Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
    Windows 11
    Hitta vanliga frågor och svar här.
  • Respons
Åtgärder
Läser in...
SUPPORT COMMUNICATION- SECURITY BULLETIN
Dokument-ID: c06114399
Version: 2
HPSBHF03590 rev. 2 - L1 Terminal Fault (L1TF)
Notice:: The information in this security bulletin should be acted upon as soon as possible.
Utgivningsdatum : 14-Aug-2018
Last updated : 15-Aug-2018
Potential Security Impact:
Unauthorized exposure of privileged data from memory.
Source: HP, HP Product Security Response Team (PSRT), Intel
Reported By: Intel
SÅRBARHETS-SUMMERING
A new speculative execution side channel variant has been discovered called L1 Terminal Fault (L1TF). There are no reports that L1TF has been used in real world exploits. This currently affects select Intel processors. Mitigations will require microcode updates released earlier this year, plus operating system and hypervisor software updates. In some cases, Intel and Microsoft guidance suggests additional mitigations, see their bulletins for more information.
More information is available at the following links:
Referensnummer
CVE-2018-3615, CVE-2018-3620, CVE-2018-3646, Intel SA-00161, PSR-2018-0205
PROGRAMVARUVERSIONER SOM STÖDS*: ENDAST berörda versioner är listade.
See RESOLUTION section for impacted products.
BAKGRUND
For a PGP signed version of this security bulletin please write to: hp-security-alert@hp.com
CVSS 3.0 Base Metrics
Reference
Base Vector
Base Score
CVE-2018-3615
CVE-2018-3620
CVE-2018-3646
CVSS:3.0/AV:L/AC:L/PR:N/UI:N/S:C/C:H/I:L/A:N
CVSS:3.0/AV:L/AC:L/PR:N/UI:N/S:C/C:H/I:N/A:N
7.9
7.1
7.1
LÖSNING
The mitigation requires 2 to 4 steps, depending on whether a hypervisor is being used.
  1. Intel CPU microcode was patched with an update released earlier this year. The first version of BIOS with these updates are listed in this HP Security Bulletin: Derivative Side-Channel Analysis Method. Subsequent BIOS firmware versions also contain this patched Intel microcode. Ensure you have updated to the latest BIOS.
  2. Follow the instructions from your operating system provider. For Microsoft Windows, this Security Advisory (in English) has more details. Microsoft has made patches available via Windows Update. Other operating system providers are also releasing updates. Refer to their websites for more information on patches and guidance.
  3. If you are using a hypervisor (e.g. Hyper-V), refer to your hypervisor provider for possible updates.
  4. In some cases, Intel and Microsoft guidance suggests additional mitigation for systems with hyper-threading, see their bulletins for more information. If a BIOS Administrator password has been installed, you will need to know that password.
    For HP commercial platforms in a managed environment this can be performed using either the HP Manageability Integration Kit plug-in to Microsoft SCCM ( https://ftp.hp.com/pub/caps-softpaq/cmit/HPMIK.html) or the HP BIOS Configuration Utility ( https://ftp.hp.com/pub/caps-softpaq/cmit/HP_BCU.html).
    Alternatively, this BIOS setting can be performed by restarting the PC and pressing F10 until the BIOS administration screen appears before the PC boots into the operating system. The exact location and option name changes across generations and types of commercial platforms:
    2015 and later: Navigate to the Advanced tab at the top of the menu and select System Options. Then select Hyperthreading and click to remove the checkmark for this setting.
    2014 Notebooks: Navigate to the Advanced tab at the top of the menu and select Device Configuration. Then select Intel HT Technology and click to remove the checkmark for this setting.
    2014 Desktops: Navigate to the Advanced tab at the top of the menu and select Device Options. Then select Hyperthreading and press the space bar to disable this setting.
    Refer to https://www.intel.com/content/www/us/en/architecture-and-technology/hyper-threading/hyper-threading-technology.html (in English) for more details on Intel hyper-threading technology.
Desktop Workstations
Product Name
HP Z1 G2 Workstation
HP Z1 G2 Workstation (Linux)
HP Z1 G3 Workstation
HP Z1 G3 Workstation (Linux)
HP Z1 Workstation
HP Z1 Workstation (Linux)
HP Z2 Mini G3 Workstation
HP Z2 Mini G3 Workstation (Linux)
HP Z210 Workstation
HP Z210 Workstation (Linux)
HP Z220 Workstation
HP Z220 Workstation (Linux)
HP Z228 Microtower Workstation
HP Z228 Microtower Workstation (Linux)
HP Z230 MT Workstation
HP Z230 MT Workstation (Linux)
HP Z230 SFF Workstation
HP Z230 SFF Workstation (Linux)
HP Z238 Microtower Workstation
HP Z238 Microtower Workstation (Linux)
HP Z240 SFF Workstation
HP Z240 SFF Workstation (Linux)
HP Z240 Tower Workstation
HP Z240 Tower Workstation (Linux)
HP Z4 G4 Core-X Workstation
HP Z4 G4 Core-X Workstation Linux
HP Z4 G4 Workstation (Xeon W)
HP Z4 G4 Workstation (Xeon W) Linux
HP Z420 Workstation (Linux)
HP Z440 Workstation
HP Z440 Workstation (Linux)
HP Z6 G4 Workstation
HP Z6 G4 Workstation (Linux)
HP Z620 Workstation
HP Z620 Workstation (Linux)
HP Z640 Workstation
HP Z640 Workstation (Linux)
HP Z8 G4 Workstation
HP Z8 G4 Workstation (Linux)
HP Z820 Workstation
HP Z820 Workstation (Linux)
HP Z840 Workstation
HP Z840 Workstation (Linux)
HP ZVR Backpack Workstation G1
Consumer PC
Product Name
HP Pavilion 15-au000~15-au099
HP Pavilion 15-au100~15-au199
HP Pavilion 15-au500~15-au599
HP Pavilion 15-au500~15-au699
HP Pavilion 15-bc000~15-bc099
HP Pavilion 15t-bc000
HP Pavilion 17-ab001~ 17-ab099
HP Pavilion 17-ab201~ 17-ab299
HP Pavilion 17-ab301~ 17-ab399
HP Pavilion 17t-ab001
HP Pavilion 17t-ab201
HP Pavilion 17t-ab301
Compaq 14-s000 through 14-s099
Compaq 14-s000 through 14-s099 TouchSmart
Compaq 14-s100 through 14-s199
Compaq 14-s100 through 14-s199 TouchSmart
Compaq 14-s200 through 14-s299
Compaq 14-s200 through 14-s299 TouchSmart
Compaq 14t-s000
Compaq 14t-s000 TouchSmart
Compaq 14t-s100
Compaq 14t-s100 TouchSmart
Compaq 14t-s200
Compaq 15-s000 ~ 15-s099
Compaq 15-s000 ~ 15-s099 TouchSmart
Compaq 15-s100 ~ 15-s199
Compaq 15-s100 ~ 15-s199 TouchSmart
Compaq 15-s200 ~ 15-s299
Compaq 15-s200 ~ 15-s299 TouchSmart
Compaq 15t-s000
Compaq 15t-s000 TouchSmart
Compaq 15t-s100
Compaq 15t-s100 TouchSmart
Compaq 15t-s200
Compaq 15t-s200 TouchSmart
ENVY x2 12-g0xx
HP 460-pxxx
HP 110-xxx
HP 14-ac0XX
HP 14-ac1XX
HP 14-am0XX
HP 14-am0XX
HP 14-am5xx
HP 14-aq0XX
HP 14-aq0XX
HP 14-ar0XX
HP 14-ar0XX
HP 14-cf0xxx
HP 14-ck0xxx
HP 14-df0xxx
HP 14-dg0xxx
HP 14g-cr0xxx
HP 14-ma0xxx
HP 14q-cs0xxx
HP 14-r000 ~ HP14-r099
HP 14-r000 ~ HP14-r099 TouchSmart
HP 14-r100 ~ HP14-r199
HP 14-r100 ~ HP14-r199 TouchSmart
HP 14-r200 ~ HP14-r299
HP 14-r200 ~ HP14-r299 TouchSmart
HP 14s-cf0xxx
HP 14s-cr0xxx
HP 14s-cs0xxx
HP 14t-r000
HP 14t-r000 Touchsmart
HP 14t-r100
HP 14t-r100 Touchsmart
HP 14t-r200
HP 14t-r200 Touchsmart
HP 15-r000 ~ HP15-r099 TouchSmart
HP 15-r100 ~ HP15-r199 TouchSmart
HP 15-r200 ~ HP15-r299 TouchSmart
HP 15t-r000
HP 15t-r000 Touchsmart
HP 15t-r100
HP 15t-r100 Touchsmart
HP 15t-r200
HP 15t-r200 Touchsmart
HP 17-bs000 ~ 17-bs099
HP 17-bs1xx
HP 17-bs500 ~ 17-bs599
HP 17g-br000 ~ 17g-br099
HP 17g-br1xx
HP 17q-bu000 ~ 17q-bu099
HP 17q-bu1xx
HP 17-x000~17-x099, 17-x500 - 17-x599
HP 17-x100~17-x199, 17-x600 - 17-x699
HP 240 G3 Notebook PC
HP 240 G4
HP 240 G5
HP 240 G6 Notebook PC
HP 240 Notebook PC
HP 246 G3 Notebook PC
HP 246 G4
HP 246 G5
HP 246 G6 Notebook PC
HP 246 Notebook PC
HP 250 G1 Notebook PC
HP 250 G3
HP 250 G4
HP 250 G5
HP 250 G6 Notebook PC
HP 251-xxx
HP 256 G3
HP 256 G4
HP 256 G5
HP 256 G6 Notebook PC
HP 258 G6 Notebook PC
HP 390-0xxx
HP 450 Notebook PC
HP All-in-One 19-xxxx
HP All-in-One 20-c4XX
HP All-in-One 20-cxxx
HP All-in-One 20-rxxx
HP All-in-One 20-xxxx
HP All-in-One 22-bxxx
HP All-in-One 22-c0xxx
HP All-in-One 22-xxxx
HP All-in-One 23-rxxx
HP All-in-One 24-exxx
HP All-in-One 24-f0xxx
HP All-in-One 24-gxxx
HP ENVY 13-d000 ~ 13-d099
HP ENVY 13-d100 ~ 13-d199
HP ENVY 13t-d000 ~ 13t-d099
HP ENVY 13t-d100 ~ 13t-d199
HP ENVY 14-j000 ~ 14-j099
HP ENVY 14-j100 ~ 14-j199
HP ENVY 14t-j000
HP ENVY 14t-j100
HP ENVY 14-u000 ~ 14-u099
HP ENVY 14-u100 ~ 14-u199
HP ENVY 14-u200 ~ 14-u299
HP ENVY 15 Notebook PC 15-q1xx
HP ENVY 15-ae000 ~ 15-ae099
HP ENVY 15-ae100 ~ 15-ae199
HP ENVY 15-k000 - 15-k099
HP ENVY 15-k100 - 15-k199
HP ENVY 15-k200 - 15-k299
HP ENVY 15-k300 - 15-k399
HP ENVY 15-q2xx
HP ENVY 15-q6xx
HP ENVY 15t-ae000 ~ 15t-ae099
HP ENVY 15t-ae100 ~ 15t-ae199
HP ENVY 15t-u200 x360
HP ENVY 15t-u300 x360
HP ENVY 15t-u400 x360
HP ENVY 17-j000 ~ 17-j099 Leap Motion SE
HP ENVY 17-j000 ~ 17-j099 Leap Motion TS SE
HP ENVY 17-j000 ~ 17-j099; 17-j100 ~ 17-j199
HP ENVY 17-j100 ~ 17-j199 Leap Motion SE
HP ENVY 17-j100 ~ 17-j199 Leap Motion TS SE
HP ENVY 17-k200 - 17-k299
HP ENVY 17-n000 ~ 17-n099
HP ENVY 17-n100 ~ 17-n199
HP ENVY 17-r100 ~ 17-r199
HP ENVY 17t-j000 Leap Motion SE
HP ENVY 17t-j000 Leap Motion TS SE
HP ENVY 17t-j000; 17t-j100
HP ENVY 17t-j100 Leap Motion SE
HP ENVY 17t-j100 Leap Motion TS SE
HP ENVY 17t-k200
HP ENVY 17t-n000
HP ENVY 17t-n100
HP ENVY 27-b2XX
HP ENVY 700-xxx
HP ENVY 700-xxx
HP ENVY 700-xxx
HP ENVY 700-xxx
HP ENVY 750-xxx
HP ENVY 750-xxx
HP ENVY 750-xxx
HP ENVY 750-xxx
HP ENVY 750-xxx
HP ENVY All-in-One 24-nxxx
HP ENVY All-in-One 27-b0xx
HP ENVY All-in-One 27-b1xx
HP ENVY All-in-One 27-pxxx
HP ENVY All-in-One 34-axxx
HP ENVY Beats All-in-One 23-nxxx
HP ENVY Curved All-in-One 34-b0xx
HP ENVY Desktop 795-0xxx
HP ENVY Laptop 13-ad000 ~ 13-ad099
HP ENVY Laptop 13-ad1xx, 13t-ad100
HP ENVY Laptop 13-ah0xxx
HP ENVY Laptop 17-ae000 ~ 17-ae099
HP ENVY Laptop 17-ae100 ~ 17-ae199
HP ENVY Laptop 17-bw0xxx
HP ENVY Laptop 17m-ae000 ~ 17m-ae099
HP ENVY Laptop 17m-ae100 ~ 17-ae199
HP ENVY Laptop 17m-bw0xxx
HP ENVY Laptop 17t-ae100
HP ENVY m7 Notebook u000~u099
HP ENVY m7 Notebook u100~u199
HP ENVY m7 Notebook u200~u299
HP ENVY m7-k200 - m7-k299
HP ENVY Notebook 13-ab000 ~ 13-ab099
HP ENVY Notebook 15-as000-as099
HP ENVY Notebook 15-as100-as199
HP ENVY Notebook 15-q3xx
HP ENVY Notebook 15t-as00
HP ENVY Notebook 15t-as100
HP ENVY Notebook 17-s000 ~ s099
HP ENVY Notebook 17-s100 ~ s199
HP ENVY Notebook 17t-s000
HP ENVY Notebook 17t-s100
HP ENVY Notebook 17t-u000
HP ENVY Notebook 17t-u100
HP ENVY Notebook 17t-u200
HP ENVY Notebook 17-u000-u099
HP ENVY Notebook 17-u100-u199
HP ENVY Notebook 17-u200-u299
HP ENVY Notebook15-q400~15-q499
HP ENVY Phoenix 810-
HP ENVY Phoenix 810-xxx
HP ENVY Phoenix 850-0xx
HP ENVY Phoenix 850-xxx
HP ENVY Phoenix 860-xxx
HP ENVY Recline TouchSmart All-in-One 23-kxxx
HP ENVY Recline TouchSmart All-in-One 27-kxxx
HP ENVY TouchSmart 17t-j000; 17t-j100
HP ENVY TouchSmart m7t-j000; m7t-j100
HP ENVY TS 17-j000 ~ 17-j099; 17-j100 ~ 17-j199
HP ENVY TS m7-j000 ~ m7-j099; m7-j100 ~ m7-j199
HP ENVY x2 12-g0xx
HP ENVY x2 15-c000 - 15-c099
HP ENVY x2 15t-c0xx
HP ENVY x2 15t-c0xx
HP ENVY x2 Detachable PC 15-c000 ~ c099
HP ENVY x360 15-w000 ~ 15-w099
HP ENVY x360 15-w1XX
HP ENVY x360 Convertible 13-y000 ~ 13-y099
HP ENVY x360 Convertible 15-aq0xx, 15t-aq000
HP ENVY x360 Convertible 15-aq1xx, 15t-aq100
HP ENVY x360 Convertible 15-aq2xx, 15t-aq200
HP ENVY x360 Convertible 15-bp000 ~ 15-bp099
HP ENVY x360 Convertible 15-bp1xx, 15t-bp100, 15m-bp1xx
HP ENVY x360 Convertible 15-cn0xxx
HP ENVY x360 Convertible 15m-bp000 ~ 15m-bp099
HP ENVY x360 Convertible 15m-cn0xxx
HP ENVY x360 Convertible 15-w200 ~ 15-w299
HP ENVY x360 m6-w1xx
HP Laptop 14-bp000 ~ 14-bp099
HP Laptop 14-bp100 ~ 14-bp199
HP Laptop 14-bs0xx, 14-bs5xx, 14-bs7xx, 14g-br0xx, 14q-bu0xx, 14t-bs000
HP Laptop 14-bs1xx, 14-bs6xx, 14t-bs100, 14t-bs600, 14g-br1xx, 14q-bu1xx
HP Laptop 14-bs2xx
HP Laptop 14g-br2xx
HP Laptop 14q-bu2xx
HP Laptop 14s-bc000 ~ 14s-bc099
HP Laptop 14s-bc100 ~ 14s-bc199
HP Laptop 14s-be000 ~ 14s-be099
HP Laptop 14s-be100 ~ 14s-be199
HP Laptop 14s-bp000 ~ 14s-bp099
HP Laptop 14s-bp100 ~ 14s-bp199
HP Laptop 15-bs0xx, 15-bs0xx, 15-bs5xx, 15-bs6xx, 15g-br0xx, 15q-bu0xx, 15-ra0xx
HP Laptop 15-bs1xx, 15-bs7xx, 15t-bs100, 15t-bs700, 15g-br1xx, 15q-bu1xx
HP Laptop 15-bs2xx
HP Laptop 15-da0xxx
HP Laptop 15g-dr0xxx
HP Laptop 15q-ds0xxx
HP Laptop 17-by0xxx
HP Laptop 17g-cr0xxx
HP Laptop 17q-cs0xxx
HP Notebook 15t-ac100
HP Notebook 13-s000 ~ 13-s099
HP Notebook 15-ac0xx & 15-ac5xx (WW/China LFR)
HP Notebook 15-ay000 ~ 15-ay099 (WW/China & India LFR)
HP Notebook 15-ay100 ~ 15-ay199 (WW/China & India LFR)
HP Notebook 15-ay500 to 15-ay599 (WW/China & India LFR)
HP Notebook 15-ay600 - 15-ay699 (WW/China & India LFR)
HP Notebook 15-bd000 ~ 15-bd099 (China & India IT Mall)
HP Notebook 15-bd100 ~ 15-bd199 (China & India IT Mall)
HP Notebook 15-be000 ~ 15-be099 (China & India OLS)
HP Notebook 15-be100 ~ 15-be199 (China & India OLS)
HP Notebook 15-bn000 ~ 15-bn099 (Camo edition)
HP Notebook 15-f0xx
HP Notebook 15-f1xx
HP Notebook 15-f2xx
HP Notebook 15g-ad0XX (China IT Mall)
HP Notebook 15t-ac000
HP Notebook 15t-ay000
HP Notebook 15t-ay100
HP Notebook -aj0XX (China OLS)
HP Notebook15-ac1xx & 15-ac6xx (WW/China LFR)
HP Notebook15g-ad1XX (China IT Mall)
HP Notebook15q-aj1XX (China OLS)
HP OMEN Notebook 15-5100 ~ 5199
HP OMEN Notebook 15-5200 ~ 5299
HP OMEN Pro 15
HP Pavilion 11-n100 x360 ~ Pavilion 11-n199 x360
HP Pavilion 11t x360
HP Pavilion 13-a000 ~ 13-a099 x360
HP Pavilion 13-a100 ~ 13-a199 x360
HP Pavilion 13-a200 ~ 13-a299 x360
HP Pavilion 13-a300 ~ 13-a399 x360
HP Pavilion 13-b000 ~ 13-b099
HP Pavilion 13-b100 ~ 13-b199
HP Pavilion 13-b200 ~ 13-b299
HP Pavilion 13-r000 ~ 13-r099 x2
HP Pavilion 13-r0XX x2
HP Pavilion 13-r100 ~ 13-r199 x2
HP Pavilion 13-r1XX x2
HP Pavilion 13t-a0XX x360
HP Pavilion 13t-a1XX x360
HP Pavilion 13t-a2XX x360
HP Pavilion 13t-a3XX x360
HP Pavilion 13t-b0XX
HP Pavilion 13t-b1XX
HP Pavilion 13t-b2XX
HP Pavilion 14 G1 Notebook PC
HP Pavilion 14-al000~14-al099
HP Pavilion 14-al100~14-al199
HP Pavilion 14t-al000
HP Pavilion 14t-al100
HP Pavilion 14t-v000
HP Pavilion 14t-v100
HP Pavilion 14t-v200
HP Pavilion 14-v000~14-v099
HP Pavilion 14-v100~14-v199
HP Pavilion 14-v200~14-v299
HP pavilion 15-bc400~15-bc499
HP Pavilion 15-p000~15-p099
HP Pavilion 15-p100~15-p199
HP Pavilion 15-p300~15-p399
HP Pavilion 15-p500~15-p599
HP Pavilion 15-p700~15-p799
HP Pavilion 15t-au000
HP Pavilion 15t-au100
HP Pavilion 15t-p000
HP Pavilion 15t-p100
HP Pavilion 15t-p300
HP Pavilion 17-f000~17-f099
HP Pavilion 17-f100~17-f199
HP Pavilion 17-f200~17-f299
HP pavilion 17t-ab400
HP Pavilion 500-xxx
HP Pavilion 500-xxx
HP Pavilion 510-pxxx
HP Pavilion 550-xxx
HP Pavilion 550-xxx
HP Pavilion 560-pxxx
HP Pavilion 570-axxx
HP Pavilion 570-pxxx
HP Pavilion All-in-One 22-axxx
HP Pavilion All-in-One 23-gxxx
HP Pavilion All-in-One 23-pxxx
HP Pavilion All-in-One 23-qxxx
HP Pavilion All-in-One 24-axxx
HP Pavilion All-in-One 24-b3XX
HP Pavilion All-in-One 24-bxxx
HP Pavilion All-in-One 24-qaxxx
HP Pavilion All-in-One 24-qxxx
HP Pavilion All-in-One 24-r1xx
HP Pavilion All-in-One 24-rxxx
HP Pavilion All-in-One 24-Xxxx
HP Pavilion All-in-One 27-axxx
HP Pavilion All-in-One 27-nxxx
HP Pavilion All-in-One 27-qa1xx
HP Pavilion All-in-One 27-r1xx
HP Pavilion All-in-One 27-rxxx
HP Pavilion Desktop 590-a0xxx
HP Pavilion Desktop 590-p0xxx
HP Pavilion Desktop 595-p0xxx
HP Pavilion Gaming 15-cx0xxx
HP Pavilion Gaming Desktop 690-0xxx
HP Pavilion Laptop 14-bf0xx, 14t-bf000
HP Pavilion Laptop 14-bf1xx, 14t-bf100
HP Pavilion Laptop 14-bk000 ~ 14-bk099
HP Pavilion Laptop 14-bk100 ~ 14-bk199
HP Pavilion Laptop 14-ce0xxx
HP Pavilion Laptop 15-cc000 ~ 15-cc099
HP Pavilion Laptop 15-cc1xx, 15t-cc100
HP Pavilion Laptop 15-cc500 ~ 15-cc599
HP Pavilion Laptop 15-cc6xx, 15t-cc600
HP Pavilion Laptop 15-cc700 ~ 15-cc799
HP Pavilion Laptop 15-ck0xx, 15t-ck000
HP Pavilion Laptop 15-cs0xxx
HP Pavilion Laptop 15-cu0xxx
HP Pavilion Mini 300-xxx
HP Pavilion Notebook 14-ab000~ab099
HP Pavilion Notebook 14-ab100~ab199
HP Pavilion Notebook 14t-ab000
HP Pavilion Notebook 14t-ab100
HP Pavilion Notebook 15-ab100~ab199
HP Pavilion Notebook 15-ab200~ab299
HP Pavilion Notebook 15-ab500~ab599
HP Pavilion Notebook 15-ak000~ak099
HP Pavilion Notebook 15-bc200 ~ 15-bc299
HP Pavilion Notebook 15-bc3xx, 15t-bc300
HP Pavilion Notebook 15-bc4XX
HP Pavilion Notebook 15-bj000~bj099
HP Pavilion Notebook 15t-ab000
HP Pavilion Notebook 15t-ab200
HP Pavilion Notebook 15t-ak000
HP Pavilion Notebook 15t-bj000
HP Pavilion Notebook 17-ab4XX
HP Pavilion Notebook 17-g000~g099
HP Pavilion Notebook 17-g100~g199
HP Pavilion Notebook 17t-g000
HP Pavilion Notebook 17t-g100
HP Pavilion Power 580-xxx
HP Pavilion Power Laptop 15-cb000 ~ 15-cb099
HP Pavilion Slimline 400-xxx
HP Pavilion Wave 600-a0xx
HP Pavilion Wave 600-axxx
HP Pavilion x2 Detachable 12-b000 ~ 12-b099 (Intel)
HP Pavilion x2 Detachable 12-b100 ~ 12-b199 (Intel)
HP Pavilion x2 Detachable 12t-b000
HP Pavilion x2 Detachable 12t-b100
HP Pavilion x360 11-ad1xx
HP Pavilion x360 11m-ad1xx
HP Pavilion x360 13-s100 ~13-s199
HP Pavilion x360 14-cd0xxx
HP Pavilion x360 14-dd0xxx
HP Pavilion x360 14m-cd0xxx
HP Pavilion x360 14m-dd0xxx
HP Pavilion x360 14q-cd0xxx
HP Pavilion x360 15-bk000 ~ 15-bk099
HP Pavilion x360 15-bk100 ~ 15-bk199
HP Pavilion x360 Convertible 11 11-k000~11-k099
HP Pavilion x360 Convertible 11 11-k100~11-k199
HP Pavilion x360 Convertible 11-ad000 ~ 11-ad099
HP Pavilion x360 Convertible 11m-ad000 ~ 11m-ad099
HP Pavilion x360 Convertible 14-ba0xx, 14t-ba0xx, 14m-ba0xx, 14t-cc0xx, 14-cc0xx
HP Pavilion x360 Convertible 14-ba1xx, 14t-ba1xx, 14m-ba1xx, 14t-cc1xx, 14-cc1xx
HP Pavilion x360 Convertible 15-br000 ~ 15-br099
HP Pavilion x360 Convertible 15-br1xx, 15t-br100
HP Pavilion x360 Convertible 15-cr0xxx
HP Pavilion x360 m1-u000~m1-u099
HP Pavilion x360 m1-u100~m1-u199
HP Pavilion x360 m3-u100~m3-u199
HP Slim Desktop 290-a0xxx
HP Slim Desktop 290-p0xxx
HP Slimline 260-pxxx
HP Slimline 270-axxx
HP Slimline 270-pxxx
HP Slimline 410-xxx
HP Slimline 450-xxx
HP Slimline 450-xxx
HP Slimline 455-xxx
HP Spectre 15-ch0xx
HP Spectre Laptop 13-af0xx
HP Spectre Notebook 13-v000 ~ 13-v099
HP Spectre Notebook 13-v100 ~ 13-v199
HP Spectre Pro 13 G1
HP Spectre Pro x360 G1
HP Spectre Pro x360 G2
HP Spectre x2 13-SMB Pro Notebook PC
HP Spectre x2 Detachable 12-a000
HP Spectre x2 Detachable 12-c000 ~ 12-c099
HP Spectre x360 Convertible 13 13-w000 ~ 13-w099
HP Spectre x360 Convertible 13-4000 ~ 13-4099
HP Spectre x360 Convertible 13-4100 ~ 13-4199 (Intel)
HP Spectre x360 Convertible 13-4200 ~ 13-4299 (Intel)
HP Spectre x360 Convertible 13-ac000 ~ 13-ac099
HP Spectre x360 Convertible 13-ae0xx, 13-ae5xx, 13t-ae000, 13t-ae500
HP Spectre x360 Convertible 15-ap000 ~ 15-ap099
HP Spectre x360 Convertible 15-bl000 ~ 15-bl099
HP Spectre x360 Convertible 15-bl1xx, 15t-bl100
HP Split 13-r000 ~ 13-r099 x2
HP Split 13-r0XX x2
HP Split 13-r100 ~ 13-r199 x2
HP Split 13-r1XX x2
HP Stream 11 Pro G4 EE
HP Stream 11-ah1xx (Win10S)
HP Stream 11-y1XX
HP Stream 14-cb1xx (Win10S)
HP Stream Laptop 14-ax1XX
HP Stream Mini 200-xxx
HP Stream x360 11-ag1xx (OPP)
HP x360 310 G2 PC
HP x360 330 G1 PC
HP ZBook 15v
OMEN by HP 15-ax000~15-ax099
OMEN by HP 15-ax100~15-ax199
OMEN by HP 15t-ax000
OMEN by HP 15t-ax100
OMEN by HP 870-xxx
OMEN by HP 870-xxx
OMEN by HP 870-xxx
OMEN by HP 870-xxx
OMEN by HP 880-xxx
OMEN by HP 880-xxx
OMEN by HP 880-xxx
OMEN by HP Laptop 15-ax200 ~ 15-ax299
OMEN by HP Laptop 15-ce000 ~ 15-ce099
OMEN by HP Laptop 15-ce1xx
OMEN by HP Laptop 15-dc0xxx
OMEN by HP Laptop 17-an000 ~ 17-an099
OMEN by HP Laptop 17-an1xx
OMEN by HP Laptop 17t-w000
OMEN by HP Laptop 17t-w100
OMEN by HP Laptop 17-w001~ 17-w099
OMEN by HP Laptop 17-w101~ 17-w199
OMEN by HP Laptop 17-w200 ~ 17-w299
OMEN X by HP 900-0xx
OMEN X by HP 900-xxx
OMEN X by HP Laptop 17-ap000 ~ 17-ap099
OMEN X by HP Laptop 17t-ap000
OMEN X by HP P1000-000 P1000-xxx
Pavilion Gaming 790-0xxx
Star WarsTM Special Edition 15-an000-an099
Star WarsTM Special Edition 15t-an000
Commercial PC
Product Name
Compaq 6200 Pro MT/SFF
Compaq 8200 Elite All-in-One PC
Compaq 8200 Elite MT/SFF
HP 20" ProOne 400 G1 AIO Business
HP 260 G1 DM
HP 260 G2 DM
HP 280 G2 Microtower Business PC
HP 280 G2 Small Form Factor PC
HP 280 G3 MT
HP 280 G3 PCI MT
HP 280 G3 PCI MT (India)
HP 280 Pro G3 MT
HP 282 Pro G3 MT
HP 288 Pro G3 MT
HP 290 G1 MT
HP 290 G1 PCI MT
HP 340 G3 Notebook PC
HP 340 G4 Notebook PC
HP 346 G3 Notebook PC
HP 346 G4 Notebook PC
HP 348 G3 Notebook PC
HP 348 G4 Notebook PC
HP 406 Microtower Business PC
HP 8200 Elite Ultra-slim PC, SignagePlayer mp8200
HP Compaq Elite 8300 23 AiO PC
HP Compaq Elite 8300 23 Touch AiO PC
HP Compaq Elite 8300 CMT PC
HP Compaq Elite 8300 USDT PC
HP Compaq Elite 8380 CMT PC
HP Compaq Pro 6300 AiO 21.5 PC
HP Compaq Pro 6300 MT PC
HP Compaq Pro 6300 SFF PC
HP Compaq Pro 6380 MT PC
HP Elite Slice
HP Elite x2 1011 G1 Tablet
HP Elite x2 1012 G1 Tablet
HP Elite x2 1012 G2 Tablet
HP Elite x2 1013 G3 Tablet
HP EliteBook 1030 G1 Notebook PC
HP EliteBook 1040 G2 Notebook PC
HP EliteBook 1040 G4 Notebook PC H
HP EliteBook 1040 G4 Notebook PC U
HP EliteBook 2170p Notebook PC
HP EliteBook 2570p Notebook PC
HP EliteBook 2760p Notebook PC
HP EliteBook 720 G1 Notebook PC
HP EliteBook 720 G2 Notebook PC
HP EliteBook 740 G1 Notebook PC
HP EliteBook 740 G2 Notebook PC
HP EliteBook 750 G1 Notebook PC
HP EliteBook 750 G2 Notebook PC
HP EliteBook 820 G1 Notebook PC
HP EliteBook 820 G2 Notebook PC
HP EliteBook 820 G3 Notebook PC
HP EliteBook 820 G4 Notebook PC
HP EliteBook 828 G3 Notebook PC
HP EliteBook 830 G5 Notebook PC
HP EliteBook 836 G5 Notebook PC
HP EliteBook 840 G1 Notebook PC
HP EliteBook 840 G2 Notebook PC
HP EliteBook 840 G3 Notebook PC
HP EliteBook 840 G4 Notebook PC
HP EliteBook 840 G5 Healthcare Edition Notebook PC
HP EliteBook 840 G5 Notebook PC
HP EliteBook 840r G4 Notebook PC
HP EliteBook 846 G5 Notebook PC
HP EliteBook 846r G4 Notebook PC
HP EliteBook 8470p Notebook PC
HP EliteBook 8470w Mobile Workstation
HP EliteBook 848 G3 Notebook PC
HP EliteBook 848 G4 Notebook PC
HP EliteBook 850 G1 Notebook PC
HP EliteBook 850 G2 Notebook PC
HP EliteBook 850 G3 Notebook PC
HP EliteBook 850 G4 Notebook PC
HP EliteBook 850 G5 Notebook PC
HP EliteBook 8570p Notebook PC
HP EliteBook 8570w Mobile Workstation
HP EliteBook 8770w Mobile Workstation
HP EliteBook Folio 1020 G1 Notebook PC
HP EliteBook Folio 1020 G1 Special Edition Notebook PC
HP EliteBook Folio 1040 G1 Notebook PC
HP EliteBook Folio 1040 G3 Notebook PC
HP EliteBook Folio 9470m Notebook PC
HP EliteBook Folio 9480m Notebook PC
HP EliteBook Folio G1 Notebook PC
HP EliteBook Revolve 810 G1
HP EliteBook Revolve 810 G2
HP EliteBook Revolve 810 G3
HP EliteBook x360 1020 G2 Notebook PC
HP EliteBook x360 1030 G2 Notebook PC
HP EliteBook x360 1030 G3 Notebook PC
HP EliteDesk 700 G1 MT
HP EliteDesk 700 G1 SFF PC
HP EliteDesk 800 G1 DM
HP EliteDesk 800 G1 SFF
HP EliteDesk 800 G1 TWR
HP EliteDesk 800 G1 USDT
HP EliteDesk 800 G2 DM
HP EliteDesk 800 G2 SFF
HP EliteDesk 800 G2 TWR
HP EliteDesk 800 G3 DM
HP EliteDesk 800 G3 SFF
HP EliteDesk 800 G3 TWR
HP EliteDesk 800 G4 DM
HP EliteDesk 800 G4 SFF
HP EliteDesk 800 G4 TWR
HP EliteDesk 880 G1 TWR
HP EliteDesk 880 G3 TWR
HP EliteDesk 880 G4 TWR
HP EliteOne 1000 G1 AiO PC
HP EliteOne 1000 G2 AIO
HP EliteOne 800 G1 21.5-in Non-Touch AiO
HP EliteOne 800 G1 AiO
HP EliteOne 800 G1 Touch AiO
HP EliteOne 800 G1 Touch Retail AiO 23
HP EliteOne 800 G2 AiO PC
HP EliteOne 800 G3 AiO PC
HP EliteOne 800 G3 GPU AiO PC
HP EliteOne 800 G4 AIO
HP Engage One All-in-One System
HP MP9 G2 Retail System
HP MP9 G4 Retail System
HP MP9 Model 9000 Digital Signage Player
HP MP9 Retail System Model 9000
HP mt20 Mobile Thin Client
HP mt21 Mobile Thin Client
HP mt40 Mobile Thin Client
HP Pro x2 612 G1 Tablet
HP Pro x2 612 G2
HP Pro X2 612 G2 Retail Solution with Retail Case
HP ProBook 11 G1 Education Edition
HP ProBook 11 G2 Education Edition
HP ProBook 430 G1 Notebook PC
HP ProBook 430 G2 Notebook PC
HP ProBook 430 G3 Notebook PC
HP ProBook 430 G4 Notebook PC
HP ProBook 430 G5 Notebook PC
HP ProBook 4340s Notebook PC
HP ProBook 4341s Notebook PC
HP ProBook 440 G0 Notebook PC
HP ProBook 440 G1 Notebook PC
HP ProBook 440 G2 Notebook PC
HP ProBook 440 G3 Notebook PC
HP ProBook 440 G4 Notebook PC
HP ProBook 440 G5 Notebook PC
HP ProBook 4440s Notebook PC
HP ProBook 4441s Notebook PC
HP ProBook 450 G0 Notebook PC
HP ProBook 450 G1 Notebook PC
HP ProBook 450 G2 Notebook PC
HP ProBook 450 G3 Notebook PC
HP ProBook 450 G4 Notebook PC
HP ProBook 450 G5 Notebook PC
HP ProBook 4540s Notebook PC
HP ProBook 470 G0 Notebook PC
HP ProBook 470 G1 Notebook PC
HP ProBook 470 G2 Notebook PC
HP ProBook 470 G3 Notebook PC
HP ProBook 470 G4 Notebook PC
HP ProBook 470 G5 Notebook PC
HP ProBook 4740s Notebook PC
HP ProBook 640 G1 Notebook PC
HP ProBook 640 G2 Notebook PC
HP ProBook 640 G3 Notebook PC
HP ProBook 640 G4 Notebook PC
HP ProBook 6470b Notebook PC
HP ProBook 650 G1 Notebook PC
HP ProBook 650 G2 Notebook PC
HP ProBook 650 G3 Notebook PC
HP ProBook 650 G4 Notebook PC
HP ProBook 6570b Notebook PC
HP ProBook x360 11 G1 Education Edition
HP ProBook x360 11 G2 Education Edition
HP ProBook x360 440 G1 Notebook PC
HP ProDesk 400 G1 DM
HP ProDesk 400 G1 MT Business
HP ProDesk 400 G1 SFF
HP ProDesk 400 G2 DM
HP ProDesk 400 G2 MT Business
HP ProDesk 400 G2 SFF Business
HP ProDesk 400 G2.5 SFF
HP ProDesk 400 G3 DM
HP ProDesk 400 G3 SFF
HP ProDesk 400 G4 DM
HP ProDesk 400 G4 MT
HP ProDesk 400 G4 SFF
HP ProDesk 400 G5 MT
HP ProDesk 400 G5 SFF
HP ProDesk 408 G1 MT Business
HP ProDesk 480 G1 MT Business
HP ProDesk 480 G2 MT Business
HP ProDesk 480 G3 SFF
HP ProDesk 480 G5 MT
HP ProDesk 480 G5 SFF
HP ProDesk 490 G1 MT Business
HP ProDesk 490 G2 MT
HP ProDesk 490 G3 SFF
HP ProDesk 498 G1 MT Business
HP ProDesk 498 G2 MT
HP ProDesk 498 G3 SFF
HP ProDesk 600 G1 DM
HP ProDesk 600 G1 SFF
HP ProDesk 600 G1 TWR
HP ProDesk 600 G2 DM
HP ProDesk 600 G2 SFF
HP ProDesk 600 G3 DM
HP ProDesk 600 G3 MT
HP ProDesk 600 G3 SFF
HP ProDesk 600 G4 DM
HP ProDesk 600 G4 MT
HP ProDesk 600 G4 SFF
HP ProDesk 680 G1 TWR
HP ProDesk 680 G3 MT
HP ProDesk 680 G4 MT
HP ProDesk 680 G4 SFF
HP ProOne 400 G1 AiO 19.5" NT
HP ProOne 400 G1 AiO 21.5" T / 23" NT
HP ProOne 400 G2 AiO PC
HP ProOne 400 G3 AiO PC
HP ProOne 600 G1 AiO Business PC
HP ProOne 600 G2 AiO PC
HP ProOne 600 G3 AiO PC
HP ProOne 600 G4 AiO
HP ProOne 600 PC
HP RP3 Retail System Model 3100
HP RP5 Retail System Model 5810
HP RP5800 Retail System
HP RP7 Retail System Model 7100
HP RP7 Retail System Model 7800
HP RP9 G1 Retail System
HP Sprout
HP Sprout Pro
HP Sprout Pro G2
HP t820 Flexible Thin Client
HP ZBook 14 G2 Mobile Workstation
HP ZBook 14 Mobile Workstation
HP ZBook 14u G4 Mobile Workstation
HP ZBook 14u G5 Mobile Workstation
HP ZBook 15 G2 Mobile Workstation
HP ZBook 15 G3 Mobile Workstation
HP ZBook 15 G4 Mobile Workstation
HP ZBook 15 G5 Mobile Workstation
HP ZBook 15 Mobile Workstation
HP ZBook 15u G2 Mobile Workstation
HP ZBook 15u G3 Mobile Workstation
HP ZBook 15u G4 Mobile Workstation
HP ZBook 15u G5 Mobile Workstation
HP ZBook 17 G2 Mobile Workstation
HP ZBook 17 G3 Mobile Workstation
HP ZBook 17 G4 Mobile Workstation
HP ZBook 17 G5 Mobile Workstation
HP ZBook 17 Mobile Workstation
HP ZBook Studio G3 Mobile Workstation
HP ZBook Studio G4 Mobile Workstation
HP ZBook Studio G5 Mobile Workstation
HP ZBook x2 G4 Detachable Workstation
HP Zhan 66 Pro G1
HP Zhan 86 Pro G1 MT
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy.
Support: For issues about implementing the recommendations of this Security Bulletin, visit https://www.hp.com/go/contacthp to learn about your HP support options.
Report: To report a potential security vulnerability with any HP supported product, send email to: hp-security-alert@hp.com.
Subscribe: To initiate a subscription to receive future HP Security Bulletin alerts via email, visit https://www.hp.com/go/alerts.
Security Bulletin Archive: To view released Security Bulletins, search the HP Support Site for "security bulletin".
Software Product Category: The Software Product Category is represented in the title by the two characters following HPSB.
PI
HP Printing and Imaging
HF
HP Hardware and Firmware
GN
HP General Software
It is strongly recommended that security related information being communicated to HP be encrypted using PGP, especially exploit information.
To get the security-alert PGP key, please send an e-mail message as follows:
Subject: get key
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin.HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action.HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin.To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISIONSHISTORIK : 14 August 2018: Version 1. 15 August 2018: Version 2-Fixed broken link.
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
