Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
    Lär dig hur du uppgraderar till Windows 11
    Handbok för uppgradering till Windows 11
  • Respons
Åtgärder
Läser in...
SUPPORT COMMUNICATION- SECURITY BULLETIN
Dokument-ID: c05869091
Version: 15
HPSBHF03573 rev. 15 - Side-Channel Analysis Method
Notice:: The information in this security bulletin should be acted upon as soon as possible.
Utgivningsdatum : 04-Jan-2018
Last updated : 05-Dec-2018
Potential Security Impact:
Elevation of Privilege/Information Disclosure
Source: HP, HP Product Security Response Team (PSRT)
Reported by: Google Project Zero
SÅRBARHETS-SUMMERING
An industry-wide vulnerability, known as side channel analysis method, has been disclosed with modern CPUs using speculative execution. Speculative execution is an important technique to optimize CPU performance. The premise behind speculative execution is that processor instructions are executed before it is determined if these instructions are required.
Researchers have nicknamed these vulnerabilities Spectre and Meltdown. Exploits using this technique could access privileged memory, including the kernel and encrypted secrets. The result could potentially lead to a loss of sensitive information.
Referensnummer
CVE-2017-5715, CVE-2017-5753, CVE-2017-5754, PSR-2017-0185
PROGRAMVARUVERSIONER SOM STÖDS*: ENDAST berörda versioner är listade.
Go to Microsoft Security Advisory ADV180002: Guidance to mitigate speculative execution side-channel vulnerabilities for further details.
See the RESOLUTION section for impacted products.
BAKGRUND
For a PGP signed version of this security bulletin please write to: hp-security-alert@hp.com.
CVSS 3.0 Base Metrics
Reference
Base Vector
Base Score
CVE-2017-5715
CVSS:3.0/AV:L/AC:H/PR:L/UI:N/S:C/C:H/I:N/A:N
5.6
CVE-2017-5753
5.6
CVE-2017-5754
5.6
Google Project Zero and other researchers discovered the initial three vulnerabilities. There are three variants of the vulnerability, which have been grouped by the researchers into two code names as shown in the table below. There are additional side-channel vulnerabilities added for reference that are addressed either in this bulletin or a separate bulletin.
Vulnerability
Patched through
Variant 1
Spectre
Bounds check bypass (CVE-2017-5753)
Requires OS update
Variant 2
Branch target injection (CVE-2017-5715)
Requires OS update
MCU Update (BIOS)
Variant 3
Meltdown
Rogue data cache load (CVE-2017-5754)
Requires OS update
Variant 4
SSB
Speculative Store Bypass (CVE-2018-3639)
Meltdown
Meltdown-PK
Protection key bypass
Requires OS update
Meltdown
Meltdown-BR
Bounds check bypass
Requires OS update
Variant 1
Spectre-PHT
Bounds check bypass - pattern history table
Requires OS update
Variant 1.1
Spectre-PHT
Requires OS update
Variant 2
Spectre-BTB
Requires OS update
MCU Update (BIOS)
Variant 4
Spectre-STL
Net2spec
Spectre-RSB
Return stack buffer
Requires OS update
Variant 1
SplitSpectre
Similar to Spectre variant 1 with attacker gadget
Requires OS update
obs!
  • Variants 1 and 2 may require additional application software and/or driver updates.
  • Variant 3 may require third party driver updates.
HP has been working closely with Intel, AMD, and Microsoft to patch these vulnerabilities. Refer to this Security Bulletin for updates.
In January 2018, Intel provided guidance to stop deployment of the CPU Microcode updates. Intel has since provided new CPU Microcode updates and Intel is recommending that these new updates be deployed (see table below for Softpaqs).
On May 21, 2018, two additional analysis methods were disclosed, similar to the original Spectre and Meltdown vulnerabilities. These were named Variant 3a and Variant 4. HP published a new Security Bulletin to deliver Softpaq mitigations, HPSBHF03584 - Derivative Side-Channel Analysis Method.
On November 13, 2018 researchers disclosed an additional seven variants of Spectre/Meltdown which are also covered by the original Spectre/Meltdown mitigations listed in the Resolution section.
On December 4, 2018, news media reported on an additional research paper from Northeastern University and IBM describing a simpler attack method for Spectre Variant 1, called “SplitSpectre”. This vulnerability is also covered by the original Spectre/Meltdown mitigations listed in the Resolutions section.
At HP we take security very seriously - it is a top issue for our customers and the foundation of trust in our products. We are focused on addressing security issues and providing the required updates to protect our customers.
LÖSNING
The mitigation requires both a processor microcode update and an operating system update. A hypervisor update may also be required.
obs!
The BIOS version published in the affected platform list is the minimum BIOS version that updates the processor microcode update for this vulnerability. Subsequent versions of BIOS also contain the update for this vulnerability.
Step 1: Processor Microcode
It is important to note that HP’s security bulletins list the first BIOS version which includes an update for the vulnerability. Subsequent BIOS versions also include these updates.
Step 2: Operating System
Select your operating system.
Microsoft Windows
  1. Ensure that your anti-virus software as well as your anti-virus definitions are up to date before installing the Microsoft Windows OS update. Contact your anti-virus vendor for more details.
    obs!
    The January 2018 Windows security update will only be offered to devices running supported anti-virus (AV) applications.
    If you do not see the patch available to download from Windows Update, your anti-virus software may need to be updated.
  2. Microsoft Windows OS updates (Windows 7 through Windows 10) are required. Microsoft has made patches/updates available via Windows Update.
  3. Processor microcode updates are being released via BIOS updates. Relevant BIOS updates can be downloaded from the platform list below.
  4. Both the Microsoft Windows OS update and the processor microcode update are required for remediation.
Google Chrome OS
Google Chrome and Google Chrome OS (e.g. Chromebooks) have software updates. Refer to the Google link below for more information.
Other
Software patches from other OS vendors may also be required. Contact your OS vendor for potential software patches.
Step 3: Hypervisors
Hypervisors could also be affected. Check with your hypervisor vendor for potential software patches.
Pending: Softpaq is in progress.
Under investigation: Softpaq is being investigated for feasibility and availability.
Not available: Softpaq not available due to technical or logistical constraints.
Commercial Desktop Workstations
Platform Name
Fixed version
SP #
Link
HP Z1 G3 Workstation
1.18
SP84169
HP Z1 G3 Workstation (Linux)
1.18
SP84538
HP Z2 Mini G3 Workstation
1.67
SP85286
HP Z2 Mini G3 Workstation (Linux)
1.67
SP85288
HP Z238 / Z240 SFF/TWR Workstation
1.67
SP85284
HP Z238 / Z240 SFF/TWR Workstation (Linux)
1.67
SP85285
HP Z4G4 Workstation (Xeon W)
1.11
SP85328
HP Z4G4 Workstation (Xeon W) (Linux)
1.11
SP85329
HP Z6G4 / Z8G4 Workstation
1.28
SP85326
HP Z6G4 / Z8G4 Workstation (Linux)
1.28
SP85327
HP Z VR Backpack G1 Workstation
F.14
SP85663
HP Z1 G2 Workstation
1.48
SP85291
HP Z1 G2 Workstation (Linux)
1.48
SP85292
HP Z1 Workstation
2.75
SP84164
HP Z1 Workstation (Linux)
2.75
SP85584
HP Z210 SFF/TWR Workstation
1.54
SP84727
HP Z220 SFF/TWR Workstation
1.85
SP84173
HP Z220 SFF/TWR Workstation (Linux)
1.85
SP85664
HP Z228/Z230 SFF/TWR Workstation
1.59
SP85289
HP Z228/Z230 SFF/TWR Workstation (Linux)
1.59
SP85290
HP Z400 Workstation
3.61
SP84161
HP Z400 Workstation (Linux)
3.61
SP85650
HP Z420/Z620 Workstation
3.92
SP84163
HP Z420/Z620 Workstation (Linux)
3.92
SP85522
HP Z440 / Z640 / Z840 Workstation
2.41
SP85295
HP Z440 / Z640 / Z840 Workstation (Linux)
2.41
SP85297
HP Z600 Workstation
3.61
SP84160
HP Z600 Workstation (Linux)
3.61
SP85652
HP Z800 Workstation
3.61
SP84159
HP Z800 Workstation
3.61
SP85654
HP Z820 Workstation
3.92
SP84162
HP Z820 Workstation (Linux)
3.92
SP85571
Commercial Desktops, Notebooks, and Retail POS
Platform Name
Fixed version
SP #
Link
HP 285 Pro G1 MT Business PC
Not Available
Not Available
Not Available
HP 260 G1 DM
2.24
SP84970
HP 260 G2 DM
02.11 / 01.11
SP85129
HP 280 G2 Microtower Business PC
A0.41
SP85158
HP 280 G2 Small Form Factor PC (Kabylake)
F.10
SP85156
HP 280 G2 Small Form Factor PC (Skylake)
F15
SP85175
HP 280 G3 MT
2.12
SP85182
HP 280 G3 PCI MT
2.12
SP85182
HP 280 Pro G3 MT
2.12
SP85182
HP 282 Pro G3 MT
2.12
SP85182
HP 285 Pro G2 MT Business PC
A0.21
SP87042
HP 288 Pro G3 MT
2.12
SP85182
HP 290 G1 MT
2.12
SP85182
HP 290 G1 PCI MT
2.12
SP85182
HP 340 G3 Notebook PC
F.37
SP85171
HP 340 G4 Notebook PC (Kabylake)
F.38
SP85167
HP 340 G4 Notebook PC (Skylake)
F.37
SP85172
HP 346 G3 Notebook PC
F.37
SP85171
HP 346 G4 Notebook PC (Kabylake)
F.38
SP85167
HP 346 G4 Notebook PC (Skylake)
F.37
SP85172
HP 348 G3 Notebook PC
F.37
SP85171
HP 348 G4 Notebook PC (Kabylake)
F.38
SP85167
HP 348 G4 Notebook PC (Skylake)
F.37
SP85172
HP 406 Microtower Business PC
F13
SP85159
HP 445/455 G2
1.44
SP87051
HP 445/455 G2
F.68
SP86987
HP 4545s
F.68
SP87050
HP 6360t Mobile Thin Client
F.67
SP85528
HP 645 G1
1.15(1.45)
SP86995
HP 6475b
F.69/F.69
SP86984
HP 725/745 G2
1.46
SP87052
HP 8200 Elite Ultra-slim PC, SignagePlayer mp8200
2.31
SP85518
HP Compaq 6200 Pro MT/SFF
2.31
SP85518
HP Compaq 8200 Elite All-in-One PC
2.18
SP85519
HP Compaq 8200 Elite MT/SFF
2.31
SP85518
HP Compaq Elite 8300 23 AiO PC
3.06
SP85516
HP Compaq Elite 8300 23 Touch AiO PC
3.06
SP85516
HP Compaq Elite 8300 CMT PC
3.06
SP85516
HP Compaq Elite 8300 SFF PC
3.06
SP85516
HP Compaq Elite 8300 USDT PC
3.06
SP85516
HP Compaq Elite 8380 CMT PC
3.06
SP85516
HP Compaq Pro 6300 AiO 21.5 PC
3.06
SP85516
HP Compaq Pro 6300 MT PC
3.06
SP85516
HP Compaq Pro 6300 SFF PC
3.06
SP85516
HP Compaq Pro 6380 MT PC
3.06
SP85516
HP Elite Slice
02.15 / 01.15
sp85437
HP Elite x2 1011 G1 Tablet
1.21
SP85008
HP Elite x2 1012 G1 Tablet
1.29
SP85132
HP Elite x2 1012 G2 Tablet
1.15
SP85029
HP EliteBook 1030 G1 Notebook PC
1.15
SP85134
HP EliteBook 1040 G2 Notebook PC
1.12
SP84994
HP EliteBook 1040 G4 Notebook PC H
1.15
SP85229
HP EliteBook 1040 G4 Notebook PC U
1.15
SP85229
HP EliteBook 2170p Notebook PC
F.68
SP85501
HP EliteBook 2560p
F.66
SP85526
HP EliteBook 2570p Notebook PC
F.69
SP85500
HP EliteBook 2760p
F.66
SP85525
HP EliteBook 645/655 G4
1.16
SP87045
HP EliteBook 720 G1 Notebook PC
1.43
SP84999
HP EliteBook 720 G2 Notebook PC
1.24
SP85000
HP EliteBook 725/745/755 G4
1.12
SP87005
HP EliteBook 740 G1 Notebook PC
1.43
SP84999
HP EliteBook 740 G2 Notebook PC
1.24
SP85000
HP EliteBook 745/755 G3
1.23
SP87012
HP EliteBook 750 G1 Notebook PC
1.43
SP84999
HP EliteBook 750 G2 Notebook PC
1.24
SP85000
HP EliteBook 820 G1 Notebook PC
1.43
SP84999
HP EliteBook 820 G2 Notebook PC
1.24
SP85000
HP EliteBook 820 G3 Notebook PC
1.24
SP85188
HP EliteBook 828 G3 Notebook PC
1.24
SP85188
HP EliteBook 840 G1 Notebook PC
1.43
SP84999
HP EliteBook 840 G2 Notebook PC
1.24
SP85000
HP EliteBook 840 G3 Notebook PC
1.24
SP85188
HP EliteBook 840 G4 Notebook PC
1.15
SP85231
HP EliteBook 8460p Notebook PC
F.67
SP85528
HP EliteBook 8460w Mobile Workstation
F.67
SP85528
HP EliteBook 8470p Notebook PC
F.70
SP85497
HP EliteBook 8470w Mobile Workstation
F.70
SP85497
HP EliteBook 848 G3 Notebook PC
1.24
SP85188
HP EliteBook 848 G4 Notebook PC
1.15
SP85231
HP EliteBook 850 G1 Notebook PC
1.43
SP84999
HP EliteBook 850 G2 Notebook PC
1.24
SP85000
HP EliteBook 850 G3 Notebook PC
1.24
SP85188
HP EliteBook 850 G4 Notebook PC
1.15
SP85231
HP EliteBook 8560p Notebook PC
F.67
SP85528
HP EliteBook 8570p Notebook PC
F.70
SP85497
HP EliteBook 8570w Mobile Workstation
F.67
SP85538
HP EliteBook 8760w Mobile Workstation
F.66
SP85529
HP EliteBook 8770w Mobile Workstation
F.67
SP85538
HP EliteBook Folio 1020 G1 Notebook PC
1.19
SP85006
HP EliteBook Folio 1020 G1 Special Edition Notebook PC
1.19
SP85006
HP EliteBook Folio 1040 G1 Notebook PC
1.39
SP85009
HP EliteBook Folio 1040 G3 Notebook PC
1.21
SP85183
HP EliteBook Folio 9470m Notebook PC
F.69
SP85505
HP EliteBook Folio 9480m Notebook PC
1.42
SP85010
HP EliteBook Folio G1 Notebook PC
1.21
SP85133
HP EliteBook Revolve 810 G1
F.69
SP85508
HP EliteBook Revolve 810 G2
1.4
SP85011
HP EliteBook Revolve 810 G3
1.14
SP84997
HP EliteBook x360 1020 G2 Notebook PC
1.15
SP85263
HP EliteBook x360 1030 G2 Notebook PC
1.15
SP85230
HP EliteDesk 700 G1 SFF PC
2.74
SP85211
HP EliteDesk 700 G1 TWR / SFF
2.74
SP85211
HP EliteDesk 705 G1 DM
2.3
SP87070
HP EliteDesk 705 G1 MT/SFF
2.3
SP87070
HP EliteDesk 705 G2 DM
2.17
SP87013
HP EliteDesk 705 G2 MT/SFF
2.22
SP87009
HP EliteDesk 705 G3 DM
2.13
SP87008
HP EliteDesk 705 G3 MT/SFF
2.15
SP87007
2.13
SP87004
HP EliteDesk 800 G1 DM
2.3
SP85214
HP EliteDesk 800 G1 SFF
2.74
SP85211
HP EliteDesk 800 G1 TWR
2.74
SP85211
HP EliteDesk 800 G1 USDT
2.74
SP85211
HP EliteDesk 800 G2 DM
2.32
SP85145
HP EliteDesk 800 G2 SFF
02.28 / 01.28
SP85142
HP EliteDesk 800 G2 TWR
02.28 / 01.28
SP85142
HP EliteDesk 800 G3 DM
02.15 / 01.15
SP85152
HP EliteDesk 800 G3 SFF
02.15 / 01.15
SP85131
HP EliteDesk 800 G3 TWR
02.15 / 01.15
SP85131
HP EliteDesk 880 G1 TWR
2.74
SP85211
HP EliteDesk 880 G3 TWR
02.15 / 01.15
SP85131
HP EliteOne 1000 G1 AiO PC
02.15 / 01.15
SP85124
HP EliteOne 705 G1 AiO 23" NT
2.3
SP87070
HP EliteOne 705 G2 AiO
2.19
SP87011
HP EliteOne 800 G1 21.5-in Non-Touch AiO
2.74
SP85211
HP EliteOne 800 G1 AiO
2.74
SP85211
HP EliteOne 800 G1 Touch AiO
2.74
SP85211
HP EliteOne 800 G1 Touch Retail AiO 23
2.74
SP85211
HP EliteOne 800 G2 AiO PC
2.28
SP85136
HP EliteOne 800 G3 AiO PC
02.15 / 01.15
SP85125
HP EliteOne 800 G3 GPU AiO PC
02.15 / 01.15
SP85125
HP Elitepad 1000 G2
1.45
SP85122
HP Elitepad 900 G1
Not Impacted
Not Impacted
Not Impacted
HP ElitePOS G1 Retail System
2.15
SP85221
HP MP9 Model 9000 Digital Signage Player
2.3
SP85214
HP MP9G2 Retail System
2.32
SP85145
HP mt20 Mobile Thin Client
1.15
SP85244
HP mt21 Mobile Thin Client
01.02.04
SP85181
HP mt40 Thin Client
F.66
SP85509
HP Mt41 Thin Client
1.45
SP87015
HP mt42 Mobile Thin Client
1.14
SP87049
HP mt43 Mobile Thin Client
1.12
SP87048
HP Pro 6305 SFF/MT
2.77
SP87071
HP Pro Tablet 608 G1
1.18
SP84788
HP Pro Tablet 610 G1
F.13
SP84795
HP Pro Tablet EE 10 G1
1.28
SP84942
HP Pro x2 612 G1 Tablet
1.44
SP85012
HP Pro x2 612 G2
1.15
SP85030
HP ProBook 11 G1 Education Edition
1.13
SP84990
HP ProBook 11 G2 Education Edition
1.13
SP85227
HP ProBook 4230s Notebook PC
F.65
SP85527
HP ProBook 430 G1 Notebook PC
1.45
SP85003
HP ProBook 430 G2 Notebook PC
1.47
SP85004
HP ProBook 430 G3 Notebook PC
1.24
SP85184
HP ProBook 430 G4 Notebook PC
1.15
SP85232
HP ProBook 430 G5 Notebook PC
01.02.04
SP85180
HP ProBook 4330s Notebook PC
F.65
SP85527
HP ProBook 4331s Notebook PC
F.65
SP85527
HP ProBook 4340s Notebook PC
F.66
SP85503
HP ProBook 4341s Notebook PC
F.66
SP85503
HP ProBook 440 G0 Notebook PC
F.68
SP85493
HP ProBook 440 G1 Notebook PC
1.45
SP85005
HP ProBook 440 G2 Notebook PC
1.47
SP85004
HP ProBook 440 G3 Notebook PC
1.24
SP85184
HP ProBook 440 G4 Notebook PC
1.15
SP85232
HP ProBook 440 G5 Notebook PC
01.02.04
SP85180
HP ProBook 4430s Notebook PC
F.65
SP85527
HP ProBook 4431s Notebook PC
F.65
SP85527
HP ProBook 4440s Notebook PC
F.66
SP85503
HP ProBook 4441s Notebook PC
F.66
SP85503
HP ProBook 450 G0 Notebook PC
F.68
SP85493
HP ProBook 450 G1 Notebook PC
1.45
SP85005
HP ProBook 450 G2 Notebook PC
1.47
SP85004
HP ProBook 450 G3 Notebook PC
1.24
SP85184
HP ProBook 450 G4 Notebook PC
1.15
SP85232
HP ProBook 450 G5 Notebook PC
01.02.04
SP85180
HP ProBook 4530s Notebook PC
F.65
SP85527
HP ProBook 4540s Notebook PC
F.66
SP85503
HP ProBook 455 G3
1.19
SP86990
HP ProBook 455 G4
1.12
SP87044
HP ProBook 455 G4
1.12
SP87044
HP ProBook 455 G5
01.01.01
SP87127
HP ProBook 470 G0 Notebook PC
F.68
SP85493
HP ProBook 470 G1 Notebook PC
1.45
SP85005
HP ProBook 470 G2 Notebook PC
1.47
SP85004
HP ProBook 470 G3 Notebook PC
1.24
SP85184
HP ProBook 470 G4 Notebook PC
1.15
SP85232
HP ProBook 470 G5 Notebook PC
01.02.04
SP85180
HP ProBook 4730s Notebook PC
F.65
SP85527
HP ProBook 4740s Notebook PC
F.66
SP85503
HP ProBook 6360b Notebook PC
F.67
SP85528
HP ProBook 640 G1 Notebook PC
1.43
SP85007
HP ProBook 640 G2 Notebook PC
1.17
SP85220
HP ProBook 640 G3 Notebook PC
1.17
SP85242
HP ProBook 645G2/655G2
1.15
SP87014
HP ProBook 6460b Notebook PC
F.67
SP85528
HP ProBook 6470b Notebook PC
F.70
SP85497
HP ProBook 650 G1 Notebook PC
1.43
SP85007
HP ProBook 650 G2 Notebook PC
1.17
SP85220
HP ProBook 650 G3 Notebook PC
1.17
SP85242
HP ProBook 6560b Notebook PC
F.67
SP85528
HP ProBook 6570b Notebook PC
F.70
SP85497
HP ProBook x360 11 G1 Education Edition
1.12
SP84470
HP ProBook x360 11 G2 Education Edition
1.15
SP85190
HP ProDesk 400 G1 DM
2.23
SP84996
HP ProDesk 400 G1 SFF
2.52
SP85212
HP ProDesk 400 G2 SFF
2.52
SP85212
HP ProDesk 400 G2 DM
2.19
SP85150
HP ProDesk 400 G2 MT
2.52
SP85212
HP ProDesk 400 G2.5 SFF
2.22
SP85553
HP ProDesk 400 G3 DM
02.15 / 01.15
SP85154
HP ProDesk 400 G3 SFF
2.19
SP85147
HP ProDesk 400 G4 MT
02.15 / 01.15
SP85138
HP ProDesk 400 G4 SFF
02.15 / 01.15
SP85140
HP ProDesk 405 G1 MT
Not Available
Not Available
Not Available
HP ProDesk 485 G1 MT
Not Available
Not Available
Not Available
HP ProDesk 405/485 G2 MT
2.27
SP87080
HP ProDesk 480 G3 SFF
2.19
SP85147
HP ProDesk 480 G4 MT
02.15 / 01.15
SP85138
HP ProDesk 490 / 400 / 480 G1/G2 MT
2.52
SP85212
HP ProDesk 490 G3 SFF
2.19
SP85149
HP ProDesk 490/498 G2 MT
2.27
SP85510
HP ProDesk 498 G3 SFF
2.19
SP85149
HP ProDesk 600 G1 DM
2.3
SP85214
HP ProDesk 600 G1 SFF
2.74
SP85211
HP ProDesk 600 G1 TWR
2.74
SP85211
HP ProDesk 600 G2 DM
2.27
SP85148
HP ProDesk 600 G2 SFF
02.28 / 01.28
SP85144
HP ProDesk 600 G3 DM
02.15 / 01.15
SP85153
HP ProDesk 600 G3 MT
02.15 / 01.15
SP85135
HP ProDesk 600 G3 SFF
02.15 / 01.15
SP85139
HP ProDesk 680 G3 MT
02.15 / 01.15
SP85135
HP ProOne 400 G1 AiO 19.5" NT
2.27
SP85213
HP ProOne 400 G1 AiO 21.5" T / 23" NT
2.27
SP85213
HP ProOne 400 G2 AiO PC
2.2
SP85143
HP ProOne 400 G3 AiO PC
02.15 / 01.15
SP85130
HP ProOne 600 G1 AiO Business PC
2.74
SP85211
HP ProOne 600 G2 AiO PC
2.26
SP85141
HP ProOne 600 G3 AiO PC
02.15 / 01.15
SP85128
HP ProOne 600 PC
02.15 / 01.15
SP85128
HP RP2 Retail System
V02.17
SP84789
HP RP3 Retail System Model 3100
2.13
SP85517
HP RP5 Retail System Model 5810
2.4
SP85210
HP RP5800 Retail System
2.28
SP85521
HP RP7 Retail System Model 7100
2.13
SP85517
HP RP7 Retail System Model 7800
3.04
SP85523
HP RP9 G1 Retail System Model 9015 & 9018
2.17
SP85222
HP RP9 G1 Retail System Model 9115 & 9118
2.18
SP85251
HP t628 Thin Client
1.07
SP84520
HP t820 Flexible Thin Client
2.74
SP85211
HP x360 310 G2 PC
F.55
SP85042
HP ZBook 14 G2 Mobile Workstation
1.24
SP85000
HP ZBook 14 Mobile Workstation
1.43
SP84999
HP ZBook 14u G4 Mobile Workstation
1.15
SP85231
HP ZBook 15 G2 Mobile Workstation
1.2
SP85086
HP ZBook 15 G3 Mobile Workstation
1.23
SP85207
HP ZBook 15 G4 Mobile Workstation
1.17
SP85240
HP ZBook 15 Mobile Workstation
1.4
SP85126
HP ZBook 15u G2 Mobile Workstation
1.24
SP85000
HP ZBook 15u G3 Mobile Workstation
1.24
SP85188
HP ZBook 15u G4 Mobile Workstation
1.15
SP85231
HP ZBook 17 G2 Mobile Workstation
1.2
SP85086
HP ZBook 17 G3 Mobile Workstation
1.23
SP85207
HP ZBook 17 G4 Mobile Workstation
1.17
SP85240
HP ZBook 17 Mobile Workstation
1.4
SP85126
HP ZBook Studio G3 Mobile Workstation
1.25
SP85219
HP ZBook Studio G4 Mobile Workstation
1.17
SP85241
HP ZBook x2 G4 Detachable Workstation
1.05
SP85252
HP Zhan 66 Pro G1 Notebook PC
01.02.09
SP85146
HP Zhan 86 Pro G1 MT
2.12
SP85182
Consumer Desktops and Notebooks
Product Name
Fixed Version(s)
SoftPaq#
Softpaq Link
HP Pavilion 15-au000~15-au099
F.46
SP85678
HP Pavilion 15-au100~15-au199
F.46
SP85678
HP Pavilion 15-au500~15-au599
F.46
SP85678
HP Pavilion 15-au500~15-au699
F.46
SP85678
HP Pavilion 15-bc000~15-bc099
F.46
SP85678
HP Pavilion 15t-au000
F.46
SP85678
HP Pavilion 15t-au100
F.46
SP85678
HP Pavilion 15t-bc000
F.46
SP85678
HP Pavilion 17-ab001~ 17-ab099
F.46
SP85678
HP Pavilion 17-ab201~ 17-ab299
F.46
SP85678
HP Pavilion 17-ab301~ 17-ab399
F.60
SP85641
HP Pavilion 17t-ab001
F.46
SP85678
HP Pavilion 17t-ab201
F.46
SP85678
HP Pavilion 17t-ab301
F.60
SP85641
Compaq 14-s000 thru 14-s099 (Intel)
F.44
SP86793
Compaq 14-s000 thru 14-s099 TouchSmart (Intel)
F.44
SP86793
Compaq 14-s100 thru 14-s199 (Intel)
F.44
SP86793
Compaq 14-s100 thru 14-s199 TouchSmart (Intel)
F.44
SP86793
Compaq 14-s200 thru 14-s299 (Intel)
F.44
SP86793
Compaq 14-s200 thru 14-s299 TouchSmart (Intel)
F.44
SP86793
Compaq 14t-s000 (Intel)
F.44
SP86793
Compaq 14t-s000 TouchSmart (Intel)
F.44
SP86793
F.44
SP86793
Compaq 14t-s100 (Intel)
F.44
SP86793
Compaq 14t-s100 TouchSmart (Intel)
F.44
SP86793
Compaq 14t-s200 (Intel)
F.44
SP86793
Compaq 15-s000 ~ 15-s099 (Intel)
F.44
SP86793
Compaq 15-s000 ~ 15-s099 TouchSmart (Intel)
F.44
SP86793
Compaq 15-s100 ~ 15-s199 (Intel)
F.44
SP86793
Compaq 15-s100 ~ 15-s199 TouchSmart (Intel)
F.44
SP86793
Compaq 15-s200 ~ 15-s299 (Intel)
F.44
SP86793
Compaq 15-s200 ~ 15-s299 TouchSmart (Intel)
F.44
SP86793
Compaq 15t-s000 (Intel)
F.44
SP86793
Compaq 15t-s000 TouchSmart (Intel)
F.44
SP86793
Compaq 15t-s100 (Intel)
F.44
SP86793
Compaq 15t-s100 TouchSmart (Intel)
F.44
SP86793
Compaq 15t-s200 (Intel)
F.44
SP86793
Compaq 15t-s200 TouchSmart (Intel)
F.44
SP86793
Compaq All-in-One 18-xxxx (ROM Family SSID 2B0C)
80.21
SP85265
ENVY x2 12-g0xx
F.05
SP85567
HP 460-axxx (ROM Family SSID 821D)
F.33
SP85053
HP 460-pxxx (ROM Family SSID 81B4)
F.34
SP84270
HP 1000-1300 ~ 1000-1399
F.49
SP86811
HP 10-p0XX
F.31
sp84890
HP 110-xxx (ROM Family SSID 2AFB)
Not Available
Not Available
Not Available
HP 110-xxx (ROM Family SSID 2B28)
80.14
SP85267
HP 110-xxx (ROM Family SSID 2B2C)
A0.17
SP84453
HP 14-ac0XX
F.26
SP85608
HP 14-ac1XX
F.26
SP85608
HP 14-am0XX
F.32
SP85611
HP 14-am0XX
F.32
SP85611
HP 14-am5xx
F.32
SP85611
HP 14-aq0XX
F.32
SP85611
HP 14-aq0XX
F.32
SP85611
HP 14-ar0XX
F.32
SP85611
HP 14-ar0XX
F.32
SP85611
HP 14-r000 ~ HP14-r099 (Intel)
F.44
SP86793
HP 14-r000 ~ HP14-r099 TouchSmart (Intel)
F.44
SP86793
HP 14-r100 ~ HP14-r199 (Intel)
F.44
SP86793
HP 14-r100 ~ HP14-r199 TouchSmart (Intel)
F.44
SP86793
HP 14-r200 ~ HP14-r299 (Intel)
F.44
SP86793
HP 14-r200 ~ HP14-r299 TouchSmart (Intel)
F.44
SP86793
HP 14t-r000 (Intel)
F.44
SP86793
HP 14t-r000 Touchsmart (Intel)
F.44
SP86793
HP 14t-r100 (Intel)
F.44
SP86793
HP 14t-r100 Touchsmart (Intel)
F.44
SP86793
HP 14t-r200 (Intel)
F.44
SP86793
HP 14t-r200 Touchsmart (Intel)
F.44
SP86793
HP 15-r000 ~ HP15-r099
F.44
SP86793
HP 15-r000 ~ HP15-r099 TouchSmart
F.44
SP86793
HP 15-r100 ~ HP15-r199
F.44
SP86793
HP 15-r100 ~ HP15-r199 TouchSmart
F.44
SP86793
HP 15-r200 ~ HP15-r299
F.44
SP86793
HP 15-r200 ~ HP15-r299 TouchSmart
F.44
SP86793
HP 15t-r000
F.44
SP86793
HP 15t-r000 Touchsmart
F.44
SP86793
HP 15t-r100
F.44
SP86793
HP 15t-r100 Touchsmart
F.44
SP86793
HP 15t-r200
F.44
SP86793
HP 15t-r200 Touchsmart
F.44
SP86793
HP 17-bs000 ~ 17-bs099
F.17
SP86709
HP 17-bs1xx
F.17
SP86709
HP 17-bs500 ~ 17-bs599
F.17
SP86709
HP 17g-br000 ~ 17g-br099
F.17
SP86709
HP 17g-br1xx
F.17
SP86709
HP 17q-bu000 ~ 17q-bu099
F.17
SP86709
HP 17q-bu1xx
F.17
SP86709
HP 17-x000~17-x099, 17-x500 - 17-x599
F.29
SP85555
HP 17-x100~17-x199, 17-x600 - 17-x699
F.29
SP85555
HP 240 G3 Notebook PC
F.44
SP86793
HP 240 G4
F.26
SP85608
HP 240 G5
F.32
SP85611
HP 240 G6 Notebook PC
F.32
SP85677
HP 240 Notebook PC
F.49
SP86811
HP 246 G3 Notebook PC
F.44
SP86793
HP 246 G4
F.26
SP85608
HP 246 G5
F.32
SP85611
HP 246 G6 Notebook PC
F.32
SP85677
HP 246 Notebook PC
F.06
SP86813
HP 250 G1 Notebook PC
F.49
SP86811
HP 250 G3
F.44
SP86793
HP 250 G4
F.25
SP86779
HP 250 G5
F.41
SP85638
HP 250 G6 Notebook PC
F.35
SP85676
HP 251-axxx (ROM Family SSID 2B28)
80.14
SP85267
HP 251-axxx (ROM Family SSID 2B46)
A0.23
SP85074
HP 251-xxx (ROM Family SSID 2B2C)
A0.17
SP84453
HP 251-xxx (ROM Family SSID 2B46)
A0.23
SP85074
HP 256 G3
F.44
SP86793
HP 256 G4
F.25
SP86779
HP 256 G5
F.41
SP85638
HP 256 G6 Notebook PC
F.35
SP85676
HP 258 G6 Notebook PC
F.35
SP85676
HP 450 Notebook PC
F.49
SP86811
HP All-in-One 19-xxxx (ROM Family SSID 2B12)
Not Available
Not Available
Not Available
HP All-in-One 19-xxxx (ROM Family SSID 2B15)
Not Available
Not Available
Not Available
HP All-in-One 20-cxxx (ROM Family SSID 81BA)
F.44
SP85643
HP All-in-One 20-cxxx (ROM Family SSID 81BB)
F.41
SP84899
HP All-in-One 20-cxxx (ROM Family SSID 82DD)
F.32
SP85646
HP All-in-One 20-cxxx (ROM Family SSID 8304)
F.17
SP84454
HP All-in-One 20-exxx (ROM Family SSID 2B5A)
A0.10
SP84302
HP All-in-One 20-rxxx (ROM Family SSID 2B3C)
A0.10
SP87680
HP All-in-One 20-rxxx (ROM Family SSID 2B3D)
A0.08
SP86703
HP All-in-One 20-rxxx (ROM Family SSID 2B40)
A0.16
SP85264
HP All-in-One 20-xxxx (ROM Family SSID 2B12)
Not Available
Not Available
Not Available
HP All-in-One 20-xxxx (ROM Family SSID 2B15)
Not Available
Not Available
Not Available
HP All-in-One 22-bxxx (ROM Family SSID 81BA)
F.44
SP85643
HP All-in-One 22-bxxx (ROM Family SSID 81BB)
F.41
SP84899
HP All-in-One 22-bxxx (ROM Family SSID 82DD)
F.32
SP85646
HP All-in-One 22-bxxx (ROM Family SSID 8304)
F.17
SP84454
HP All-in-One 22-xxxx (ROM Family SSID 2B3C)
A0.10
SP87680
HP All-in-One 22-xxxx (ROM Family SSID 2B40)
A0.16
SP85264
HP All-in-One 23-rxxx (ROM Family SSID 2B3C)
A0.10
SP87680
HP All-in-One 23-rxxx (ROM Family SSID 2B3D)
A0.08
SP86703
HP All-in-One 23-rxxx (ROM Family SSID 2B40)
A0.16
SP85264
HP All-in-One 24-exxx (ROM Family SSID 81BA)
F.44
SP85643
HP All-in-One 24-exxx (ROM Family SSID 81BB)
F.41
SP84899
HP All-in-One 24-exxx (ROM Family SSID 82DD)
F.32
SP85646
HP All-in-One 24-exxx (ROM Family SSID 8304)
F.17
SP84454
HP All-in-One 24-gxxx (ROM Family SSID 81BA)
F.44
SP85643
HP All-in-One 24-gxxx (ROM Family SSID 81BB)
F.41
SP84899
HP All-in-One 24-gxxx (ROM Family SSID 82DD)
F.32
SP85646
HP All-in-One 24-gxxx (ROM Family SSID 8304)
F.17
SP84454
HP Envy 13-d000 ~ 13-d099
F.49
SP85682
HP Envy 13-d100 ~ 13-d199
F.49
SP85678
HP Envy 13t-d000 ~ 13t-d099
F.49
SP85682
HP Envy 13t-d100 ~ 13t-d199
F.49
SP85678
HP Envy 14-j000 ~ 14-j099
F.49
SP85682
HP Envy 14-j100 ~ 14-j199
F.49
SP85682
HP Envy 14t-j000
F.49
SP85682
HP Envy 14t-j100
F.49
SP85682
HP Envy 14-u000 ~ 14-u099
F.55
SP85681
HP Envy 14-u100 ~ 14-u199
F.55
SP85681
HP Envy 14-u200 ~ 14-u299
F.55
SP85681
HP Envy 15 Notebook PC 15-q1xx
F.29
SP85637
HP Envy 15-ae000 ~ 15-ae099
F.49
SP85682
HP Envy 15-ae100 ~ 15-ae199
F.49
SP85682
HP Envy 15-j000 ~ 15-j099; 15-j100 ~ 15-j199
F.71
SP86702
HP Envy 15-k000 - 15-k099
F.55
SP85681
HP Envy 15-k100 - 15-k199
F.55
SP85681
HP Envy 15-k200 - 15-k299
F.55
SP85681
HP Envy 15-k300 - 15-k399
F.55
SP85681
HP Envy 15-q2xx
F.29
SP85637
HP Envy 15-q6xx
F.38
Sp86746
HP Envy 15t-ae000 ~ 15t-ae099
F.49
SP85682
HP Envy 15t-ae100 ~ 15t-ae199
F.49
SP85682
HP ENVY 15t-j000; 15t-j100
F.71
SP86702
HP ENVY 15t-u000 x360
F.40
SP85580
HP ENVY 15t-u100 x360
F.40
SP85580
HP ENVY 15t-u200 x360
F.40
SP85580
HP ENVY 15t-u300 x360
F.07
SP85659
HP ENVY 15t-u400 x360
F.1D
SP86783
HP ENVY 17-j000 ~ 17-j099 Leap Motion SE
F.71
SP86702
HP ENVY 17-j000 ~ 17-j099 Leap Motion TS SE
F.71
SP86702
HP Envy 17-j000 ~ 17-j099; 17-j100 ~ 17-j199
F.71
SP86702
HP ENVY 17-j100 ~ 17-j199 Leap Motion SE
F.71
SP86702
HP ENVY 17-j100 ~ 17-j199 Leap Motion TS SE
F.71
SP86702
HP Envy 17-k000 - 17-k099
F.55
SP85681
HP Envy 17-k100 - 17-k199
F.55
SP85681
HP Envy 17-k200 - 17-k299
F.55
SP85681
HP Envy 17-k300 - 17-k399
F.55
SP85681
HP Envy 17-n000 ~ 17-n099
F.49
SP85682
HP Envy 17-n100 ~ 17-n199
F.49
SP85682
HP Envy 17-r100 ~ 17-r199
F.49
SP85682
HP ENVY 17t-j000 Leap Motion SE
F.71
SP86702
HP ENVY 17t-j000 Leap Motion TS SE
F.71
SP86702
HP ENVY 17t-j000; 17t-j100
F.71
SP86702
HP ENVY 17t-j100 Leap Motion SE
F.71
SP86702
HP ENVY 17t-j100 Leap Motion TS SE
F.71
SP86702
HP Envy 17t-k000
F.55
SP85681
HP Envy 17t-k100
F.55
SP85681
HP Envy 17t-k200
F.55
SP85681
HP Envy 17t-k300
F.55
SP85681
HP Envy 17t-n000
F.49
SP85682
HP Envy 17t-n100
F.49
SP85682
HP ENVY 700-0xx PC (ROM Family SSID 2ACE)
Not Available
Not Available
Not Available
HP ENVY 700-xxx (ROM Family SSID 2AF3)
Not Available
Not Available
Not Available
HP ENVY 700-xxx (ROM Family SSID 2AF7)
Not Available
Not Available
Not Available
HP ENVY 700-xxx (ROM Family SSID 2B2C)
A0.17
SP84453
HP ENVY 700-xxx (ROM Family SSID 2B36)
Not Available
Not Available
Not Available
HP ENVY 750-xxx (ROM Family SSID 2B4B)
A0.59
SP85454
HP ENVY 750-xxx (ROM Family SSID 828A)
F.42
SP85453
HP ENVY 750-xxx (ROM Family SSID 82F1)
F.24
SP86741
HP ENVY 750-xxx (ROM Family SSID 83C1)
F.13
SP86911
HP ENVY All-in-One 24-nxxx (ROM Family SSID 2B3E)
A0.13
SP86876
HP ENVY All-in-One 27-b0xx (ROM Family SSID 8269)
F.16
SP84341
HP ENVY All-in-One 27-b1xx (ROM Family SSID 82F3)
F.24
SP85612
HP ENVY All-in-One 27-pxxx (ROM Family SSID 2B3E)
A0.13
SP86876
HP ENVY All-in-One 34-axxx (ROM Family SSID 2B4C)
A0.12
SP85537
HP ENVY Beats All-in-One 23-nxxx (ROM Family SSID 2B1C)
80.15
SP85634
HP ENVY Curved All-in-One 34-b0xx (ROM Family SSID 826A)
F.24
SP85613
HP ENVY h8-XXXX Desktop (ROM Family SSID 2ACE)
Not Available
Not Available
Not Available
HP ENVY Laptop 13-ad000 ~ 13-ad099
F.22
SP85574
HP ENVY Laptop 13-ad1xx, 13t-ad100
F.22
SP85574
HP ENVY Laptop 17-ae000 ~ 17-ae099
F.22
SP85575
HP ENVY Laptop 17-ae100 ~ 17-ae199
F.22
SP85575
HP ENVY Laptop 17m-ae000 ~ 17m-ae099
F.22
SP85575
HP ENVY Laptop 17m-ae100 ~ 17-ae199
F.22
SP85575
HP ENVY Laptop 17t-ae100
F.22
SP85575
HP ENVY m7 Notebook u000~u099
F.31
SP85381
HP ENVY m7 Notebook u100~u199
F.54
SP85512
HP ENVY m7 Notebook u200~u299
F.14
SP85513
HP Envy m7-k000 - m7-k099
F.55
SP85681
HP Envy m7-k100 - m7-k199
F.55
SP85681
HP Envy m7-k200 - m7-k299
F.55
SP85681
HP Envy m7-k300 - m7-k399
F.55
SP85681
HP ENVY Notebook 13-ab000 ~ 13-ab099
F.19
SP85534
HP ENVY Notebook 15-as000-as099
F.31
SP85381
HP ENVY Notebook 15-as100-as199
F.54
SP85512
HP ENVY Notebook 15-q3xx
F.23
SP86796
HP ENVY Notebook 15t-as00
F.31
SP85381
HP ENVY Notebook 15t-as100
F.54
SP85512
HP ENVY Notebook 17-s000 ~ s099
F.92
SP85514
HP ENVY Notebook 17-s100 ~ s199
F.92
SP85514
HP ENVY Notebook 17t-s000
F.92
SP85514
HP ENVY Notebook 17t-s100
F.92
SP85514
HP ENVY Notebook 17t-u000
F.31
SP85381
HP ENVY Notebook 17t-u100
F.54
SP85512
HP ENVY Notebook 17t-u200
F.14
SP85513
HP ENVY Notebook 17-u000-u099
F.31
SP85381
HP ENVY Notebook 17-u100-u199
F.54
SP85512
HP ENVY Notebook 17-u200-u299
F.14
SP85513
HP ENVY Notebook15-q400~15-q499
F.23
SP86796
HP ENVY Phoenix 800-0xx PC (ROM Family SSID 2ACE)
Not Available
Not Available
Not Available
HP ENVY Phoenix 810- (ROM Family SSID 2AF3)
Not Available
Not Available
Not Available
HP ENVY Phoenix 810-0xx PC (ROM Family SSID 2ACE)
Not Available
Not Available
Not Available
HP ENVY Phoenix 810-xxx (ROM Family SSID 2B36)
Not Available
Not Available
Not Available
HP ENVY Phoenix 850-0xx (ROM Family SSID 2B3A)
A0.08
SP87010
HP ENVY Phoenix 850-xxx (ROM Family SSID 2B36)
Not Available
Not Available
Not Available
HP ENVY Phoenix 860-xxx (ROM Family SSID 2B36)
Not Available
Not Available
Not Available
HP ENVY Phoenix 860-xxx (ROM Family SSID 2B4B)
A0.59
SP85454
HP ENVY Recline TouchSmart All-in-One 23-kxxx (ROM Family SSID 2B2B)
80.09
SP86867
HP ENVY Recline TouchSmart All-in-One 27-kxxx (ROM Family SSID 2B2B)
80.09
SP86867
HP ENVY TouchSmart 15t-j000; 15t-j100
F.71
SP86702
HP ENVY TouchSmart 17t-j000; 17t-j100
F.71
SP86702
HP ENVY TouchSmart m7t-j000; m7t-j100
F.71
SP86702
HP Envy TS 15-j000 ~ 15-j099; 15-j100 ~ 15-j199
F.71
SP86702
HP Envy TS 17-j000 ~ 17-j099; 17-j100 ~ 17-j199
F.71
SP86702
HP Envy TS m7-j000 ~ m7-j099; m7-j100 ~ m7-j199
F.71
SP86702
HP ENVY x2 15-c000 - 15-c099
F.16
SP85550
HP ENVY x2 15t-c0xx
F.16
SP85550
HP ENVY x2 15t-c0xx
F.16
SP85550
HP ENVY x2 Detachable PC 15-c000 ~ c099
F.16
SP85550
HP Envy x360 15-w000 ~ 15-w099
F.33
SP85578
HP ENVY x360 15-w1XX
F.33
SP85578
HP ENVY x360 Convertible 13-y000 ~ 13-y099
F.13
SP85591
HP ENVY x360 Convertible 15-aq0xx, 15t-aq000
F.55
SP85617
HP ENVY x360 Convertible 15-aq1xx, 15t-aq100
F.55
SP85617
HP ENVY x360 Convertible 15-aq2xx, 15t-aq200
F.55
SP85617
HP ENVY x360 Convertible 15-bp000 ~ 15-bp099
F.38
SP85615
HP ENVY x360 Convertible 15-bp1xx, 15t-bp100, 15m-bp1xx
F.38
SP85615
HP ENVY x360 Convertible 15m-bp000 ~ 15m-bp099
F.38
SP85615
HP ENVY x360 Convertible 15-w200 ~ 15-w299
F.33
SP85578
HP ENVY x360 m6-w1xx
F.33
SP85578
HP g14-a000~HP g14-a099
F.10
SP86743
HP Laptop 14-bp000 ~ 14-bp099
F.14
SP85680
HP Laptop 14-bp100 ~ 14-bp199
F.28
SP85653
HP Laptop 14-bs0xx, 14-bs5xx, 14-bs7xx, 14g-br0xx, 14q-bu0xx, 14t-bs000
F.32
SP85677
HP Laptop 14-bs1xx, 14-bs6xx, 14t-bs100, 14t-bs600, 14g-br1xx, 14q-bu1xx
F.32
SP85677
HP Laptop 14s-bc000 ~ 14s-bc099
F.14
SP85680
HP Laptop 14s-bc100 ~ 14s-bc199
F.28
SP85653
HP Laptop 14s-be000 ~ 14s-be099
F.14
SP85680
HP Laptop 14s-be100 ~ 14s-be199
F.28
SP85653
HP Laptop 14s-bp000 ~ 14s-bp099
F.14
SP85680
HP Laptop 14s-bp100 ~ 14s-bp199
F.28
SP85653
HP Laptop 15-bs0xx, 15-bs0xx , 15-bs5xx , 15-bs6xx, 15g-br0xx, 15q-bu0xx, 15-ra0xx
F.35
SP85676
HP Laptop 15-bs1xx, 15-bs7xx, 15t-bs100, 15t-bs700, 15g-br1xx, 15q-bu1xx
F.35
SP85676
HP Notebook 15t-ac100
F.25
SP86779
HP Notebook 11-f0XX
F.22
SP85070
HP Notebook 11-f1XX
F.22
SP85070
HP Notebook 13-s000 ~ 13-s099
F.25
SP85579
HP Notebook 14-y0xx
F.06
SP85013
HP Notebook 15-ac0xx & 15-ac5xx (WW/China LFR)
F.25
SP86779
HP Notebook 15-ay000 ~ 15-ay099 (WW/China & India LFR)
F.41
SP85638
HP Notebook 15-ay100 ~ 15-ay199, (WW/China & India LFR)
F.41
SP85638
HP Notebook 15-ay500 to 15-ay599 (WW/China & India LFR)
F.41
SP85638
HP Notebook 15-ay600 - 15-ay699 (WW/China & India LFR)
F.41
SP85638
HP Notebook 15-bd000 ~ 15-bd099 (China & India IT Mall)
F.41
SP85638
HP Notebook 15-bd100 ~ 15-bd199 (China & India IT Mall)
F.41
SP85638
HP Notebook 15-be000 ~ 15-be099 (China & India OLS)
F.41
SP85638
HP Notebook 15-be100 ~ 15-be199 (China & India OLS)
F.41
SP85638
HP Notebook 15-bn000 ~ 15-bn099 (Camo edition)
F.41
SP85638
HP Notebook 15-f0xx
F.38
SP84839
HP Notebook 15-f1xx
F.38
SP84839
HP Notebook 15-f2xx
F.38
SP84839
HP Notebook 15g-ad0XX(China IT Mall)
F.25
SP86779
HP Notebook 15t-ac000
F.25
SP86779
HP Notebook 15t-ay000
F.41
SP85638
HP Notebook 15t-ay100
F.41
SP85638
HP Notebook -aj0XX (China OLS)
F.25
SP86779
HP Notebook PC 11-aa0XX
F.14
SP85080
HP Notebook PC 11-ab0XX
F.14
SP85080
HP Notebook15-ac1xx & 15-ac6xx (WW/China LFR)
F.25
SP86779
HP Notebook15g-ad1XX(China IT Mall)
F.25
SP86779
HP Notebook15q-aj1XX(China OLS)
F.25
SP86779
HP OMEN Notebook 15-5100 ~ 5199
F.44
SP85669
HP OMEN Notebook 15-5200 ~ 5299
F.44
SP85669
HP OMEN Pro 15
F.44
SP85669
HP Pavilion 11-n000 x360 ~ Pavilion 11-n099 x360
F.2F
SP86809
HP Pavilion 11-n100 x360 ~ Pavilion 11-n199 x360
F.2F
SP86809
HP Pavilion 11t x360
F.2F
SP86809
F.2F
SP86809
HP Pavilion 13-a000 ~ 13-a099 x360
F.40
SP85580
HP Pavilion 13-a100 ~ 13-a199 x360
F.40
SP85580
HP Pavilion 13-a200 ~ 13-a299 x360
F.40
SP85580
HP Pavilion 13-a300 ~ 13-a399 x360
F.40
SP85580
HP Pavilion 13-b000 ~ 13-b099
F.40
SP85580
HP Pavilion 13-b100 ~ 13-b199
F.40
SP85580
HP Pavilion 13-b200 ~ 13-b299
F.40
SP85580
HP Pavilion 13-r000 ~ 13-r099 x2
F.21
SP85670
HP Pavilion 13-r0XX x2
F.21
SP85670
HP Pavilion 13-r100 ~ 13-r199 x2
F.21
SP85670
HP Pavilion 13-r1XX x2
F.21
SP85670
HP Pavilion 13t-a0XX x360
F.40
SP85580
HP Pavilion 13t-a1XX x360
F.40
SP85580
HP Pavilion 13t-a2XX x360
F.40
SP85580
HP Pavilion 13t-a3XX x360
F.40
SP85580
HP Pavilion 13t-b0XX
F.40
SP85580
HP Pavilion 13t-b1XX
F.40
SP85580
HP Pavilion 13t-b2XX
F.40
SP85580
HP Pavilion 14 G1 Notebook PC
F.46
SP85678
HP Pavilion 14-al000~14-al099
F.46
SP85678
HP Pavilion 14-al100~14-al199
F.46
SP85678
HP Pavilion 14t-al000
F.46
SP85678
HP Pavilion 14t-al100
F.46
SP85678
HP Pavilion 14t-v000
F.55
SP85681
HP Pavilion 14t-v100
F.55
SP85681
HP Pavilion 14t-v200
F.55
SP85681
HP Pavilion 14-v000~14-v099
F.55
SP85681
HP Pavilion 14-v100~14-v199
F.55
SP85681
HP Pavilion 14-v200~14-v299
F.55
SP85681
HP Pavilion 15-n100~199
F.72
SP86738
HP Pavilion 15-p000~15-p099
F.55
SP85681
HP Pavilion 15-p100~15-p199
F.55
SP85681
HP Pavilion 15-p300~15-p399
F.55
SP85681
HP Pavilion 15-p500~15-p599
F.55
SP85681
HP Pavilion 15-p700~15-p799
F.55
SP85681
HP Pavilion 15t-p000
F.55
SP85681
HP Pavilion 15t-p100
F.55
SP85681
HP Pavilion 15t-p300
F.55
SP85681
HP Pavilion 17-f000~17-f099
F.55
SP85681
HP Pavilion 17-f100~17-f199
F.55
SP85681
HP Pavilion 17-f200~17-f299
F.55
SP85681
HP Pavilion 500-xxx (ROM Family SSID 2AF7)
Not Available
Not Available
Not Available
HP Pavilion 500-xxx (ROM Family SSID 2B2C)
A0.17
SP84453
HP Pavilion 510-axxx (ROM Family SSID 821D)
F.33
SP85053
HP Pavilion 510-pxxx (ROM Family SSID 81B4)
F.34
SP84270
HP Pavilion 550-xxx (ROM Family SSID 2B2C)
A0.17
SP84453
HP Pavilion 560-pxxx (ROM Family SSID 828A)
F.42
SP85453
HP Pavilion 560-pxxx (ROM Family SSID 82F1)
F.24
SP86741
HP Pavilion 570-axxx (ROM Family SSID 82F9)
F.23
SP84405
HP Pavilion 570-pxxx (ROM Family SSID 82F2)
F.25
SP85590
HP Pavilion All-in-One 22-axxx (ROM Family SSID 2B43)
A0.11
SP85644
HP Pavilion All-in-One 22-axxx (ROM Family SSID 2B45)
A0.14
SP84403
HP Pavilion All-in-One 23-gxxx (ROM Family SSID 2B21)
80.2
SP85688
HP Pavilion All-in-One 23-pxxx (ROM Family SSID 2B21)
80.2
SP85688
HP Pavilion All-in-One 23-qxxx (ROM Family SSID 2B43)
A0.11
SP85644
HP Pavilion All-in-One 23-qxxx (ROM Family SSID 2B45)
A0.14
SP84403
HP Pavilion All-in-One 24-axxx (ROM Family SSID 81B7)
F.41
SP85642
F.66
SP85655
HP Pavilion All-in-One 24-axxx (ROM Family SSID 82DC)
F.26
SP85645
F.62
SP85656
HP Pavilion All-in-One 24-bxxx (ROM Family SSID 81B7)
F.41
SP85642
F.66
SP85655
HP Pavilion All-in-One 24-bxxx (ROM Family SSID 82DC)
F.26
SP85645
F.62
SP85656
HP Pavilion All-in-One 24-qaxxx (ROM Family SSID 838B)
F.12
SP85648
HP Pavilion All-in-One 24-qxxx (ROM Family SSID 81B7)
F.41
SP85642
F.66
SP85655
HP Pavilion All-in-One 24-qxxx (ROM Family SSID 82DC)
F.26
SP85645
F.62
SP85656
HP Pavilion All-in-One 24-rxxx
F.01
SP85268
HP Pavilion All-in-One 24-rxxx (ROM Family SSID 838B)
F.12
SP85648
HP Pavilion All-in-One 24-Xxxx (ROM Family SSID 838C)
F.12
SP85649
HP Pavilion All-in-One 27-axxx (ROM Family SSID 81B7)
F.41
SP85642
F.66
SP85655
HP Pavilion All-in-One 27-axxx (ROM Family SSID 82DC)
F.26
SP85645
F.62
SP85656
HP Pavilion All-in-One 27-nxxx (ROM Family SSID 2B43)
A0.11
SP85644
HP Pavilion All-in-One 27-nxxx (ROM Family SSID 2B45)
A0.14
SP84403
HP Pavilion All-in-One 27-rxxx (ROM Family SSID 838B)
F.12
SP85648
HP Pavilion HPE h8-1xxx PC (ROM Family SSID 2ACE)
Not Available
Not Available
Not Available
HP Pavilion HPE h9-1xxx Phoenix PC (ROM Family SSID 2ACE)
Not Available
Not Available
Not Available
HP Pavilion Laptop 14-bf0xx, 14t-bf000
F.35
SP86745
HP Pavilion Laptop 14-bf1xx, 14t-bf100
F.35
SP86745
HP Pavilion Laptop 14-bk000 ~ 14-bk099
F.14
SP85680
HP Pavilion Laptop 14-bk100 ~ 14-bk199
F.28
SP85653
HP Pavilion Laptop 15-cc000 ~ 15-cc099
F.14
SP85680
HP Pavilion Laptop 15-cc1xx, 15t-cc100
F.28
SP85653
HP Pavilion Laptop 15-cc500 ~ 15-cc599
F.14
SP85680
HP Pavilion Laptop 15-cc6xx, 15t-cc600
F.28
SP85653
HP Pavilion Laptop 15-cc700 ~ 15-cc799
F.14
SP85680
HP Pavilion Laptop 15-ck0xx, 15t-ck000
F.07
SP85568
HP Pavilion Mini 300-xxx (ROM Family SSID 2B38)
A0.14
SP87266
HP Pavilion Notebook 11-s000 ~ 11-s099
F.19
sp84822
HP Pavilion Notebook 11-s100 ~ 11-s199
F.19
sp84822
HP Pavilion Notebook 14-ab000~ab099
F.87
SP85556
HP Pavilion Notebook 14-ab100~ab199
F.87
SP85556
HP Pavilion Notebook 14t-ab000
F.87
SP85556
HP Pavilion Notebook 14t-ab100
F.87
SP85556
HP Pavilion Notebook 15-ab100~ab199
F.87
SP85556
HP Pavilion Notebook 15-ab200~ab299
F.87
SP85556
HP Pavilion Notebook 15-ab500~ab599
F.87
SP85556
HP Pavilion Notebook 15-ak000~ak099
F.87
SP85556
HP Pavilion Notebook 15-bc200 ~ 15-bc299
F.46
SP85678
HP Pavilion Notebook 15-bc3xx, 15t-bc300
F.60
SP85641
HP Pavilion Notebook 15-bj000~bj099
F.87
SP85556
HP Pavilion Notebook 15t-ab000
F.87
SP85556
HP Pavilion Notebook 15t-ab200
F.87
SP85556
F.87
SP85556
HP Pavilion Notebook 15t-ak000
F.87
SP85556
HP Pavilion Notebook 15t-bj000
F.87
SP85556
HP Pavilion Notebook 17-g000~g099
F.87
SP85556
HP Pavilion Notebook 17-g100~g199
F.87
SP85556
HP Pavilion Notebook 17t-g000
F.87
SP85556
HP Pavilion Notebook 17t-g100
F.87
SP85556
HP Pavilion Power 580-xxx (ROM Family SSID 828A)
F.42
SP85453
HP Pavilion Power 580-xxx (ROM Family SSID 82F1)
F.24
SP86741
HP Pavilion Power 580-xxx (ROM Family SSID 8437)
F.14
SP86701
HP Pavilion Power Laptop 15-cb000 ~ 15-cb099
F.14
SP85680
HP Pavilion Slimline 400-xxx (ROM Family SSID 2B2C)
A0.17
SP84453
HP Pavilion Wave 600-a0xx (ROM Family SSID 81C9)
F.34
SP85461
HP Pavilion Wave 600-axxx (ROM Family SSID 82FD)
F.25
SP86700
HP Pavilion x2 10-n0XX
F.15
sp85243
HP Pavilion x2 10-n1xx
F.18
sp85176
HP Pavilion x2 10-n2XX
F.15
sp85243
HP Pavilion x2 10t-n000
F.15
sp85243
HP Pavilion x2 10t-n100
F.18
sp85176
HP Pavilion x2 10t-n200
F.15
sp85243
HP Pavilion x2 Detachable 12-b000 ~ 12-b099 (Intel)
F.20
sp85464
HP Pavilion x2 Detachable 12-b100 ~ 12-b199 (Intel)
F.20
sp85464
HP Pavilion x2 Detachable 12t-b000
F.20
sp85464
HP Pavilion x2 Detachable 12t-b100
F.20
sp85464
HP Pavilion x2 Detachable PC 10-j0xx
F.12
sp85178
HP Pavilion x2 Detachable PC 10-k0xx
F.10
sp85198
HP Pavilion x360 13-s100 ~13-s199
F.25
SP85579
HP Pavilion x360 15-bk000 ~ 15-bk099
F.24
SP85577
HP Pavilion x360 15-bk100 ~ 15-bk199
F.24
SP85577
HP Pavilion x360 Convertible 11 11-k000~11-k099
F.56
sp85640
HP Pavilion x360 Convertible 11 11-k100~11-k199
F.56
sp85640
HP Pavilion x360 Convertible 11-ad000 ~ 11-ad099
F.37
SP85616
HP Pavilion x360 Convertible 11m-ad000 ~ 11m-ad099
F.37
SP85616
HP Pavilion x360 Convertible 14-ba0xx, 14t-ba0xx, 14m-ba0xx, 14t-cc0xx, 14-cc0xx
F.38
SP85557
HP Pavilion x360 Convertible 14-ba1xx, 14t-ba1xx, 14m-ba1xx, 14t-cc1xx, 14-cc1xx
F.38
SP85557
HP Pavilion x360 Convertible 15-br000 ~ 15-br099
F.37
SP85558
HP Pavilion x360 Convertible 15-br1xx, 15t-br100
F.37
SP85558
HP Pavilion x360 m1-u000~m1-u099
F.34
SP85636
F.34
SP85636
HP Pavilion x360 m1-u100~m1-u199
F.34
SP85636
HP Pavilion x360 m3-u000~m3-u099
F.34
SP85563
HP Pavilion x360 m3-u100~m3-u199
F.34
SP85563
HP Slimline 260-axxx (ROM Family SSID 821D)
F.33
SP85053
HP Slimline 260-pxxx (ROM Family SSID 81B4)
F.34
SP84270
HP Slimline 270-axxx (ROM Family SSID 82F9)
F.23
SP84405
HP Slimline 270-pxxx (ROM Family SSID 82F2)
F.25
SP85590
HP Slimline 410-xxx (ROM Family SSID 2B5B)
A0.10
SP85674
HP Slimline 411-axxx (ROM Family SSID 2B46)
A0.23
SP85074
HP Slimline 450-axxx (ROM Family SSID 2B46)
A0.23
SP85074
HP Slimline 450-xxx (ROM Family SSID 2B28)
80.14
SP85267
HP Slimline 450-xxx (ROM Family SSID 2B2C)
A0.17
SP84453
HP Slimline 455-xxx (ROM Family SSID 2B5B)
A0.10
SP85674
HP Spectre 15-ch0xx
F.12
SP86739
HP Spectre Laptop 13-af0xx
F.14
SP85565
HP Spectre Notebook 13-v000 ~ 13-v099
F.40
SP85576
HP Spectre Notebook 13-v100 ~ 13-v199
F.40
SP85576
HP Spectre Pro 13 G1
F.40
SP85576
HP Spectre Pro x360 G1
F.50
SP86795
HP Spectre Pro x360 G2
F.19
SP85494
HP Spectre x2 13-SMB Pro Notebook PC
F.27
SP85667
HP Spectre x2 Detachable 12-a000
F.29
SP84425
HP Spectre x2 Detachable 12-c000 ~ 12-c099
F.15
SP85671
HP Spectre x360 Convertible 13 13-w000 ~ 13-w099
F.45
sp85679
HP Spectre x360 Convertible 13-4000 ~ 13-4099 (Intel)
F.50
SP86795
HP Spectre x360 Convertible 13-4100 ~ 13-4199 (Intel)
F.50
SP86795
HP Spectre x360 Convertible 13-4200 ~ 13-4299 (Intel)
F.50
SP86795
HP Spectre x360 Convertible 13-ac000 ~ 13-ac099
F.45
sp85679
HP Spectre x360 Convertible 13-ae0xx, 13-ae5xx, 13t-ae000, 13t-ae500
F.15
SP85524
HP Spectre x360 Convertible 15-ap000 ~ 15-ap099
F.18
SP85614
HP Spectre x360 Convertible 15-bl000 ~ 15-bl099
F.35
sp85661
HP Spectre x360 Convertible 15-bl1xx, 15t-bl100
F.35
sp85661
HP Split 13-r000 ~ 13-r099 x2
F.21
SP85670
HP Split 13-r0XX x2
F.21
SP85670
HP Split 13-r100 ~ 13-r199 x2
F.21
SP85670
HP Split 13-r1XX x2
F.21
SP85670
HP Split x2 13-g200~299
F.27
SP85667
HP Split x2 13t-g200
F.27
SP85667
HP Stream 11 Pro G2 Notebook PC
F.19
sp84822
HP Stream 11 Pro G4 EE
F.05
SP84449
HP Stream 11 Pro Notebook PC
F.0D
SP85079
HP Stream 11-d000 ~ 11-d099
F.0D
SP85079
HP Stream 11-y0XX
F.22
sp84945
HP Stream 14 Pro G3
F.46
SP85208
HP Stream 14-ax0XX
F.46
SP85208
HP Stream 14-cb0XX
F.46
SP85208
HP Stream Mini 200-xxx (ROM Family SSID 2B38)
A0.14
SP87266
HP Stream Notebook 11-r000 ~ 11-r099
F.19
sp84822
HP Stream Notebook 11-r100 ~ 11-r199
F.19
sp84822
HP Stream Notebook PC 13-c000 ~ 13-c099
F.22
sp84838
HP Stream Notebook PC 13-c100 ~ 13-c199
F.22
sp84838
HP x360 11-p000-p099
F.09
SP85273
HP x360 11-p100-p199
F.18
SP84199
HP x360 310 G1 PC
F.2F
SP86809
HP x360 310 G2 PC
F.56
sp85649
HP x360 330 G1 PC
F.25
SP85579
HP xxx (ROM Family SSID 2B1B)
80.1
SP86794
HP Z
F.14
SP85663
F.14
SP85663
OMEN by HP 15-ax000~15-ax099
F.46
SP85678
OMEN by HP 15-ax100~15-ax199
F.46
SP85678
OMEN by HP 15t-ax000
F.46
SP85678
OMEN by HP 15t-ax100
F.46
SP85678
OMEN by HP 870-xxx (ROM Family SSID 2B4B)
A0.59
SP85454
OMEN by HP 870-xxx (ROM Family SSID 828A)
F.42
SP85453
OMEN by HP 870-xxx (ROM Family SSID 82F1)
F.24
SP86741
OMEN by HP 870-xxx (ROM Family SSID 830C)
F.24
SP86731
OMEN by HP 880-xxx (ROM Family SSID 8307)
F.11
SP85692
OMEN by HP 880-xxx (ROM Family SSID 8308)
F.11
SP85695
OMEN by HP 880-xxx (ROM Family SSID 8437)
F.14
SP86701
OMEN by HP Laptop 15-ax200 ~ 15-ax299
F.46
SP85678
OMEN by HP Laptop 15-ce000 ~ 15-ce099
F.15
SP85573
OMEN by HP Laptop 17-an000 ~ 17-an099
F.15
SP85573
OMEN by HP Laptop 17t-w000
F.46
SP85678
OMEN by HP Laptop 17t-w100
F.46
SP85678
OMEN by HP Laptop 17-w001~ 17-w099
F.46
SP85678
OMEN by HP Laptop 17-w101~ 17-w199
F.46
SP85678
OMEN by HP Laptop 17-w200 ~ 17-w299
F.46
SP85678
OMEN X by HP 900-0xx (ROM Family SSID 81B6)
F.22
SP84299
OMEN X by HP 900-xxx (ROM Family SSID 8268)
F.14
SP86744
OMEN X by HP 900-xxx (ROM Family SSID 82E0)
F.25
SP86742
OMEN X by HP 900-xxx (ROM Family SSID 839F)
F.13
SP86747
OMEN X by HP Laptop 17-ap000 ~ 17-ap099
F.14
sp85618
OMEN X by HP Laptop 17t-ap000
F.14
sp85618
OMEN X by HP P1000-000 P1000-xxx
F.15
SP85662
Presario CQ45-900 ~ CQ45-999
F.49
SP86811
Star WarsTM Special Edition 15-an000-an099
F.87
SP85556
Star WarsTM Special Edition 15t-an000
F.87
SP85556
TouchSmart 15-n100~199
F.72
SP86738
Immersive Systems
Platform Name
Fixed version
SP #
Link
Sprout by HP (Win8)
80.1
SP88764
Sprout by HP (Win10)
A0.06
SP88408
Sprout Pro by HP
A0.10
SP87751
Sprout Pro by HP G2
A0.13
SP87578
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy.
Support: For issues about implementing the recommendations of this Security Bulletin, visit http://www.hp.com/go/contacthp to learn about your HP support options.
Report: To report a potential security vulnerability with any HP supported product, send email to: hp-security-alert@hp.com.
Subscribe: To initiate a subscription to receive future HP Security Bulletin alerts via email, visit https://h41369.www4.hp.com/alerts-signup.php?lang=en&cc=US&jumpid=hpsc_profile.
Security Bulletin Archive: To view released Security Bulletins, search the HP Support Site for "security bulletin".
Software Product Category: The Software Product Category is represented in the title by the two characters following HPSB.
PI
HP Printing and Imaging
HF
HP Hardware and Firmware
GN
HP General Software
It is strongly recommended that security related information being communicated to HP be encrypted using PGP, especially exploit information.
To get the security-alert PGP key, please send an e-mail message as follows:
Subject: get key
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin.HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action.HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin.To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISIONSHISTORIK : Version 1: 4 January 2018 Initial release; Version 2: 8 January 2018 Updated release dates; Version 3: 9 January 2018 Updated product tables and release dates; Version 4: 12 January 2018 Updated Windows instructions per KF12925; Version 5: 17 January 2018 Modifications to product tables; Version 6: 22 January 2018 Updated status on MCU updates and Softpaq status; Version 7: 26 January 2018 Updated vulnerability summary; Version 8: 7 February 2018 Updated BIOS version for SKL platforms; Version 9: 12 February 2018: Added Consumer BIOS versions for SKL platforms; Version 10: 21 February 2018 Updated CMIT and DT WS platform lists; Version 11: Updated CMIT and DT WS platform lists; Version 12: Updated CMIT and DT WS Platform lists; Version 13: Updated CMIT, DT WS, and Combined Consumer platform lists; Version 14: 12 November 2018. Updated Commercial PC and Consumer PC platforms, added Immersive, added legend for platform lists. Version 15: 5 December 2018. Updated description of vulnerability and resolution, added additional Spectre/Meltdown variants.
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
