Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
    Lär dig hur du uppgraderar till Windows 11
    Handbok för uppgradering till Windows 11
  • Respons
Åtgärder
Läser in...
HP Printers - Troubleshoot a USB Printer Connection
This document is for HP printers with a USB cable connection.
If the computer is unable to detect the printer over a USB connection, restart the computer, the printer, and check the cable connection.
  1. Turn off the printer and your computer, and then disconnect the USB cable from the computer.
  2. Inspect the cable.
    • Look for any damage. If the cable is damaged, replace the cable.
    • Check the length of the cable. If the cable is more than 3 m (9 ft 10 in) in length, replace the cable with one that is shorter.
  3. Connect the cable to a different USB port on the computer. The port should be USB 2.0 or greater. If you use a USB hub or docking station, connect the cable directly to the computer.
  4. Make sure the cable is fully secured to both ports.
  5. Turn on the computer, and then wait for the computer to complete the startup.
  6. Turn on the printer.
    • Windows: Wait for the computer to install the new device.
    • Mac: Add the printer, if you have not already done so.
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
