, view warranty information, case status and more.
Learn more about account benefits
Visit your dashboard and learn about your devices
hp logo
Notice
Your session has timed out. Please click on restart button..
Privacy Policy© Copyright 2021 HP Development Company, L.P.
hp logo
Watch a video
hp logo
Find your serial number using a keyboard command
The product information label contains your serial number and product number. You can find it either on the back of your laptop, inside the battery compartment or under the cover on the back of the laptop.
Examples of where to find your product label
first image
Example of a serial number inside a laptop battery compartment
second image
third image
Example of a Label under a cover on the back of the laptop
fourth image
For detachable PCs, the product identification label might be located somewhere on the kickstand.
Previous Next
Sample product label
hp logo
Service unavailable
The service is temporarily unavailable. Please try again later.
Fetching Results
Hp logo
Select registration option
Personal accounts
  • Save your personal devices and preferences
  • Easy access to support resources
Business/IT accounts
  • Managing contracts and warranties for your business
  • Submitting and managing support cases
Privacy Policy © Copyright 2020 HP Development Company, L.P.
Country/Region: Flag
hp-logo
Select a location
Americas
  • América Central
  • Argentina
  • Bolivia
  • Brasil
  • Canada
  • Canada - Français
  • Caribbean
  • Chile
  • Colombia
  • Ecuador
  • México
  • Paraguay
  • Perú
  • Puerto Rico
  • United States
  • Uruguay
  • Venezuela
Europe, Middle East, Africa
  • Africa
  • Afrique
  • Беларусь
  • België
  • Belgique
  • Bulgaria
  • Česká republika
  • Croatia
  • Danmark
  • Deutschland
  • Estonia
  • España
  • France
  • Ελλάδα
  • Ireland
  • ישראל
  • Italia
  • Казахстан
  • Latvia
  • Lithuania
  • Magyarország
  • Middle East
  • العربية
  • Nederland
  • Norge
  • Österreich
  • Polska
  • Portugal
  • Romania
  • Россия
  • Schweiz
  • Suisse
  • Serbia
  • Slovakia
  • Slovenia
  • South Africa
  • Suomi
  • Sverige
  • Türkiye
  • United Kingdom
  • Украина
  • Bosna i Hercegovina
Asia Pacific and Oceania
  • Australia
  • 中国
  • 中國香港
  • Hong Kong SAR
  • Indonesia
  • India
  • 日本
  • 한국
  • Malaysia
  • New Zealand
  • Philippines
  • Singapore
  • 台灣地區
  • Thailand
  • ไทย
  • Vietnam
