    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
HP ZBook 15 Mobile Workstation Product Specifications
Product image
Product features
Feature
Mobile Intel QM87
Processors
  • 4th Generation Intel Core i7-4900MQ (2.8 GHz, 1600MHz, 8MB L3 cache, 4 cores, 47 W) Up to 3.80 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel Core i7-4800MQ (2.7 GHz, 1600MHz, 6MB L3 cache, 4 cores, 47 W) Up to 3.70 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel Core i7-4700MQ (2.4 GHz, 1600MHz, 6MB L3 cache, 4 cores, 47 W) (no vPro support)* Up to 3.40 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel Core i7-4600M (2.90 GHz, 1600 MHz, 4MB L3 Cache, 2 cores, 37 W) Up to 3.60 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel Core i5-4330M (2.80 GHz, 1600 MHz, 3MB L3 Cache, 2 cores, 37 W) Up to 3.50 GHz with Intel Turbo Boost Technology
  • Intel Dual-Core i5-4300M (2.60 GHz, 1600 MHz, 3MB L3 Cache, 4 threads, 37 W) Up to 3.30 GHz with Intel Turbo Boost Technology
Graphics1
Microsoft DirectX 11.1 (Shader Model 5.0) and OpenGL 4.2 capable
  • NVIDIA Quadro K610M with 1GB dedicated GDDR5 video memory
  • NVIDIA Quadro K1100M with 2GB dedicated GDDR5 video memory
  • NVIDIA Quadro K2100M with 2GB dedicated GDDR5 video memory
  • NVIDIA Optimus Technology supported
  • Internal
    15.6-inch diagonal LED-backlit FHD SVA eDP anti-glare (1920 x 1080)
    15.6-inch diagonal LED-backlit FHD UWVA eDP anti-glare + Panel Self Refresh (PSR) (1920 x 1080)
    15.6-inch diagonal RGB LED-backlit FHD DreamColor UWVA eDP anti-glare (1920 x 1080)
  • External
    Up to 32-bit per pixel color depth
  • Thunderbolt
    Supported as part of the daisy chain connected with Intel approved thunderbolt cables. Click here for more information.
    Thunderbolt features:
    • Legacy : DP 1.1a, DVI-A/D, HDMI and VGA displays attached to the end of the thunderbolt daisy chain via Intel certified dongles
    • DP 1.2 redrive: DisplayPort monitors capable of supporting DP 1.2 may be directly attached to the Thunderbolt port to achieve HBR2 and MST functionality.
    • DP display with miniDP connector may be attached directly to TB (Thunderbolt) port.
    • DP display with standard DP connector and other legacy displays (HDMI, DVI, VGA) may be attached to TB with the use of a dongle.
    • DP1.2 MST feature ("daisy-chain" feature) is supported through TB port.
  • DisplayPort w/MST (Multi-stream Transport)
    Supports resolutions up to QFHD 3840 x 2160, 24/30-bit color depth at 60 Hz, and WUXGA (1920 x 1200) monitors, 24/30-bit color depth at 120 Hz.
    DisplayPort feature:
    Multi-stream Transport (MST): Multi-stream Transport is a DP 1.2 feature that allows daisy chaining of DP 1.2 monitors (requires built in support of DP 1.2 MST in monitor), or the use of DP 1.2 hubs with MST to achieve 4 active displays without a docking station.
  • VGA
    Port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
  • DVI-D (single link)
    Video signal available through DVI port in optional HP Docking Station (sold separately), as well as through DisplayPort to DVI-D; DisplayPort to DVI-D (dual link); and DisplayPort to HDMI adapters.
    Supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Storage and drives
  • mSATA storage bay
    128GB mini-card Solid State Drive
  • Primary storage bay
    Hard drives
    • 320/500/750GB 7200 rpm SMART SATA II
    • 1TB 5400 rpm SMART SATA II
    • 500GB 7200 rpm SMART SATA II Self Encrypting Drive
    • 500GB 5400 rpm SMART SATA II Self Encrypting Drive FIPS 140-2 compliant
    Solid State Drive
    • 128/180/512GB SATA 6 Gb/s
    • 256GB SATA 6 Gb/s Self Encrypting Drive
Optical drives
  • Fixed 9.5 mm SATA optical drive
    • Blu-ray R/RE DVD+/-RW SuperMulti DL Drive
    • Blu-ray ROM DVD+/-RW SuperMulti DL Drive
    • DVD+/-RW SuperMulti DL Drive
    • DVD-ROM Drive
  • Second hard drive
    • 750GB 7200 rpm SMART SATA II Hard Drive
    • 512GB SATA 6 Gb/s Solid State Drive
    • RAID 0 and 1 supported
Memory
  • Standard
    • DDR3L 1.35 V SDRAM (1600 MHz)
    • Two SODIMM slots (Dual-core processor) or four SODIMM slots (Quad-core processor) supporting dual-channel memory
    • 2GB, 4GB, and 8GB SODIMMs
  • Maximum
    • Upgradeable to 16384MB with optional 8192MB SODIMMs in both slots (Dual-core processor)
    • Upgradeable to 32768MB with optional 8192MB SODIMMs in all 4 slots (Quad-core processor)
  • Dual-channel
    Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Networking/Communications
  • Wireless
  • Mobile Broadband options
    • HP hs3110 HSPA+ Mobile Broadband Module
    • HP lt4111 LTE/EV-DO/HSPA+ Gobi4G Module
    • HP lt4112 LTE/HSPA+Gobi4G Module (EMEA,APJ)
  • All 802.11 integrated wireless LAN options
    • Intel Dual Band Wireless-AC 7260 802.11 ac (2x2) + Bluetooth 4.0 LE Combo
    • Intel Centrino Advanced-N 6235 802.11 a/b/g/n (2x2) + Bluetooth 4.0 LE Combo
    • Intel Centrino Advanced-N 6205 802.11 a/b/g/n (2x2)
  • Communications
    Integrated Intel I217-LM Gigabit Network Connection (vPro configurations)
Audio/Multimedia
  • Audio
    • DTS Studio Sound HD audio (Windows OS only)
    • Integrated stereo speakers
    • Integrated microphone (dual-microphone array when equipped with optional webcam)
    • Button for volume mute; function keys for volume up and down
    • Combo mic-in / stereo headphone-out jack
  • Webcam
    Optional 720p HD webcam
    • HD format (widescreen)
    • Supports videoconferencing and still image capture
    • High quality fixed focus lens
    • Video capture at various resolutions up to 1280x720 resolution (720p) and up to 30fps
    • M-JPEG compression supports higher frame rates for video capture and videoconferencing
    • Improved low light sensitivity
    • Improved dynamic range
NVIDIA Quadro mobile professional graphics support up to four independent displays when using an HP Advanced Docking station (sold separately) without hybrid graphics enabled, and up to 5 with Hybrid graphics enabled.
System specifications
Specification
Stand-alone power requirements (AC power)
Nominal operating voltage: 19.5 V
Average operating power:
  • Windows 7 (32-bit): 16.28 W
  • Windows 7 (64-bit): 16.8 W
Max operating power: Less than 150 W or less than 200 W
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
  • -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6° F (38.7° C) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • EPEAT: Less than 150 W or less than 200 W
  • ICES: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
Display specifications
15.6-inch diagonal LEDbacklit FHD UWVA eDP anti-glare + Panel Self Refresh (PSR) (1920 x 1080)
Specification
Active area (W x H)
34.4 x 19.4 cm (13.54 x 7.59 in)
Dimensions (W x H)
39.6 cm (15.6 in)
420 g (max)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nit (typical)
Pixel resolution
  • Format: 1920 x 1080 (FHD)
  • Configuration: RGB Stripe
Backlight
LED
PPI
142
Viewing angle
UWVA 85/85/85/85
15.6-inch LED FHD UWVA (1920 x 1080) anti-glare DreamColor
Specification
Active area (W x H)
Dimensions (W x H)
39.6 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
800:1 (min)
Refresh rate
48 Hz, 50 Hz and 60 Hz
Brightness
210 nits (typical)
Pixel resolution
  • Pitch: 0.179 mm x 0.179 mm
Backlight
RGB LED
PPI
142
Viewing angle
±89° Horizontal, ±89° Vertical (typical)
Technology type
30-bit In-Plane Switching (IPS)
Color depth
10-bits/color
Display colors
Over 1 billion colors (native mode)
Color gamut coverage
NTSC:
  • CIE1931 (x,y): 109%
  • CIE 1976 (u',v'): 129%
AdobeRGB
  • CIE1931 (x,y): 114%
  • CIE 1976 (u',v'): 127%
sRGB
  • CIE1931 (x,y): 154%
  • CIE 1976 (u',v'): 148%
15.6-inch diagonal LEDbacklit FHD SVA eDP antiglare (1920 x 1080)
Specification
Active area (W x H)
Dimensions (W x H)
39.6 cm (15.6 in)
380 g (max)
Surface treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
300 nit (typical)
Pixel resolution
Backlight
LED
PPI
142
Viewing angle
UWVA 85/85/85/85
HDD specifications
1TB 5400 rpm SATA Hard Drive
Specification
Drive weight
115g (0.25 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum) 300MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Single Track: 4 ms
  • Average: 14 ms
  • Maximum: 24 ms
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Operating temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA security
500GB 7200 rpm SATA Hard Drive
Specification
Drive weight
115g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Single Track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16GB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
500GB 5400 rpm SATA FIPS Hard Drive
Specification
Drive weight
115g (0.25 lb)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
Specification
Drive weight
115g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
Transfer rate
  • Single Track: 1 ms
  • Average: 12 ms
  • Maximum: 20 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
320GB 7200 rpm SATA Hard Drive
Specification
Drive weight
115g (0.25 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
625,142,448
Features
ATA security
SATA 6 Gb/s 512 GB, 2.5- inch Solid State Drive
Specification
Drive weight
73g
Capacity
512GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: 460 MB/s
  • Maximum Sequential Write: 260 MB/s
Logical blocks
1,000,215,216
0° to 70° C (32° to 158° F) [case temp]
Features
ATA security; ATA-8; SATA 3.0 DIPM; TRIM
SATA 6 Gb/s 128 GB, 2.5- inch Solid State Drive
Specification
Drive weight
73g
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: 415 MB/s
  • Maximum Sequential Write: 175 MB/s
Logical blocks
250,069,680
Features
Optical drive specifications
DVD-ROM Drive
Specification
Access times
Random:
Less than 140 ms CD (typical)
Less than 160 ms DVD (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X-DVD
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported Media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
Supported Media (write)
None
Max Media Capacity (read)
8.5GB
Transport
Tray Loading
Specification
Access times
Random:
  • 24X CD-ROM
  • 8X-DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 6X - DVD+R Dual Layer
  • 6X - DVD-R Dual Layer
  • 5X DVD-RAM
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
8.5GB
Max Media Capacity (write)
8.5 GB
Transport
Tray Loading
Specification
Access times
Random:
Less than 190 ms CD-ROM (typical)
Less than 180ms DVD-ROM (typical)
Less than 230 ms BD-ROM (typical)
  • 24X CD-ROM
  • 8X-DVD
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 4X - DVD+R Dual Layer
  • 4X - DVD-R Dual Layer
  • 5X DVD-RAM
  • 6X BD-ROM
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
CD-DA, , CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW. DVD-RAM, BD-ROM, BD-R, BD-RE
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVDRAM
50.0 GB
8.5 GB
Transport
Tray Loading
Specification
Access times
Random:
Less than 165 ms CD-ROM (typical)
Less than 185 ms DVD-ROM (typical)
Less than 205 ms BD-ROM (typical)
  • 24X CD-ROM
  • 8X-DVD
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD+R Dual Layer
  • 6X DVD-R Dual Layer
  • 5X DVD-RAM
  • 6X BD-ROM
  • 6X BD-R
  • 2X BD-RE
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVDRAM, BD-R, BD-RE
50.0 GB
50.0 GB
Transport
Tray Loading
Intel® I217-LM Gigabit Network Connection
Specification
Ethernet Features
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mbit/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023. Clauses 40)
  • IEEE 802.3u Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE(Energy Efficient Ethernet)
  • IEEE 802.1as/1588 conformance
  • Jumbo Frame 9K
  • Auto MDI/MDIX Crossover cable detection
Power Management
  • ACPI compliant - multiple power mode
  • Energy Detect Low Power Mode(Green Ethernet)
Performance Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Protocol Offload( ARP & NS)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
  • MACSec Offload (802.3ae)
  • Intel vPro
  • iSCSI Boot
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only) PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30)
  • Comprehensive diagnostic and configuration software suite Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ.
NIC Device Driver Name
Intel Ethernet Network Connection I217-LM
Specification
Technology/Operating Bands
  • 1Modes: WCDMA/HSDPA/HSUPA/HSPA+/AWS/GSM/EDGE/GPRS
  • Penta-band WCDMA/HSDPA/HSUPA/HSPA+/AWS: 850/900/1900/2100/AWS MHz
  • GSM/GPRS/EDGE: 850/900/1800/1900 MHz
Wireless Protocol Standards
  • GSM/GPRS/EDGE: Class B, Multi-slot class 33, coding schemes CS1 - CS4 and MSC1 - MSC9.
  • UMTS/WCDMA: Release 99 and Release 7 Advanced Receiver Type 3i
Wireless Parametric Standards
Complies with 3GPP specifications
Maximum Data Rates
  • GPRS/EDGE: Multi-slot Class 33, Class B
  • WCDMA PS: UL (384 kbps) / DL (384 kbps)
  • UL/DL HSPA: UL (5.76 Mbps)/ DL (7.2 Mbps)
  • UL/DL HSPA+: UL (5.76 Mbps)/ DL (21Mbps)
GPS
GPS Standalone, A-GPS: L1 (Internet- and Network assisted
GPS Bands
1575.42 MHz (± 1.023 MHz)
Maximum Output Power
  • WCDMA/HSPA/HSPA+ 2100/1900/900/850/AWS MHz: +24dBm (Power Class 3)
  • GPRS 1900/1800 MHz: +30dBm (Power Class 1)
  • GPRS 900/850 MHz: +33dBm (Power Class 4)
  • EDGE 1900/1800 MHz: +26dBm (Power Class E2)
  • EDGE 900/850 MHz: +27dBm (Power Class E2)
Maximum Power Consumption
2500mA (peak); 600mA (average)2700mA (peak)
Power Consumption, Sleep Mode
3.6 mA
Power Management
USB selective suspend, Connected Standby Integrated notebook wireless button
Antenna Type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the display enclosure
Form Factor
M.2 Socket 2, USB 2.0 interface high speed
Less than 6g
HP lt4111 LTE/EVDO/ HSPA+ Mobile Broadband Module*
Specification
  • LTE FDD all bands with diversity: 1900 MHz (Band II) , 1700/2100MHz (Band IV (AWS), 850 MHz (Band V), 700MHz (Band XIII), 700MHZ (Band XVII), 1900MHz G Block (Band XXV)
  • WCDMA/HSDPA/HSUPA/HSPA+: all bands with diversity: 2100 MHz (Band I), 1900 MHz (Band II) , AWS 1700/2100MHz (Band IV), 850 MHz (Band V), 800 MHz (Band VIII)
  • GSM/GPRS/EDGE: 1900 MHz, 1800 MHz , 850 MHz , 900 MHz
  • CDMA: Cellular 800MHz (BC0), PCS 1900MHz (BC1)
  • 3GPP Release 8 LTE Specification
  • WCDMA R99, 3GPP Release 5, 6 and 7 UMTS Specification EVDO Release 0 and Release A
Complies with 3GPP specifications Release 8 for LTE
Maximum Data Rates
  • LTE (Category 3): 100 Mbps (Download), 50Mbps (Upload)
  • DC-HSPA+: 42 Mbps (Download), 5.76 Mbps (Upload)
  • HSPA+: 21.6 Mbps (Download), 5.76 Mbps (Upload)
  • EDGE: 236.8 kbps (Download), 236.8 kbps (Upload)
  • GPRS: 85.6 kbps(Download), 85.6 kbps (Upload)
GPS
Standalone GPS, A-GPS, GPS XTRA
GPS Bands
LTE: +23 dBm (+/- 1 dBm)
  • WCDMA: +23 dBm (+/- 1 dBm)
  • LTE: +23 dBm (+/- 1 dBm)
  • GSM850/900, GMSK: +32dBm (+/- 1dBm)
  • GSM850/900, 8PSK: +27dBm (+/- 1dBm)
  • DCS1800 / PCS 1900, GMSK: +29dBm (+/- 1dBm)
  • DCS1800 / PCS 1900, 8PSK: +26dBm (+/- 1dBm)
  • CDMA: +24dBm (+/- 1dBm)
  • LTE: 1,200 mA (peak); less than 900 mA (average)
  • WCDMA: 1,100 mA (peak); less than 800 mA (average)
  • EGPRS: 2,500 mA (peak); less than 700 mA (average)
2 mA
Power Management
USB selective suspend, Integrated notebook wireless button
Antenna Type
Dual high efficiency multi-band antennae with spatial diversity
Form Factor
M.2, 3042-S3 Key B
Less than 6g
Dimensions (Length x Width x Thickness)
42 mm × 30 mm × 2.3 mm
Voltage, Operating
3.135 V to 4.4 V (3.3 V +1.1V/-0.165V)
Temperature, operating (from TIA/EIA/IS-98-D)
-13° to 140° F (-25° to 60° C)
Temperature, nonoperating, 96 hours (from MIL-STD 202 Method 108)
-40° to 185° F (-40° to 85° C)
Humidity, non-operating
95% relative humidity for 48 hours @ 185° F (85° C) (non-condensing)
LED activity
LED Off - Radio Off; Solid LED On - Radio On
HP lt4112 LTE/HSPA+ Gobi 4G Module
Specification
  • LTE FDD all bands with diversity: 2100 MHz (Band I), 1900 MHz (Band II), 1800 MHz (Band III), 850 MHz (Band V), 2600 MHz (Band VII), 900 MHz (Band VIII), 700 MHz (Band XX, DD800)
  • WCDMA/HSDPA/HSUPA/HSPA+ all bands with diversity: 2100 MHz (Band I), 1900 MHz (Band II), 800 MHz (Band V), 900 MHz (Band VIII)
  • GSM/GPRS/EDGE: 1900 MHz (Band II), 1800 MHz (Band III), 850 MHz (Band V), 900 MHz (Band VIII)
Maximum Data Rates
GPS
Standalone
GPS Bands
1575.42 MHz (± 1.023 MHz), GLONASS 1596-1607MHz
  • LTE: +23 dBm (+/- 2 dBm)
  • WCDMA: +23.5 dBm (+/- 1 dBm)
  • GPRS Band II, III: +29.5 dBm (+/- 1 dBm)
  • GPRS Band V, VIII: +32.5 dBm (+/- 1 dBm)
  • EGPRS Band II, III: +26.5 dBM (+/-1.5 dBm)
  • EGPRS Band V, VIII: +27.5 dBM (+/-1.5 dBm)
  • EGPRS: 2,800 mA (peak); less than 700 mA (average)
3 mA
Power Management
Antenna Type
Form Factor
M.2, USB 2.0 interface
6g
Voltage, Operating
–10° to 55° C (14° to 131° F)
–40° to 85° C (–40° to 185° F)
LED activity
Intel Dual Band Wireless- AC 7260 802.11 ac (2x2) WiFi + BT 4.0 combo Adapter
Specification
Wireless LAN Standards
  • IEEE 802.11a
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11ac
Interoperability
Wi-Fi certified
Frequency Band
802.11b/g/n
  • 2.402 - 2.482 GHz
802.11a/n
  • 4.9 - 4.95 GHz (Japan)
  • 5.15 - 5.25 GHz
  • 5.25 - 5.35 GHz
  • 5.47 - 5.725 GHz
  • 5.825 - 5.850 GHz
  • 2.402 - 2.482 GHz
Data Rates
  • 802.11b: 1, 2, 5.5, 11 Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11n: MCS 0 ~ MCS 15, (20MHz, and 40MHz)
  • 802.11ac : MCS0 ~ MCS9, (1SS, and 2SS) (20MHz, 40MHz, and 80MHz)
Modulation
Direct Sequence Spread Spectrum
BPSK, QPSK, CCK, 16-QAM, 64-QAM, 256-QAM
Security
  • IEEE and WiFi compliant 64 / 128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES.
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through CCX4 and CCX Lite
  • WAPI
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output Power
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
  • Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas >20cm from the user and peak gain of +3dBi at 2.4GHz and +4dBi at 5GHz
Power Consumption
ACPI and PCI Express compliant power management 802.11 compliant power saving mode
Receiver Sensitivity
  • 802.11a/g:-90 dBm (6 Mbps), -89 dBm (9 Mbps), -87 dBm (12 Mbps), -85 dBm (18 Mbps), -82 dBm (24 Mbps), -79 dBm (36 Mbps), -76 dBm (48 Mbps), -74 dBm (54 Mbps)
  • 802.11b:-95 dBm (1 Mbps), -93 dBm (2 Mbps), -91 dBm (5.5 Mbps), -88 dBm (11 Mbps)
  • 802.11n:-69 dBm (72.2 Mbps), -66 dBm (300 Mbps)
Antenna type
  • Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
  • High efficiency antenna with spatial diversity, mounted in the display enclosure
Audio/Multimedia - DTS sound
Specification
Implementation
IDT 92HD91
Function key volume
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
Less than 85 dB
Total harmonic distortion
0.01%
Noise floor
- 110 dB
Play/Record sampling rate(s)
8 kHz - 48 kHz
D ac
16, 20 or 24-bit
ADC
16 or 20-bit
Internal stereo speakers
Power rating
2 W
Impedance
4 ohms
Power
HP 65W EM Smart AC Adapter
Specification
Dimensions
12.65 x 5.0 x 3.0 cm (4.98 x 1.97 x 1.18 in)
290 g (0.62 lb)
Input
190 to 265 V ac
Input Efficiency: 87% min at 115 V ac
Input frequency range: 47 to 63 Hz
Input ac current: 1.7 A at 90 V ac
Output
Output power: 65W
DC output: 19.5V
Hold-up time: 5 msec at 115 V ac input
Output current limit: less than 11 A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
Operating temperature: 0° to 35° C (32° to 95° F)
Non-operating (storage) temperature: -20° to 85° C (-4° to 121° F)
Altitude: 0 to 5,000 m (0 to 16,405 ft)
Humidity: 0% to 95%
Storage Humidity: 0% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within the first three years of operation.
HP 200W Slim Smart AC Adapter
Dimensions
172 x 96 x 25.4 mm (6.77 x 3.80 x 1.0 in)
Weight (max)
748 g (1.65 lb)
Input
100 to 240 VAC
  • 100 to 240 VAC
  • Input Efficiency 87% min at 115 VAC
  • Input frequency range 47 to 63 Hz
  • Input AC current 2.9 A at 90 VAC, 1.45 A at 180 VAC
Output
  • Output power 200W
  • DC output 19.5V
  • Hold-up time 5 msec at 115 VAC input
  • Less than 16A, Over voltage protection- 29V max automatic shutdown
Connector
Environmental Design
0° to 40° C (32° to 104° F)
-20° to 65° C (-4° to 149° F)
Altitude
0 to 3,048 m (0 to 10,000 ft)
Humidity
20% to 80%
Storage Humidity
10% to 90%
EMI and Safety Certifications
CE Mark- full compliance with LVD and EMC directives; Worldwide safety standards- IEC950, EN60950, UL1950, Class 1, SELV; Agency approvals- C-ULUS, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCIB, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
HP 150W Slim Smart AC adapter
Specification
Dimensions
6.59 x 3.23 x 1.0 in (167.5 x 82 x 25.4 mm)
565 g (1.25 lb)
Input
100 to 240 VAC
Input AC current Less than 2.7 A at 90 VAC
Output
Output power 150W
DC output 19.50V +5.0%/-5.0%
Output current limit Less than 15A, Over voltage protection- 29V max automatic shutdown
Connector
Operating temperature 5° to 35° C (41° to 95° F)
Non-operating (storage) temperature-20° to 85° C (-4° to 185° F)
Altitude Humidity
  • 0 to 10,000 ft (0 to 3,048 m)
  • 10% to 95%
  • 10% to 95%
Worldwide safety and EMC approvals including CE, UL, CSA or cUL, GS, Australian Electric Permit, C-tick, NOM, CCC, KC, GOST, SABS, S mark, BSMI, ISC, PSE, PSB and SII.
HP 8-cell Lithium-Ion Battery (83 WHr)
Dimensions
2 x 5.3 x 27cm (0.8 x 2.1 x 10.6 in)
Weight (max)
0.442 kg (0.99lb)
Cells/Type
Lithium-Ion
Energy
  • Voltage: 14.8V
  • Amp-hour capacity: 5.6Ah
  • Watt-hour capacity: 83Wh
Temperature
Operating (Charging: 0° to 45° C (32° to 113° F)
Operating (Discharging) F(-10° to 50° C (14° to 122°)
Non-operating: -20° to 50° C -4° to 122° F
Battery Re-Charge Time
System in OFF or Standby: 2.5 hours
System ON : 3 to 5 hours
Fuel Gauge LED
No
1 year
Compatible with optional Travel Battery
Yes
HP Long Life 8-cell Lithium-Ion Battery (75 WHr)
Specification
Dimensions (H x W x L)
Weight (max)
0.442 kg (0.99lb)
Cells/Type
8-cell; Lithium-Ion
Energy
  • Voltage: 14.8V
  • Amp-hour capacity: 5.1Ah
  • Watt-hour capacity: 75Wh
Temperature
Operating (Discharging) 10° to 60° C (14° to 140° F)
Non-operating: -20° to 60° C (-4° to 140° F)
System in OFF or Standby Mode: 2.5 hours
System ON: 3 to 5 hours
Fuel Gauge LED
No
3 year
Yes
Physical specifications
Feature
Weights and dimensions
  • Starting at 2.82 kg) (6.20 lb) with mini-card SSD and weight saver (no optical drive).
  • Starting at 2.93 kg (6.45 lb) with hard drive and DVD-R/W drive.
Dimensions (w x d x h)
  • 0.19 x 1.06 x 1.18 in
  • 3.1 x 26.8 x 30.0 mm
Ports/Slots
Ports
  • VGA – One
  • DisplayPort v1.2– One
  • Stereo microphone in / headphone-out combo jack – One
  • Power Connector – One
  • Secondary Battery Connector – One
  • Docking Connector – One
  • RJ-45 (Ethernet) – One
  • USB 3.0 – Two
  • USB 3.0 Charging Port – One
  • USB 2.0 – One
  • Security lock slot – One
Digital media slots
  • ExpressCard/54 slot – One (Supports ExpressCard/54)
  • SD UHS-II Flash Media slot – One
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 8-cell battery, hard drive, 1 GB memory, and no optical drive. Weight varies by configuration and components.
Software/OS
Feature
  • Windows 8 Pro 64
  • Windows 8 64
  • Windows 7 Professional 32 (available through downgrade rights from Windows 8 Pro)
  • Windows 7 Professional 64
  • SuSE Linux Enterprise (SLED 11) SP2 64bit
  • FreeDOS
Preinstalled software with Windows operating system
Preinstalled
  • HP Recovery Manager
  • HP Performance Advisor
  • HP Remote Graphics Software (pre-load)
  • HP Support Assistant
  • HP Client Security
  • HP Hotkey Support
  • HP Wireless Hotspot (Windows 8 only)
  • HP Connection Manager (Windows 7 only)
  • HP GPS and Location (Select Models) (Windows 7 only)
  • Adobe Flash Player (Windows 7 only)
  • Buy Office
  • Microsoft Office 2013 Trial Version
  • Microsoft Security Essentials
  • Cyberlink Power DVD
  • Cyberlink Power2Go
  • PDF Complete Corporate Edition
  • Skype
Additional software available from the web
  • HP SoftPaq Download Manager
  • HP Software System Manager
  • HP Peak Power Manager
HP Recovery Manager
Security
Standard
  • HP Client Security (Windows 7 & 8) (standard modules include)
    • Credential Manager
    • Computrace
    • Device Access Manager with Just In Time Authentication
    • Drive Encryption
    • Validity Fingerprint Driver
    • File Sanitizer (Windows 8 only)
    • Trust Circles
  • HP Fingerprint Sensor (optional)
  • Integrated Smart Card Reader
  • Enhanced Pre-Boot Security (Multiuser / Multifactor)
  • One-Step Logon
  • Support for Intel AT
Security
Specification
Mobile voltage operation
3.0V -3.6V single supply
-10° - 75°C (14° - 167°F)
Current consumption image
36mA
Low latency wait for finger
950 uA
Capture rate
3000 lines/sec
ESD Resistance
IEC 6100-4-2 4B (+/-15KV)
Detection matrix
200*1 (plus another secondary line); 508 dpi, sensor area 12*3 mm
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
Country/Region: Flag Singapore
