Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
    Windows 11
    Hitta vanliga frågor och svar här.
  • Respons
Åtgärder
Läser in...
SUPPORT COMMUNICATION- SECURITY BULLETIN
Dokument-ID: c06154544
Version: 2
HPSBHF03593 rev. 2 - Firmware Trusted Platform Module (fTPM) for Select AMD Client Systems
Notice:: The information in this security bulletin should be acted upon as soon as possible.
Utgivningsdatum : 28-Sep-2018
Last updated : 07-Feb-2019
Potential Security Impact:
Unauthorized access, elevation of privilege.
Source: HP, HP Product Security Response Team (PSRT)
Reported By: CTS-Labs
SÅRBARHETS-SUMMERING
A security vulnerability has been identified in specific versions of the AMD firmware-based Trusted Platform Module (fTPM). The fTPM is used only on AMD platforms (see platform list below) in place of a discrete hardware-based Trusted Platform Module (TPM). This vulnerability can potentially compromise applications that utilize the fTPM.
Affected platforms have a softpaq with a firmware update for the fTPM.
Referensnummer
CVE-N/A, PSR-2018-0233: AMD fTPM (in English)
PROGRAMVARUVERSIONER SOM STÖDS*: ENDAST berörda versioner är listade.
Microsoft operating systems
BAKGRUND
For a PGP signed version of this security bulletin, please write to: hp-security-alert@hp.com.
CVSS 3.0 Base Metrics
Reference
Base Vector
Base Score
CVE-N/A
N/A
N/A
LÖSNING
  1. Run the Softpaq update.
  2. Run TPM.MSC: Press the Win+ R keys to open Run, type tpm.msc, and then click/tap on OK to open the TPM Management snap-in.
  3. Check the Manufacturer version for the TPM.
      The Manufacturer details of the TPM
    1. This means AMD fTPM is enabled
    2. This is the AMD fTPM version
  4. If the Manufacturer Version starts with a 3, it is necessary to clear the TPM to fully mitigate the vulnerability.
      varning!
    Failure to properly prepare your system before clearing the TPM may cause data protected by a TPM key to become unavailable. Read the following section completely before continuing.
Before using any of the clear TPM instructions, follow all OS recommended preparations to disable or suspend software or system features that depend on the TPM protections (for example, precautions to take before clearing the TPM in Microsoft Windows).
  • Disable or suspend all applications and services that use the TPM.
    obs!
    The most common use of the TPM is Microsoft Bitlocker.
  • Back up all TPM protected data.
  • HP recommends that customers using Microsoft Windows on the latest HP products follow the Clear TPM instructions provided on the following Microsoft website: https://docs.microsoft.com/en-us/windows/security/information-protection/tpm/initialize-and-configure-ownership-of-the-tpm (in English).
    obs!
    On some HP systems, the system BIOS (UEFI) might prompt the user to accept the request to clear the TPM via Windows TPM.MSC. Users must accept the change to complete clearing the TPM. Do not accept the request if this message is shown and you have not initiated clearing the TPM; instead contact your administrator.
This bulletin will be updated; check back frequently for updates. HP is identifying affected platforms and target dates for SoftPaqs. See the current list below.
Consumer PCs
Product Name
New Version
SoftPaq #
SoftPaq Link
HP Pavilion 23-p0xx All-in-One PC
80.05
SP87651
HP All-in-One 18-xxxx
A0.15
SP87825
Compaq All-in-One 18-xxxx
A0.15
SP87825
HP 110-5xx
A0.16
SP87656
HP 251-axxx
A0.16
SP87656
HP Pavilion 550-axxx
A0.16
SP87656
HP Slimline 450-axxx
A0.16
SP87656
Compaq 100-xxx
A0.16
SP87656
HP 110-5xx
A0.16
SP87656
HP All-in-One 22-2xxx
Not Available
Not Available
Not Available
HP All-in-One 19-3xxx
Not Available
Not Available
Not Available
HP All-in-One 19-2xxx
Not Available
Not Available
Not Available
A0.17
SP87637
HP ENVY 750-xxx
Not Available
Not Available
Not Available
HP Pavilion 550-xxx
Not Available
Not Available
Not Available
HP All-in-One 20-rxxx
Not Available
Not Available
Not Available
HP All-in-One 23-rxxx
Not Available
Not Available
Not Available
HP All-in-One 22-3xxx
Not Available
Not Available
Not Available
HP All-in-One 20-exxx
Not Available
Not Available
Not Available
HP Pavilion All-in-One 22-axxx
Not Available
Not Available
Not Available
HP Pavilion All-in-One 23-qxxx
Not Available
Not Available
Not Available
HP 251-axx
A0.14
SP87330
A0.14
SP87330
HP Pavilion 500-xxx
Not Available
Not Available
Not Available
HP Pavilion 510-pxxx
F.21
SP87083
HP All-in-One 20-cxxx
F.41
SP87538
HP All-in-One 22-bxxx
F.41
SP87538
HP All-in-One 24-gxxx
F.41
SP87538
HP Pavilion All-in-One 24-bxxx
F.42
SP87152
F.41
SP87155
HP OMEN 870-0xx
F.41
SP87155
HP Slimline 260-axxx
F.31
SP87792
HP 460-axxx
F.31
SP87792
HP Pavilion 510-axxx
F.31
SP87792
F.24
SP87146
F.24
SP87146
HP All-in-One 24-exxx
F.24
SP87146
HP Pavilion All-in-One 24-xxxx
F.12
SP87097
F.12
SP87101
HP Pavilion Power 580-1xx
F.22
SP87363
HP ENVY 750-6xx
F.22
SP87363
HP Pavilion All-in-One 27-rxxx
F.12
SP87094
HP Pavilion All-in-One 24-rxxx
F.12
SP87099
F.12
SP87099
HP OMEN 880-xxx
F.11
SP87263
HP Slimline 270-axxx
F.23
SP87079
HP Pavilion 570-axxx
F.23
SP87079
HP Pavilion 570-pxxx
F.23
SP87082
F.01
SP85268
HP All-in-One 22-cxxx
F.04
SP87147
HP All-in-One 24-fxxxx
F.04
SP87147
HP Pavilion 590-pxxxx (ROM Family SSID 8433)
F.08
SP87366
HP Pavilion 590-pxxxx (ROM Family SSID 8434)
F.08
SP87367
HP Pavilion 590-axxxx (ROM Family SSID 8435)
F.08
SP87368
HP Pavilion 590-axxxx (ROM Family SSID 8436)
F.05
SP87204
HP Slimline 290-axxxx
F.03
SP87205
HP Pavilion 15-p000~15-p099
F.46
SP87479
HP Pavilion 15-p100~15-p199
F.46
SP87479
HP Pavilion 17-f000~17-f099
F.46
sp87479
HP Pavilion 17-f100~17-f199
F.46
sp87479
HP Envy 15-q1xx
F.27
SP87172
HP 15-e000~HP 15-e099
F.48
SP87348
Compaq 15-b000~Compaq 15-b099
F.48
SP87348
HP 15-e100~HP 15-e199
F.48
SP87348
Compaq 15-b100~Compaq 15-b199
F.48
SP87348
HP 14-g000~HP 14-g099
F.48
SP87348
Compaq 14-h000~Compaq 14-h099
F.48
SP87348
HP Pavilion 14-v000~14-v099
F.46
sp87479
HP Pavilion 14-v100~14-v199
F.46
sp87479
HP Pavilion x360 13-a0XX
F.16
SP87345
HP 14-w0xx
F.40
SP87356
HP 15-f0xx
F.40
SP87356
HP 15-f1xx
F.42
SP87182
HP Pavilion 15-p200~15-p299
F.46
sp87479
HP Pavilion 15-p200~15-p399
F.46
sp87479
HP 17-p000 ~ 17-p099
F.18
SP87268
HP 17-p100 ~ 17-p199
F.18
SP87268
HP Pavilion 17-f200~17-f299
F.46
sp87479
HP Envy 15-q2xx
F.27
SP87172
HP 15-e200~HP 15-e299
F.48
SP87348
Compaq 15-b200~Compaq 15-b299
F.48
SP87348
HP 15-g300~HP 15-g399
F.48
SP87348
HP Pavilion 15-ab000~15-ab099
F.52
SP90267
HP Pavilion 15-ab100~15-ab199
F.52
SP90267
HP 14-g100~HP 14-g199
F.48
SP87348
Compaq 14-h100~Compaq 14-h199
F.48
SP87348
HP 14-af0XX
F.21
SP91343
HP 14-af1XX
F.21
SP91343
HP Pavilion 14-ab000~14-ab099
F.52
SP90267
HP Pavilion 14-ab100~14-ab199
F.52
SP90267
HP Pavilion 14-v200~14-v299
F.46
sp87479
HP Pavilion x360 13-a1XX
F.16
SP87345
HP ENVY m6-p000 ~ m6-p099
F.19
sp87581
HP ENVY 15-ah000 ~ 15-ah099
F.19
sp87581
HP ENVY m6-p100 ~ m6-p199
F.19
sp87581
HP ENVY 15-ah100 ~ 15-ah199
F.19
sp87581
HP Pavilion 17-g000~17-g099
F.52
SP90267
HP Pavilion 17-g100~17-g199
F.52
SP90267
HP 14-w1xx
F.40
SP87356
HP 15-f3xx
F.42
SP87182
HP 15-af0XX
F.25
SP87665
HP 15-af1XX
F.25
SP87665
HP Pavilion 15-aw001 ~ 15-aw099
F.29
SP87548
ENVY x360 m6-ar0XX
F.20
SP87179
ENVY x360 15-ar0XX
F.20
SP87179
HP 15-ba000 ~ 15-ba099
F.32
SP87426
HP 15-ba100 ~ 15-ba199
F.32
SP87426
HP 14-an000 ~ 14-an099
F.31
SP87417
HP Pavilion 14-av001 ~ 14-av099
F.27
SP87388
HP 17-y000~17-y099
F.40
SP87652
HP 17-y500 - 17-y599
F.40
SP87652
HP 17-ak000 ~ 17-ak099
F.08
SP87058
HP Pavilion 15-cd001 ~ 15-cd099
F.23
sp87116
HP Pavilion 17-ar001 ~ 17-ar099
F.23
sp87116
HP 15-bw0xx
F.23
SP87191
HP 15g-bx0xx
F.23
SP87191
HP 15q-by0xx
F.23
SP87191
HP 14-bw0xx
F.23
SP87157
HP 14g-bx0xx
F.23
SP87157
HP 14q-by0xx
F.23
SP87157
HP ENVY x360 m6-bq0xx
F.08
SP87124
HP ENVY x360 15-bq0xx
F.08
SP87124
HP ENVY x360 m6-bq1xx
F.17
SP87238
HP ENVY x360 15-bq1xx
F.17
SP87238
HP 17-ca0000~17-ca0999
F.04
SP87285
HP 14-cg0xxx
F.04
SP87286
HP 14g-cg0xxx
F.04
SP87286
HP 14q-cg0xxx
F.04
SP87286
HP 15-da0000 ~ 15-da0099
F.03
SP87561
HP 15g-da0000 ~ 15g-da0099
F.03
SP87561
HP 15q-da0000 ~ 15q-da0099
F.03
SP87561
HP 255 G1
F.49
SP88265
HP 255 G3
F.48
SP87348
HP 245 G3
F.48
SP87348
HP 245 G4
F.21
SP91343
HP 255 G4
F.25
SP87665
HP 255 G5
F.32
SP87426
HP 240 G5 Notebook PC
F.31
SP87417
HP 245 G5 Notebook PC
F.31
SP87417
HP 255 G6
F.23
SP87191
HP 245 G6
F.23
SP87157
Pending: SoftPaq is in progress.
Under Investigation: SoftPaq is being investigated for feasibility and availability.
Not Available: SoftPaq not available due to technical or logistical constraints.
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy.
Support: For issues about implementing the recommendations of this Security Bulletin, visit https://www.hp.com/go/contacthp to learn about your HP support options.
Report: To report a potential security vulnerability with any HP supported product, send email to: hp-security-alert@hp.com.
Subscribe: To initiate a subscription to receive future HP Security Bulletin alerts via email, visit https://www.hp.com/go/alerts.
Security Bulletin Archive: To view released Security Bulletins, search the HP Support Site for "security bulletin".
Software Product Category: The Software Product Category is represented in the title by the two characters following HPSB.
PI
HP Printing and Imaging
HF
HP Hardware and Firmware
GN
HP General Software
It is strongly recommended that security related information being communicated to HP be encrypted using PGP, especially exploit information.
To get the security-alert PGP key, please send an e-mail message as follows:
Subject: get key
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin.HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action.HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin.To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISIONSHISTORIK : Version:1 - 28 September 2018 Initial Release. Version: 2 - 7 February 2019 Updated pending Consumer PC products with new softpaqs.
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
