Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Dokument-ID: c06020986
Version: 1
Advisory: HP ENVY, Spectre and x360 Convertible PCs - HP Command Center Settings Remain in Effect After It Has Been Uninstalled
Utgivningsdatum : 16-May-2018
Last updated : 16-May-2018
DESCRIPTION
After uninstalling HP Command Center, any configuration changes that were made using it will remain in effect. To clear the settings, the app must be reinstalled and setting restored to default.
NOTE: The HP Command Center app allows HP PCs owners to adjust the tradeoff between fan noise, performance, and PC skin temperature. The default mode balances all three but users can also select one of three other modes according to their preference.
OMFATTNING
Information in this document applies to any HP computer that has the HP Command Center app installed. The app comes installed on the following:
Computers:
  • HP ENVY 13 Laptop PC series
  • HP ENVY 13t Laptop PC series CTO
  • HP ENVY 15 Laptop PC series
  • HP ENVY 17 Laptop PC series
  • HP ENVY 17 Laptop PC series CTO
  • HP ENVY 17m Laptop PC series
  • HP ENVY 17t Laptop PC series
  • HP ENVY 13 x360 Convertible PC series
  • HP ENVY 15 x360 Convertible PC series
  • HP ENVY 15m x360 Convertible PC series
  • HP Spectre 13 Laptop PC series
  • HP Spectre 13 x360 Convertible PC series
  • HP Spectre 15 x360 Convertible PC series
  • HP Spectre 15t x360 Convertible PC series CTO
LÖSNING
Avoid the issue by restoring HP Command Center to the default setting (CoolSense = Off) before uninstalling.
To change the setting after HP Command Center has been uninstalled:
  1. Re-install HP Command Center from the Microsoft Store:
  2. Open the HP Command Center.
  3. Select Thermal Profiles.
  4. Click Learn more...
  5. Switch CoolSense to Off.
Hardware platforms affected : HP ENVY - 13-ah0000 CTO, HP ENVY - 13-ah0000nk, HP ENVY - 13-ah0000no, HP ENVY - 13-ah0000np, HP ENVY - 13-ah0000tu, HP ENVY - 13-ah0000tx, HP ENVY - 13-ah0000ur, HP ENVY - 13-ah0001ca, HP ENVY - 13-ah0001la, HP ENVY - 13-ah0001nc, HP ENVY - 13-ah0001nj, HP ENVY - 13-ah0001nk, HP ENVY - 13-ah0001np, HP ENVY - 13-ah0001ns, HP ENVY - 13-ah0001nv, HP ENVY - 13-ah0001tu, HP ENVY - 13-ah0001tx, HP ENVY - 13-ah0001ur, HP ENVY - 13-ah0002ca, HP ENVY - 13-ah0002la, HP ENVY - 13-ah0002nj, HP ENVY - 13-ah0002nk, HP ENVY - 13-ah0002np, HP ENVY - 13-ah0002ns, HP ENVY - 13-ah0002tu, HP ENVY - 13-ah0002tx, HP ENVY - 13-ah0002ur, HP ENVY - 13-ah0003ca, HP ENVY - 13-ah0003la, HP ENVY - 13-ah0003ng, HP ENVY - 13-ah0003ns, HP ENVY - 13-ah0003nv, HP ENVY - 13-ah0003tu, HP ENVY - 13-ah0003tx, HP ENVY - 13-ah0003ur, HP ENVY - 13-ah0004la, HP ENVY - 13-ah0004ng, HP ENVY - 13-ah0004np, HP ENVY - 13-ah0004ns, HP ENVY - 13-ah0004tu, HP ENVY - 13-ah0004tx, HP ENVY - 13-ah0004ur, HP ENVY - 13-ah0005nc, HP ENVY - 13-ah0005ng, HP ENVY - 13-ah0005np, HP ENVY - 13-ah0005ns, HP ENVY - 13-ah0005tu, HP ENVY - 13-ah0005ur, HP ENVY - 13-ah0006nc, HP ENVY - 13-ah0006no, HP ENVY - 13-ah0006np, HP ENVY - 13-ah0006ns, HP ENVY - 13-ah0006nv, HP ENVY - 13-ah0006tu, HP ENVY - 13-ah0006tx, HP ENVY - 13-ah0006ur, HP ENVY - 13-ah0007ns, HP ENVY - 13-ah0007tu, HP ENVY - 13-ah0007tx, HP ENVY - 13-ah0007ur, HP ENVY - 13-ah0008tu, HP ENVY - 13-ah0008tx, HP ENVY - 13-ah0008ur, HP ENVY - 13-ah0009tu, HP ENVY - 13-ah0009tx, HP ENVY - 13-ah0009ur, HP ENVY - 13-ah0010nr, HP ENVY - 13-ah0010tu, HP ENVY - 13-ah0010tx, HP ENVY - 13-ah0011tu, HP ENVY - 13-ah0011tx, HP ENVY - 13-ah0012tu, HP ENVY - 13-ah0012tx, HP ENVY - 13-ah0013tu, HP ENVY - 13-ah0013tx, HP ENVY - 13-ah0014no, HP ENVY - 13-ah0014tu, HP ENVY - 13-ah0014tx, HP ENVY - 13-ah0015no, HP ENVY - 13-ah0015tu, HP ENVY - 13-ah0015tx, HP ENVY - 13-ah0016tu, HP ENVY - 13-ah0016tx, HP ENVY - 13-ah0017tu, HP ENVY - 13-ah0017tx, HP ENVY - 13-ah0018tu, HP ENVY - 13-ah0018tx, HP ENVY - 13-ah0019tu, HP ENVY - 13-ah0019tx, HP ENVY - 13-ah0020tu, HP ENVY - 13-ah0020tx, HP ENVY - 13-ah0021tu, HP ENVY - 13-ah0021tx, HP ENVY - 13-ah0022tu, HP ENVY - 13-ah0022tx, HP ENVY - 13-ah0023tu, HP ENVY - 13-ah0023tx, HP ENVY - 13-ah0024tu, HP ENVY - 13-ah0024tx, HP ENVY - 13-ah0025tu, HP ENVY - 13-ah0025tx, HP ENVY - 13-ah0026tu, HP ENVY - 13-ah0026tx, HP ENVY - 13-ah0027tu, HP ENVY - 13-ah0027tx, HP ENVY - 13-ah0028tu, HP ENVY - 13-ah0028tx, HP ENVY - 13-ah0029tu, HP ENVY - 13-ah0029tx, HP ENVY - 13-ah0030tu, HP ENVY - 13-ah0030tx, HP ENVY - 13-ah0031tu, HP ENVY - 13-ah0031tx, HP ENVY - 13-ah0032tu, HP ENVY - 13-ah0032tx, HP ENVY - 13-ah0033tu, HP ENVY - 13-ah0033tx, HP ENVY - 13-ah0034cl, HP ENVY - 13-ah0034tu, HP ENVY - 13-ah0034tx, HP ENVY - 13-ah0035tu, HP ENVY - 13-ah0035tx, HP ENVY - 13-ah0036tx, HP ENVY - 13-ah0037tx, HP ENVY - 13-ah0038tx, HP ENVY - 13-ah0042nb, HP ENVY - 13-ah0051wm, HP ENVY - 13-ah0052la, HP ENVY - 13-ah0053la, HP ENVY - 13-ah0054la, HP ENVY - 13-ah0075nr, HP ENVY - 13-ah0500nz, HP ENVY - 13-ah0501na, HP ENVY - 13-ah0501sa, HP ENVY - 13-ah0503na, HP ENVY - 13-ah0700nz, HP ENVY - 13-ah1000ne, HP ENVY - 13-ah1000nm, HP ENVY - 13-ah1000ns, HP ENVY - 13-ah1000nw, HP ENVY - 13-ah1000tu, HP ENVY - 13-ah1000tx, HP ENVY - 13-ah1000ur, HP ENVY - 13-ah1001ne, HP ENVY - 13-ah1001ng, HP ENVY - 13-ah1001nn, HP ENVY - 13-ah1001tu, HP ENVY - 13-ah1001tx, HP ENVY - 13-ah1001ur, HP ENVY - 13-ah1002na, HP ENVY - 13-ah1002ne, HP ENVY - 13-ah1002ng, HP ENVY - 13-ah1002tu, HP ENVY - 13-ah1002tx, HP ENVY - 13-ah1002ur, HP ENVY - 13-ah1003na, HP ENVY - 13-ah1003ne, HP ENVY - 13-ah1003no, HP ENVY - 13-ah1003tu, HP ENVY - 13-ah1003tx, HP ENVY - 13-ah1003ur, HP ENVY - 13-ah1004ne, HP ENVY - 13-ah1004ng, HP ENVY - 13-ah1004tu, HP ENVY - 13-ah1004tx, HP ENVY - 13-ah1004ur, HP ENVY - 13-ah1005ne, HP ENVY - 13-ah1005tu, HP ENVY - 13-ah1005tx, HP ENVY - 13-ah1005ur, HP ENVY - 13-ah1006nb, HP ENVY - 13-ah1006ne, HP ENVY - 13-ah1006no, HP ENVY - 13-ah1006tu, HP ENVY - 13-ah1006tx, HP ENVY - 13-ah1006ur, HP ENVY - 13-ah1007nb, HP ENVY - 13-ah1007tu, HP ENVY - 13-ah1007tx, HP ENVY - 13-ah1007ur, HP ENVY - 13-ah1008ng, HP ENVY - 13-ah1008tu, HP ENVY - 13-ah1008tx, HP ENVY - 13-ah1008ur, HP ENVY - 13-ah1009tu, HP ENVY - 13-ah1009tx, HP ENVY - 13-ah1009ur, HP ENVY - 13-ah1010tu, HP ENVY - 13-ah1010tx, HP ENVY - 13-ah1010ur, HP ENVY - 13-ah1011tu, HP ENVY - 13-ah1011tx, HP ENVY - 13-ah1011ur, HP ENVY - 13-ah1012tu, HP ENVY - 13-ah1012tx, HP ENVY - 13-ah1012ur, HP ENVY - 13-ah1013tu, HP ENVY - 13-ah1013tx, HP ENVY - 13-ah1013ur, HP ENVY - 13-ah1014tu, HP ENVY - 13-ah1014tx, HP ENVY - 13-ah1014ur, HP ENVY - 13-ah1015no, HP ENVY - 13-ah1015tu, HP ENVY - 13-ah1015tx, HP ENVY - 13-ah1015ur, HP ENVY - 13-ah1016tu, HP ENVY - 13-ah1016tx, HP ENVY - 13-ah1016ur, HP ENVY - 13-ah1017tu, HP ENVY - 13-ah1017tx, HP ENVY - 13-ah1017ur, HP ENVY - 13-ah1018tu, HP ENVY - 13-ah1018tx, HP ENVY - 13-ah1018ur, HP ENVY - 13-ah1019tu, HP ENVY - 13-ah1019tx, HP ENVY - 13-ah1019ur, HP ENVY - 13-ah1020tu, HP ENVY - 13-ah1020tx, HP ENVY - 13-ah1020ur, HP ENVY - 13-ah1021tu, HP ENVY - 13-ah1021tx, HP ENVY - 13-ah1021ur, HP ENVY - 13-ah1022tu, HP ENVY - 13-ah1022tx, HP ENVY - 13-ah1022ur, HP ENVY - 13-ah1023tu, HP ENVY - 13-ah1023tx, HP ENVY - 13-ah1023ur, HP ENVY - 13-ah1024tu, HP ENVY - 13-ah1024tx, HP ENVY - 13-ah1024ur, HP ENVY - 13-ah1025cl, HP ENVY - 13-ah1025tu, HP ENVY - 13-ah1025tx, HP ENVY - 13-ah1025ur, HP ENVY - 13-ah1026tu, HP ENVY - 13-ah1026tx, HP ENVY - 13-ah1026ur, HP ENVY - 13-ah1027tu, HP ENVY - 13-ah1027tx, HP ENVY - 13-ah1027ur, HP ENVY - 13-ah1028tu, HP ENVY - 13-ah1028tx, HP ENVY - 13-ah1028ur, HP ENVY - 13-ah1029tu, HP ENVY - 13-ah1029tx, HP ENVY - 13-ah1029ur, HP ENVY - 13-ah1030tu, HP ENVY - 13-ah1030tx, HP ENVY - 13-ah1030ur, HP ENVY - 13-ah1031tu, HP ENVY - 13-ah1031tx, HP ENVY - 13-ah1031ur, HP ENVY - 13-ah1032tu, HP ENVY - 13-ah1032tx, HP ENVY - 13-ah1032ur, HP ENVY - 13-ah1033tu, HP ENVY - 13-ah1033tx, HP ENVY - 13-ah1033ur, HP ENVY - 13-ah1034tu, HP ENVY - 13-ah1034tx, HP ENVY - 13-ah1035tu, HP ENVY - 13-ah1035tx, HP ENVY - 13-ah1036tu, HP ENVY - 13-ah1036tx, HP ENVY - 13-ah1037tu, HP ENVY - 13-ah1037tx, HP ENVY - 13-ah1038tu, HP ENVY - 13-ah1039tu, HP ENVY - 13-ah1100nd, HP ENVY - 13-ah1125nd, HP ENVY - 13-ah1500nz, HP ENVY - 13-ah1700nz, HP ENVY - 13-ah1803no, HP ENVY - 13-ah1804no, HP ENVY - 13t-ah000 CTO, HP ENVY - 17-bw0000 CTO, HP ENVY - 17-bw0000nk, HP ENVY - 17-bw0001nc, HP ENVY - 17-bw0001ng, HP ENVY - 17-bw0001no, HP ENVY - 17-bw0001np, HP ENVY - 17-bw0001ns, HP ENVY - 17-bw0001nv, HP ENVY - 17-bw0002ng, HP ENVY - 17-bw0003ca, HP ENVY - 17-bw0003nf, HP ENVY - 17-bw0003ng, HP ENVY - 17-bw0003sa, HP ENVY - 17-bw0004np, HP ENVY - 17-bw0007nc, HP ENVY - 17-bw0008ca, HP ENVY - 17-bw0008nc, HP ENVY - 17-bw0011nr, HP ENVY - 17-bw0015nb, HP ENVY - 17-bw0019nb, HP ENVY - 17-bw0030nb, HP ENVY - 17-bw0200ng, HP ENVY - 17-bw0200nz, HP ENVY - 17-bw0503na, HP ENVY - 17-bw0700nz, HP ENVY - 17m-bw0000 CTO, HP ENVY - 17m-bw0013dx, HP ENVY - 17t-bw000 CTO, HP ENVY 13-ag0000 x360 Convertible PC, HP ENVY 13-ah0000 Laptop PC, HP ENVY 13-ah1000 Laptop PC, HP ENVY 13m-ag0000 x360 Convertible PC, HP ENVY 15-cn0000 x360 Convertible PC, HP ENVY 15-cn1000 x360 Convertible PC, HP ENVY 15-cp0000 x360 Convertible PC, HP ENVY 15m-cn0000 x360 Convertible PC, HP ENVY 15m-cp0000 x360 Convertible PC, HP ENVY 17-bw0000 Laptop PC, HP ENVY 17m-bw0000 Laptop PC, HP ENVY x360 - 13-ag0000 CTO, HP ENVY x360 - 13-ag0000au, HP ENVY x360 - 13-ag0000nk, HP ENVY x360 - 13-ag0000no, HP ENVY x360 - 13-ag0000np, HP ENVY x360 - 13-ag0000ur, HP ENVY x360 - 13-ag0001au, HP ENVY x360 - 13-ag0001la, HP ENVY x360 - 13-ag0001nk, HP ENVY x360 - 13-ag0001np, HP ENVY x360 - 13-ag0001ns, HP ENVY x360 - 13-ag0001nv, HP ENVY x360 - 13-ag0001ur, HP ENVY x360 - 13-ag0002au, HP ENVY x360 - 13-ag0002la, HP ENVY x360 - 13-ag0002ns, HP ENVY x360 - 13-ag0002sa, HP ENVY x360 - 13-ag0002ur, HP ENVY x360 - 13-ag0003au, HP ENVY x360 - 13-ag0003la, HP ENVY x360 - 13-ag0003np, HP ENVY x360 - 13-ag0003sa, HP ENVY x360 - 13-ag0003ur, HP ENVY x360 - 13-ag0004au, HP ENVY x360 - 13-ag0004la, HP ENVY x360 - 13-ag0004nc, HP ENVY x360 - 13-ag0004ur, HP ENVY x360 - 13-ag0005au, HP ENVY x360 - 13-ag0005np, HP ENVY x360 - 13-ag0005nv, HP ENVY x360 - 13-ag0005ur, HP ENVY x360 - 13-ag0006au, HP ENVY x360 - 13-ag0006nc, HP ENVY x360 - 13-ag0007au, HP ENVY x360 - 13-ag0008au, HP ENVY x360 - 13-ag0009au, HP ENVY x360 - 13-ag0010au, HP ENVY x360 - 13-ag0010nc, HP ENVY x360 - 13-ag0011au, HP ENVY x360 - 13-ag0011nn, HP ENVY x360 - 13-ag0012au, HP ENVY x360 - 13-ag0013au, HP ENVY x360 - 13-ag0014au, HP ENVY x360 - 13-ag0015au, HP ENVY x360 - 13-ag0016au, HP ENVY x360 - 13-ag0016nb, HP ENVY x360 - 13-ag0017au, HP ENVY x360 - 13-ag0018au, HP ENVY x360 - 13-ag0019au, HP ENVY x360 - 13-ag0020au, HP ENVY x360 - 13-ag0021au, HP ENVY x360 - 13-ag0022au, HP ENVY x360 - 13-ag0023au, HP ENVY x360 - 13-ag0051la, HP ENVY x360 - 13-ag0052la, HP ENVY x360 - 13-ag0053la, HP ENVY x360 - 13-ag0300nz, HP ENVY x360 - 13-ag0502na, HP ENVY x360 - 13-ag0503na, HP ENVY x360 - 13-ag0600nz0, HP ENVY x360 - 13m-ag0000 CTO, HP ENVY x360 - 13m-ag0001dx, HP ENVY x360 - 13m-ag0002dx, HP ENVY x360 - 13z-ag000 CTO, HP ENVY x360 - 15-cn0000 CTO, HP ENVY x360 - 15-cn0000no, HP ENVY x360 - 15-cn0000np, HP ENVY x360 - 15-cn0000tu, HP ENVY x360 - 15-cn0000tx, HP ENVY x360 - 15-cn0001la, HP ENVY x360 - 15-cn0001nc, HP ENVY x360 - 15-cn0001ng, HP ENVY x360 - 15-cn0001nn, HP ENVY x360 - 15-cn0001no, HP ENVY x360 - 15-cn0001tu, HP ENVY x360 - 15-cn0001tx, HP ENVY x360 - 15-cn0002la, HP ENVY x360 - 15-cn0002nk, HP ENVY x360 - 15-cn0002np, HP ENVY x360 - 15-cn0002tu, HP ENVY x360 - 15-cn0002tx, HP ENVY x360 - 15-cn0003ca, HP ENVY x360 - 15-cn0003ng, HP ENVY x360 - 15-cn0003nk, HP ENVY x360 - 15-cn0003np, HP ENVY x360 - 15-cn0003tu, HP ENVY x360 - 15-cn0003tx, HP ENVY x360 - 15-cn0004ng, HP ENVY x360 - 15-cn0004np, HP ENVY x360 - 15-cn0004tu, HP ENVY x360 - 15-cn0004tx, HP ENVY x360 - 15-cn0005nc, HP ENVY x360 - 15-cn0005ng, HP ENVY x360 - 15-cn0005tx, HP ENVY x360 - 15-cn0006nc, HP ENVY x360 - 15-cn0006tx, HP ENVY x360 - 15-cn0007ng, HP ENVY x360 - 15-cn0007nn, HP ENVY x360 - 15-cn0007tx, HP ENVY x360 - 15-cn0008ca, HP ENVY x360 - 15-cn0008ng, HP ENVY x360 - 15-cn0008tx, HP ENVY x360 - 15-cn0009tx, HP ENVY x360 - 15-cn0010tx, HP ENVY x360 - 15-cn0011tx, HP ENVY x360 - 15-cn0012tx, HP ENVY x360 - 15-cn0013nr, HP ENVY x360 - 15-cn0013tx, HP ENVY x360 - 15-cn0014tx, HP ENVY x360 - 15-cn0015tx, HP ENVY x360 - 15-cn0016tx, HP ENVY x360 - 15-cn0017tx, HP ENVY x360 - 15-cn0018tx, HP ENVY x360 - 15-cn0052la, HP ENVY x360 - 15-cn0100nb, HP ENVY x360 - 15-cn0200ng, HP ENVY x360 - 15-cn0201ng, HP ENVY x360 - 15-cn0503na, HP ENVY x360 - 15-cn0504na, HP ENVY x360 - 15-cn0600nz0, HP ENVY x360 - 15-cn0650nz0, HP ENVY x360 - 15-cn0755nd, HP ENVY x360 - 15-cn0800nz0, HP ENVY x360 - 15-cn0850nz0, HP ENVY x360 - 15-cn1000na, HP ENVY x360 - 15-cn1000nc, HP ENVY x360 - 15-cn1000ne, HP ENVY x360 - 15-cn1000no, HP ENVY x360 - 15-cn1000nw, HP ENVY x360 - 15-cn1000tu, HP ENVY x360 - 15-cn1000tx, HP ENVY x360 - 15-cn1000ur, HP ENVY x360 - 15-cn1001na, HP ENVY x360 - 15-cn1001ne, HP ENVY x360 - 15-cn1001ng, HP ENVY x360 - 15-cn1001nn, HP ENVY x360 - 15-cn1001no, HP ENVY x360 - 15-cn1001nw, HP ENVY x360 - 15-cn1001tx, HP ENVY x360 - 15-cn1001ur, HP ENVY x360 - 15-cn1002na, HP ENVY x360 - 15-cn1002ng, HP ENVY x360 - 15-cn1002no, HP ENVY x360 - 15-cn1002nw, HP ENVY x360 - 15-cn1002tx, HP ENVY x360 - 15-cn1002ur, HP ENVY x360 - 15-cn1003na, HP ENVY x360 - 15-cn1003nw, HP ENVY x360 - 15-cn1003tx, HP ENVY x360 - 15-cn1003ur, HP ENVY x360 - 15-cn1004ng, HP ENVY x360 - 15-cn1004tx, HP ENVY x360 - 15-cn1004ur, HP ENVY x360 - 15-cn1005ng, HP ENVY x360 - 15-cn1005tx, HP ENVY x360 - 15-cn1005ur, HP ENVY x360 - 15-cn1006nb, HP ENVY x360 - 15-cn1006tx, HP ENVY x360 - 15-cn1006ur, HP ENVY x360 - 15-cn1007tx, HP ENVY x360 - 15-cn1007ur, HP ENVY x360 - 15-cn1008tx, HP ENVY x360 - 15-cn1008ur, HP ENVY x360 - 15-cn1009ng, HP ENVY x360 - 15-cn1009ur, HP ENVY x360 - 15-cn1010ur, HP ENVY x360 - 15-cn1011ur, HP ENVY x360 - 15-cn1012ur, HP ENVY x360 - 15-cn1013ur, HP ENVY x360 - 15-cn1016nb, HP ENVY x360 - 15-cn1025nb, HP ENVY x360 - 15-cn1026nb, HP ENVY x360 - 15-cn1100nd, HP ENVY x360 - 15-cn1350nd, HP ENVY x360 - 15-cn1450nz, HP ENVY x360 - 15-cn1600nz, HP ENVY x360 - 15-cn1707nz, HP ENVY x360 - 15-cn1800nz, HP ENVY x360 - 15-cp0000 CTO, HP ENVY x360 - 15-cp0000au, HP ENVY x360 - 15-cp0001au, HP ENVY x360 - 15-cp0002au, HP ENVY x360 - 15-cp0003au, HP ENVY x360 - 15-cp0004au, HP ENVY x360 - 15-cp0005au, HP ENVY x360 - 15-cp0006au, HP ENVY x360 - 15-cp0007au, HP ENVY x360 - 15-cp0008au, HP ENVY x360 - 15-cp0008ca, HP ENVY x360 - 15-cp0009au, HP ENVY x360 - 15-cp0013nr, HP ENVY x360 - 15m-cn0000 CTO, HP ENVY x360 - 15m-cn0011dx, HP ENVY x360 - 15m-cn0012dx, HP ENVY x360 - 15m-cp0000 CTO, HP ENVY x360 - 15m-cp0011dx, HP ENVY x360 - 15m-cp0012dx, HP ENVY x360 - 15t-cn000 CTO, HP ENVY x360 - 15z-cp000 CTO, HP Spectre - 13-af100tu, HP Spectre - 13-af101tu, HP Spectre - 13-af102tu, HP Spectre - 13-af103tu, HP Spectre - 13-af104tu, HP Spectre - 13-af105tu, HP Spectre - 13-af106tu, HP Spectre - 13-af107tu, HP Spectre - 13-af108tu, HP Spectre - 13-af109tu, HP Spectre - 13-af110tu, HP Spectre - 13-af111tu, HP Spectre - 13-af112tu, HP Spectre - 13-af113tu, HP Spectre - 13-af114tu, HP Spectre - 13-af115tu, HP Spectre - 13-af116tu, HP Spectre - 13-af117tu, HP Spectre - 13-af118tu, HP Spectre - 13-af119tu, HP Spectre - 13-af120tu, HP Spectre - 13-af121tu, HP Spectre - 13-af122tu, HP Spectre - 13-af123tu, HP Spectre - 13-af124tu, HP Spectre - 13-af125tu, HP Spectre - 13-af126tu, HP Spectre - 13-af127tu, HP Spectre - 13-af128tu, HP Spectre - 13-af129tu, HP Spectre - 13-af130tu, HP Spectre - 13-af131tu, HP Spectre - 13-af132tu, HP Spectre - 13-af133tu, HP Spectre - 13-af134tu, HP Spectre - 13-af135tu, HP Spectre - 13-af136tu, HP Spectre - 13-af137tu, HP Spectre - 13-af138tu, HP Spectre - 13-af139tu, HP Spectre - 13-af140tu, HP Spectre - 13-af141tu, HP Spectre - 13-af142tu, HP Spectre - 13-af143tu, HP Spectre - 13-af144tu, HP Spectre - 13-af146tu, HP Spectre - 13-af147tu, HP Spectre - 13-af148tu, HP Spectre - 13-af149tu, HP Spectre - 13-af150tu, HP Spectre - 13-af151tu, HP Spectre - 13-af152tu, HP Spectre - 13-af153tu, HP Spectre 13-af100 Laptop PC, HP Spectre 13-ap0000 x360 Convertible PC, HP Spectre 15-df0000 x360 Convertible PC, HP Spectre x360 - 13-ap0000na, HP Spectre x360 - 13-ap0000nb, HP Spectre x360 - 13-ap0000nc, HP Spectre x360 - 13-ap0000nf, HP Spectre x360 - 13-ap0000nh, HP Spectre x360 - 13-ap0000nk, HP Spectre x360 - 13-ap0000nl, HP Spectre x360 - 13-ap0000nn, HP Spectre x360 - 13-ap0000no, HP Spectre x360 - 13-ap0000nq, HP Spectre x360 - 13-ap0000ns, HP Spectre x360 - 13-ap0000nv, HP Spectre x360 - 13-ap0000nw, HP Spectre x360 - 13-ap0000nx, HP Spectre x360 - 13-ap0000sa, HP Spectre x360 - 13-ap0000tu, HP Spectre x360 - 13-ap0000ur, HP Spectre x360 - 13-ap0001la, HP Spectre x360 - 13-ap0001nb, HP Spectre x360 - 13-ap0001nc, HP Spectre x360 - 13-ap0001nf, HP Spectre x360 - 13-ap0001nh, HP Spectre x360 - 13-ap0001nj, HP Spectre x360 - 13-ap0001nk, HP Spectre x360 - 13-ap0001nl, HP Spectre x360 - 13-ap0001nn, HP Spectre x360 - 13-ap0001no, HP Spectre x360 - 13-ap0001np, HP Spectre x360 - 13-ap0001nq, HP Spectre x360 - 13-ap0001ns, HP Spectre x360 - 13-ap0001nu, HP Spectre x360 - 13-ap0001nv, HP Spectre x360 - 13-ap0001nw, HP Spectre x360 - 13-ap0001nx, HP Spectre x360 - 13-ap0001tu, HP Spectre x360 - 13-ap0001ur, HP Spectre x360 - 13-ap0002ne, HP Spectre x360 - 13-ap0002nf, HP Spectre x360 - 13-ap0002nh, HP Spectre x360 - 13-ap0002nj, HP Spectre x360 - 13-ap0002nk, HP Spectre x360 - 13-ap0002nn, HP Spectre x360 - 13-ap0002no, HP Spectre x360 - 13-ap0002np, HP Spectre x360 - 13-ap0002ns, HP Spectre x360 - 13-ap0002nu, HP Spectre x360 - 13-ap0002nw, HP Spectre x360 - 13-ap0002nx, HP Spectre x360 - 13-ap0002sa, HP Spectre x360 - 13-ap0002tu, HP Spectre x360 - 13-ap0002ur, HP Spectre x360 - 13-ap0003nb, HP Spectre x360 - 13-ap0003nf, HP Spectre x360 - 13-ap0003np, HP Spectre x360 - 13-ap0003nq, HP Spectre x360 - 13-ap0003ns, HP Spectre x360 - 13-ap0003nw, HP Spectre x360 - 13-ap0003nx, HP Spectre x360 - 13-ap0003tu, HP Spectre x360 - 13-ap0003ur, HP Spectre x360 - 13-ap0004na, HP Spectre x360 - 13-ap0004ne, HP Spectre x360 - 13-ap0004no, HP Spectre x360 - 13-ap0004np, HP Spectre x360 - 13-ap0004ns, HP Spectre x360 - 13-ap0004nw, HP Spectre x360 - 13-ap0004nx, HP Spectre x360 - 13-ap0004tu, HP Spectre x360 - 13-ap0004ur, HP Spectre x360 - 13-ap0005ne, HP Spectre x360 - 13-ap0005nf, HP Spectre x360 - 13-ap0005nl, HP Spectre x360 - 13-ap0005nn, HP Spectre x360 - 13-ap0005np, HP Spectre x360 - 13-ap0005nw, HP Spectre x360 - 13-ap0005nx, HP Spectre x360 - 13-ap0005tu, HP Spectre x360 - 13-ap0005ur, HP Spectre x360 - 13-ap0006nb, HP Spectre x360 - 13-ap0006nf, HP Spectre x360 - 13-ap0006no, HP Spectre x360 - 13-ap0006nu, HP Spectre x360 - 13-ap0006nw, HP Spectre x360 - 13-ap0006nx, HP Spectre x360 - 13-ap0006tu, HP Spectre x360 - 13-ap0006ur, HP Spectre x360 - 13-ap0007na, HP Spectre x360 - 13-ap0007ne, HP Spectre x360 - 13-ap0007nf, HP Spectre x360 - 13-ap0007nn, HP Spectre x360 - 13-ap0007no, HP Spectre x360 - 13-ap0007nx, HP Spectre x360 - 13-ap0007tu, HP Spectre x360 - 13-ap0007ur, HP Spectre x360 - 13-ap0008ca, HP Spectre x360 - 13-ap0008nc, HP Spectre x360 - 13-ap0008nf, HP Spectre x360 - 13-ap0008nn, HP Spectre x360 - 13-ap0008no, HP Spectre x360 - 13-ap0008nu, HP Spectre x360 - 13-ap0008nx, HP Spectre x360 - 13-ap0008tu, HP Spectre x360 - 13-ap0008ur, HP Spectre x360 - 13-ap0009nc, HP Spectre x360 - 13-ap0009ne, HP Spectre x360 - 13-ap0009nl, HP Spectre x360 - 13-ap0009no, HP Spectre x360 - 13-ap0009nx, HP Spectre x360 - 13-ap0009tu, HP Spectre x360 - 13-ap0009ur, HP Spectre x360 - 13-ap0010ca, HP Spectre x360 - 13-ap0010na, HP Spectre x360 - 13-ap0010ne, HP Spectre x360 - 13-ap0010nf, HP Spectre x360 - 13-ap0010nl, HP Spectre x360 - 13-ap0010no, HP Spectre x360 - 13-ap0010nx, HP Spectre x360 - 13-ap0010tu, HP Spectre x360 - 13-ap0010ur, HP Spectre x360 - 13-ap0011na, HP Spectre x360 - 13-ap0011nc, HP Spectre x360 - 13-ap0011ne, HP Spectre x360 - 13-ap0011nf, HP Spectre x360 - 13-ap0011no, HP Spectre x360 - 13-ap0011ur, HP Spectre x360 - 13-ap0012nc, HP Spectre x360 - 13-ap0012ne, HP Spectre x360 - 13-ap0012nf, HP Spectre x360 - 13-ap0012nn, HP Spectre x360 - 13-ap0012no, HP Spectre x360 - 13-ap0012tu, HP Spectre x360 - 13-ap0012ur, HP Spectre x360 - 13-ap0013dx, HP Spectre x360 - 13-ap0013nb, HP Spectre x360 - 13-ap0013ne, HP Spectre x360 - 13-ap0013nf, HP Spectre x360 - 13-ap0013tu, HP Spectre x360 - 13-ap0013ur, HP Spectre x360 - 13-ap0014na, HP Spectre x360 - 13-ap0014nf, HP Spectre x360 - 13-ap0014tu, HP Spectre x360 - 13-ap0014ur, HP Spectre x360 - 13-ap0015na, HP Spectre x360 - 13-ap0015nf, HP Spectre x360 - 13-ap0015tu, HP Spectre x360 - 13-ap0015ur, HP Spectre x360 - 13-ap0016nf, HP Spectre x360 - 13-ap0016ng, HP Spectre x360 - 13-ap0016tu, HP Spectre x360 - 13-ap0016ur, HP Spectre x360 - 13-ap0017ng, HP Spectre x360 - 13-ap0017tu, HP Spectre x360 - 13-ap0017ur, HP Spectre x360 - 13-ap0018tu, HP Spectre x360 - 13-ap0018ur, HP Spectre x360 - 13-ap0019tu, HP Spectre x360 - 13-ap0019ur, HP Spectre x360 - 13-ap0020tu, HP Spectre x360 - 13-ap0020ur, HP Spectre x360 - 13-ap0021tu, HP Spectre x360 - 13-ap0021ur, HP Spectre x360 - 13-ap0022tu, HP Spectre x360 - 13-ap0023dx, HP Spectre x360 - 13-ap0023tu, HP Spectre x360 - 13-ap0024tu, HP Spectre x360 - 13-ap0025tu, HP Spectre x360 - 13-ap0026tu, HP Spectre x360 - 13-ap0027tu, HP Spectre x360 - 13-ap0028ca, HP Spectre x360 - 13-ap0028tu, HP Spectre x360 - 13-ap0029tu, HP Spectre x360 - 13-ap0030tu, HP Spectre x360 - 13-ap0031tu, HP Spectre x360 - 13-ap0032tu, HP Spectre x360 - 13-ap0033dx, HP Spectre x360 - 13-ap0033tu, HP Spectre x360 - 13-ap0034tu, HP Spectre x360 - 13-ap0035tu, HP Spectre x360 - 13-ap0036tu, HP Spectre x360 - 13-ap0037tu, HP Spectre x360 - 13-ap0038nr, HP Spectre x360 - 13-ap0038tu, HP Spectre x360 - 13-ap0039tu, HP Spectre x360 - 13-ap0040ca, HP Spectre x360 - 13-ap0040tu, HP Spectre x360 - 13-ap0041tu, HP Spectre x360 - 13-ap0042tu, HP Spectre x360 - 13-ap0043dx, HP Spectre x360 - 13-ap0043tu, HP Spectre x360 - 13-ap0044tu, HP Spectre x360 - 13-ap0045tu, HP Spectre x360 - 13-ap0046tu, HP Spectre x360 - 13-ap0047tu, HP Spectre x360 - 13-ap0048tu, HP Spectre x360 - 13-ap0049tu, HP Spectre x360 - 13-ap0050ca, HP Spectre x360 - 13-ap0050ng, HP Spectre x360 - 13-ap0050tu, HP Spectre x360 - 13-ap0051la, HP Spectre x360 - 13-ap0051tu, HP Spectre x360 - 13-ap0052tu, HP Spectre x360 - 13-ap0053tu, HP Spectre x360 - 13-ap0054tu, HP Spectre x360 - 13-ap0055tu, HP Spectre x360 - 13-ap0056tu, HP Spectre x360 - 13-ap0057tu, HP Spectre x360 - 13-ap0058tu, HP Spectre x360 - 13-ap0059tu, HP Spectre x360 - 13-ap0060tu, HP Spectre x360 - 13-ap0061tu, HP Spectre x360 - 13-ap0062tu, HP Spectre x360 - 13-ap0063tu, HP Spectre x360 - 13-ap0064tu, HP Spectre x360 - 13-ap0065tu, HP Spectre x360 - 13-ap0066tu, HP Spectre x360 - 13-ap0067tu, HP Spectre x360 - 13-ap0068ms, HP Spectre x360 - 13-ap0068tu, HP Spectre x360 - 13-ap0069tu, HP Spectre x360 - 13-ap0070tu, HP Spectre x360 - 13-ap0071tu, HP Spectre x360 - 13-ap0072tu, HP Spectre x360 - 13-ap0073tu, HP Spectre x360 - 13-ap0074tu, HP Spectre x360 - 13-ap0075tu, HP Spectre x360 - 13-ap0076tu, HP Spectre x360 - 13-ap0077tu, HP Spectre x360 - 13-ap0078tu, HP Spectre x360 - 13-ap0079tu, HP Spectre x360 - 13-ap0080tu, HP Spectre x360 - 13-ap0081tu, HP Spectre x360 - 13-ap0082tu, HP Spectre x360 - 13-ap0083tu, HP Spectre x360 - 13-ap0084tu, HP Spectre x360 - 13-ap0085tu, HP Spectre x360 - 13-ap0086tu, HP Spectre x360 - 13-ap0087tu, HP Spectre x360 - 13-ap0088tu, HP Spectre x360 - 13-ap0089tu, HP Spectre x360 - 13-ap0090tu, HP Spectre x360 - 13-ap0091tu, HP Spectre x360 - 13-ap0092tu, HP Spectre x360 - 13-ap0093tu, HP Spectre x360 - 13-ap0094tu, HP Spectre x360 - 13-ap0095tu, HP Spectre x360 - 13-ap0096tu, HP Spectre x360 - 13-ap0097tu, HP Spectre x360 - 13-ap0098tu, HP Spectre x360 - 13-ap0099tu, HP Spectre x360 - 13-ap0100nd, HP Spectre x360 - 13-ap0100tu, HP Spectre x360 - 13-ap0101ng, HP Spectre x360 - 13-ap0101tu, HP Spectre x360 - 13-ap0102ng, HP Spectre x360 - 13-ap0102tu, HP Spectre x360 - 13-ap0103tu, HP Spectre x360 - 13-ap0104ng, HP Spectre x360 - 13-ap0104tu, HP Spectre x360 - 13-ap0105tu, HP Spectre x360 - 13-ap0106tu, HP Spectre x360 - 13-ap0107tu, HP Spectre x360 - 13-ap0108tu, HP Spectre x360 - 13-ap0109ng, HP Spectre x360 - 13-ap0109tu, HP Spectre x360 - 13-ap0110ng, HP Spectre x360 - 13-ap0110tu, HP Spectre x360 - 13-ap0111tu, HP Spectre x360 - 13-ap0112tu, HP Spectre x360 - 13-ap0113tu, HP Spectre x360 - 13-ap0114tu, HP Spectre x360 - 13-ap0121ng, HP Spectre x360 - 13-ap0122ng, HP Spectre x360 - 13-ap0180nd, HP Spectre x360 - 13-ap0250nd, HP Spectre x360 - 13-ap0303ng, HP Spectre x360 - 13-ap0304ng, HP Spectre x360 - 13-ap0312ng, HP Spectre x360 - 13-ap0317ng, HP Spectre x360 - 13-ap0400nd, HP Spectre x360 - 13-ap0404nz, HP Spectre x360 - 13-ap0406nz, HP Spectre x360 - 13-ap0409nz, HP Spectre x360 - 13-ap0500nz, HP Spectre x360 - 13-ap0509nz, HP Spectre x360 - 13-ap0550nz, HP Spectre x360 - 13-ap0589na, HP Spectre x360 - 13-ap0590na, HP Spectre x360 - 13-ap0599na, HP Spectre x360 - 13-ap0609nz, HP Spectre x360 - 13-ap0708nz, HP Spectre x360 - 13-ap0800no, HP Spectre x360 - 13-ap0801no, HP Spectre x360 - 13-ap0802no, HP Spectre x360 - 13-ap0803no, HP Spectre x360 - 13-ap0807nz, HP Spectre x360 - 13-ap0809nz, HP Spectre x360 - 13-ap0857nz, HP Spectre x360 - 13-ap0897nz, HP Spectre x360 - 13-ap0900nz, HP Spectre x360 - 13-ap0902nz, HP Spectre x360 - 13-ap0904nz, HP Spectre x360 - 13-ap0950nz, HP Spectre x360 - 13-ap0991nz, HP Spectre x360 - 13-ap0997nb, HP Spectre x360 - 13-ap0998nb, HP Spectre x360 - 13-ap0999nb, HP Spectre x360 - 15-df0000nf, HP Spectre x360 - 15-df0000no, HP Spectre x360 - 15-df0000nv, HP Spectre x360 - 15-df0000nx, HP Spectre x360 - 15-df0000tx, HP Spectre x360 - 15-df0000ur, HP Spectre x360 - 15-df0001nf, HP Spectre x360 - 15-df0001nv, HP Spectre x360 - 15-df0001nx, HP Spectre x360 - 15-df0001tx, HP Spectre x360 - 15-df0002na, HP Spectre x360 - 15-df0002nf, HP Spectre x360 - 15-df0002no, HP Spectre x360 - 15-df0002nx, HP Spectre x360 - 15-df0002tx, HP Spectre x360 - 15-df0003nc, HP Spectre x360 - 15-df0003nx, HP Spectre x360 - 15-df0003tx, HP Spectre x360 - 15-df0004na, HP Spectre x360 - 15-df0004nc, HP Spectre x360 - 15-df0004ne, HP Spectre x360 - 15-df0004tx, HP Spectre x360 - 15-df0005na, HP Spectre x360 - 15-df0005ne, HP Spectre x360 - 15-df0005nf, HP Spectre x360 - 15-df0005no, HP Spectre x360 - 15-df0005tx, HP Spectre x360 - 15-df0006na, HP Spectre x360 - 15-df0006tx, HP Spectre x360 - 15-df0007na, HP Spectre x360 - 15-df0007tx, HP Spectre x360 - 15-df0008ca, HP Spectre x360 - 15-df0008nc, HP Spectre x360 - 15-df0008tx, HP Spectre x360 - 15-df0009nc, HP Spectre x360 - 15-df0009nf, HP Spectre x360 - 15-df0009tx, HP Spectre x360 - 15-df0010ca, HP Spectre x360 - 15-df0010nf, HP Spectre x360 - 15-df0010tx, HP Spectre x360 - 15-df0011na, HP Spectre x360 - 15-df0011nf, HP Spectre x360 - 15-df0011tx, HP Spectre x360 - 15-df0012na, HP Spectre x360 - 15-df0012tx, HP Spectre x360 - 15-df0013dx, HP Spectre x360 - 15-df0013tx, HP Spectre x360 - 15-df0014tx, HP Spectre x360 - 15-df0015tx, HP Spectre x360 - 15-df0015ur, HP Spectre x360 - 15-df0016na, HP Spectre x360 - 15-df0016tx, HP Spectre x360 - 15-df0017tx, HP Spectre x360 - 15-df0018tx, HP Spectre x360 - 15-df0018ur, HP Spectre x360 - 15-df0019tx, HP Spectre x360 - 15-df0020tx, HP Spectre x360 - 15-df0021tx, HP Spectre x360 - 15-df0022nb, HP Spectre x360 - 15-df0023dx, HP Spectre x360 - 15-df0025na, HP Spectre x360 - 15-df0025nb, HP Spectre x360 - 15-df0026na, HP Spectre x360 - 15-df0027nb, HP Spectre x360 - 15-df0028na, HP Spectre x360 - 15-df0028nb, HP Spectre x360 - 15-df0029na, HP Spectre x360 - 15-df0032nb, HP Spectre x360 - 15-df0037ur, HP Spectre x360 - 15-df0038ur, HP Spectre x360 - 15-df0044nb, HP Spectre x360 - 15-df0062nb, HP Spectre x360 - 15-df0065nr, HP Spectre x360 - 15-df0068nr, HP Spectre x360 - 15-df0100nd, HP Spectre x360 - 15-df0104ng, HP Spectre x360 - 15-df0106ng, HP Spectre x360 - 15-df0108ng, HP Spectre x360 - 15-df0126ng, HP Spectre x360 - 15-df0180no, HP Spectre x360 - 15-df0303ng, HP Spectre x360 - 15-df0304ng, HP Spectre x360 - 15-df0306nz, HP Spectre x360 - 15-df0322ng, HP Spectre x360 - 15-df0400nd, HP Spectre x360 - 15-df0400nz, HP Spectre x360 - 15-df0500nd, HP Spectre x360 - 15-df0590na, HP Spectre x360 - 15-df0599na, HP Spectre x360 - 15-df0707nz, HP Spectre x360 - 15-df0709nz, HP Spectre x360 - 15-df0757nz, HP Spectre x360 - 15-df0797nz, HP Spectre x360 - 15-df0800no, HP Spectre x360 - 15-df0800nz, HP Spectre x360 - 15-df0801no, HP Spectre x360 - 15-df0850nz, HP Spectre x360 - 15-df0900nz, HP Spectre x360 - 15-df0950nz, HP Spectre x360 - 15-df0999nb
Operativsystem påverkade : Inte tillämplig
Programvaror påverkade : Inte tillämplig
Korsreferens-ID för support-kommunikation : IA06020986
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
