Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
    Lär dig hur du uppgraderar till Windows 11
    Handbok för uppgradering till Windows 11
  • Respons
Åtgärder
Läser in...
SUPPORT COMMUNICATION- SECURITY BULLETIN
Dokument-ID: c05839270
Version: 4
HPSBPI03569 rev 4 - HP LaserJet Enterprise printers, HP PageWide Enterprise printers, HP LaserJet Managed printers, HP OfficeJet Enterprise printers, Execution of arbitrary code
Notice:: The information in this security bulletin should be acted upon as soon as possible.
Utgivningsdatum : 17-Nov-2017
Last updated : 19-Dec-2017
Potential Security Impact:
Source: NTT Security
Reported By: Stephen Breen
SÅRBARHETS-SUMMERING
Insufficient Solution DLL Signature Validation allows potential execution of arbitrary code.
Referensnummer
CVE-2017-2750, PSR-2017-0141
PROGRAMVARUVERSIONER SOM STÖDS*: ENDAST berörda versioner är listade.
Please refer to the RESOLUTION below for the list of potentially impacted HP products.
BAKGRUND
For a PGP signed version of this security bulletin please write to: hp-security-alert@hp.com
CVSS 3.0 Base Metrics
Reference
Base Vector
Base Score
CVE-2017-2750
AV:N/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:H
8.1 High
Information on CVSS is documented in HP Customer Notice: HPSN­2008­002.
LÖSNING
Available Mitigation Settings:
The vulnerability can be avoided by either of the following actions:
  • Set the Local Administrator password for the Embedded Web Server (EWS).
    Open the printer EWS, click the Security tab, then locate the Local Administrator Password section.
  • Disable Allow firmware upgrades sent as print jobs (Port 9100) setting.
    Open the printer EWS, click the Security tab, then locate the Firmware Upgrade Security section.
  • See page 35 for EWS administrator password configuration.
  • See page 37 for Allow firmware upgrades sent as print jobs configuration.
HP has provided firmware updates for impacted printers as indicated in the table below. To obtain the updated firmware, go to www.hp.com and follow these steps:
  1. Select Support from the top of the page, then select Software & drivers.
  2. Enter the appropriate product name or model number from the table below into the search field.
  3. Click on Find.
  4. Scroll down and click Firmware from the category list.
  5. Select the Download button for appropriate firmware.
Firmware Update Table
obs!
Some FutureSmart printers have multiple firmware platforms - FutureSmart 3 (FS3) and FutureSmart 4 (FS4). Select the appropriate firmware version for the required FutureSmart platform.
Product Name
Model Numbers
Firmware Revision
HP Color LaserJet CM4540 MFP
CC419A, CC420A, CC421A
FS3: 2308937_578507 (or higher)
HP Color LaserJet CP5525
CE707A, CE708A, CE709A
FS3: 2308937_578508 (or higher)
HP Color LaserJet Enterprise Flow MFP M681f
J8A12A, J8A13A
FS4: 2405129_000037 (or higher)
HP Color LaserJet Enterprise Flow MFP M682
J8A17A
HP Color LaserJet Enterprise M552
B5L23A
FS3: 2308937_578487 (or higher)
HP Color LaserJet Enterprise M553
B5L24A, B5L25A, B5L26A
HP Color LaserJet Enterprise M651
CZ255A, CZ256A, CZ257A, CZ258A
FS3: 2308937_578497 (or higher)
FS4: 2405129_000047 (or higher)
HP Color LaserJet Enterprise M652
J7Z98A, J7Z99A
FS4: 2405130_000068 (or higher)
HP Color LaserJet Enterprise M653
J8A04A, J8A05A, J8A06A
HP Color LaserJet Enterprise M750
D3L08A, D3L09A, D3L10A
FS3: 2308937_578501 (or higher)
HP Color LaserJet Enterprise MFP M577
B5L46A, B5L47A, B5L48A, B5L49A, B5L50A, B5L54A
FS3: 2308937_578488 (or higher)
FS4: 2405129_000038 (or higher)
HP Color LaserJet Enterprise MFP M681
J8A10A, J8A11A
HP Color LaserJet Enterprise MFP M682
J8A17A
HP Color LaserJet Enterprise MFP M680
CZ250A, CZ251A, CZ248A, CZ249A
FS3: 2308937_578496 (or higher)
FS4: 2405129_000042 (or higher)
HP Color LaserJet Managed E65050
L3U55A
HP Color LaserJet Managed E65060
L3U56A
HP Color LaserJet Managed Flow MFP E67560
L3U70A
HP Color LaserJet Managed MFP E67550dh
L3U66A
HP Color LaserJet Managed MFP E67560dz
L3U70A
HP LaserJet Enterprise 500 color MFP M575
CD644A, CD645A
FS3: 2308937_578502 (or higher)
FS4: 2405129_000045 (or higher)
HP LaserJet Enterprise 500 MFP M525
CF116A, CF117A, L3U59A, L3U60A
FS3: 2308937_578493 (or higher)
FS4: 2405129_000048 (or higher)
HP LaserJet Enterprise 600 M601
CE989A, CE990A
FS3: 2308937_578503 (or higher)
HP LaserJet Enterprise 600 M602
CE991A, CE992A, CE993A
HP LaserJet Enterprise 600 M603
CE994A, CE995A, CE996A
HP LaserJet Enterprise 700 color MFP M775 series
CC522A, CC523A, CC524A
FS3: 2308937_578505 (or higher)
HP LaserJet Enterprise 700 M712
CF235A, CF236A, CF238A
FS3: 2308937_578504 (or higher)
HP LaserJet Enterprise 800 color M855
A2W77A, A2W78A, A2W79A, D7P73A
FS3: 2308937_578499 (or higher)
FS4: 2405129_000057 (or higher)
HP LaserJet Enterprise 800 color MFP M880
A2W76A, A2W75A, D7P71V, D7P71A, D7P68A, L3U51A, L3U52A, L3U65A
FS3: 2308937_578494 (or higher)
FS4: 2405129_000054 (or higher)
HP LaserJet Enterprise Color 500 M551 Series
CF081A, CF082A, CF083A
FS3: 2308937_578506 (or higher)
HP LaserJet Enterprise color flow MFP M575
CD646A
HP LaserJet Enterprise flow M830z MFP
CF367A
FS3: 2308937_578495 (or higher)
FS4: 2405129_000060 (or higher)
HP LaserJet Enterprise flow MFP M525
CF118A
HP LaserJet Enterprise Flow MFP M630
B3G85A
FS3: 2308937_578479 (or higher)
FS4: 2405129_000040 (or higher)
HP LaserJet Enterprise Flow MFP M631
J8J64A
FS4: 2405129_000041 (or higher)
HP LaserJet Enterprise Flow MFP M632z
J8J72A
HP LaserJet Enterprise Flow MFP M633z
J8J78A
HP LaserJet Enterprise M4555 MFP
CE503A, CE504A, CE738A
FS3: 2308937_578484 (or higher)
HP LaserJet Enterprise M506
F2A68A, F2A69A, F2A70A, F2A71A
FS3: 2308937_578489 (or higher)
HP LaserJet Enterprise M527
F2A76A, F2A77A, F2A81A
FS3: 2308937_578485 (or higher)
FS4: 2405129_000039 (or higher)
HP LaserJet Enterprise M604
E6B67A, E6B68A
FS3: 2308937_578490 (or higher)
HP LaserJet Enterprise M605
E6B69A, E6B70A. E6B71A
HP LaserJet Enterprise M606
E6B72A, E6B73A
HP LaserJet Enterprise M607
K0Q14A, K0Q15A
FS4: 2405130_000069 (or higher)
HP LaserJet Enterprise M608
K0Q17A, K0Q18A, K0Q19A
FS4:2405130_000069 (or higher)
HP LaserJet Enterprise M609d
K0Q20A, K0Q21A, K0Q22A
HP LaserJet Enterprise M806
CZ244A, CZ245A
FS3: 2308937_578500 (or higher)
FS4: 2405129_000059 (or higher)
HP LaserJet Enterprise MFP M630
J7X28A, B3G84A, B3G86A
HP LaserJet Enterprise MFP M631
J8J63A, J8J65A
HP LaserJet Enterprise MFP M632
J8J70A, J8J71A
HP LaserJet Enterprise MFP M633
J8J76A
HP LaserJet Enterprise MFP M725
CF066A, CF067A, CF068A, CF069A
FS3: 2308937_578498 (or higher)
FS4: 2405129_000058 (or higher)
HP LaserJet Managed E60055dn
M0P33A
HP LaserJet Managed E60065
M0P35A, M0P36A
HP LaserJet Managed E60075
M0P39A, M0P40A
HP LaserJet Managed Flow MFP E62565h, z
J8J74A, J8J79A
HP LaserJet Managed Flow MFP E62575z
J8J80A
HP LaserJet Managed MFP E62555dn
J8J66A
HP LaserJet Managed MFP E62565hs
J8J73A
HP OfficeJet Enterprise Color Flow MFP X585
B5L06A, B5L06V, B5L07A
FS3: 2308937_578483 (or higher)
FS4: 2405129_000050 (or higher)
HP OfficeJet Enterprise Color MFP X585
B5L04A, B5L04V, B5L05A, B5L05V, L3U40A, L3U41A
HP OfficeJet Enterprise Color X555
C2S11A, C2S11V, C2S12A, C2S12V, L1H45A
FS3: 2308937_578482 (or higher)
HP PageWide Enterprise Color 765d
J7Z04A
FS4: 2405087_018564 (or higher)
HP PageWide Enterprise Color MFP 586
G1W39A, G1W39V, G1W40A, G1W40V
FS3: 2308937_578492 (or higher)
FS4: 2405129_000066 (or higher)
HP PageWide Enterprise Color MPF 780
J7Z09A, J7Z10A
FS4: 2405087_018548 (or higher)
HP PageWide Enterprise Color MPF 785
J7Z11A, J7Z12A
HP PageWide Enterprise Color X556
G1W46A, G1W46V, G1W47A, G1W47V
FS3: 2308937_578491 (or higher)
FS4: 2405129_000051 (or higher)
HP PageWide Managed Color E55650
L3U44A
HP PageWide Managed Color E75160
J7Z06A
HP PageWide Managed Color Flow MFP 586
G1W41A, G1W41V
HP PageWide Managed Color Flow MFP E58650
L3U43A
HP PageWide Managed Color Flow MFP E77650
J7Z08A, J7Z14A
HP PageWide Managed Color Flow MFP E77660
Z5G77A, J7Z03A, J7Z07A, J7Z05A
HP PageWide Managed Color MFP E58650
L3U42A
HP PageWide Managed Color MFP E77650
J7Z13A, Z5G79A
HP Digital Sender Flow 8500 fn2 Document Capture Workstation
L2762A
FS4: 2405087_018553 (or higher)
HP Scanjet Enterprise 8500 Document Capture Workstation
L2717A
FS3: 2308937_578486 (or higher)
HP ScanJet Enterprise Flow N9120 Document Flatbed Scanner
L2683A
FS4: 2405087_018552 (or higher)
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy.
Support: For issues about implementing the recommendations of this Security Bulletin, visit http://www.hp.com/go/contacthp to learn about your HP support options.
Report: To report a potential security vulnerability with any HP supported product, send email to: hp-security-alert@hp.com.
Subscribe: To initiate a subscription to receive future HP Security Bulletin alerts via email, visit https://h41369.www4.hp.com/alerts-signup.php?lang=en&cc=US&jumpid=hpsc_profile.
Security Bulletin Archive: To view released Security Bulletins, search the HP Support Site for "security bulletin".
Software Product Category: The Software Product Category is represented in the title by the two characters following HPSB.
PI
HP Printing and Imaging
HF
HP Hardware and Firmware
GN
HP General Software
It is strongly recommended that security related information being communicated to HP be encrypted using PGP, especially exploit information.
To get the security-alert PGP key, please send an e-mail message as follows:
Subject: get key
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin.HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action.HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin.To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISIONSHISTORIK : Version 1: 17 November 2017 Initial release; Version 2: 29 November 2017 Added workarounds; Version 3: 11 December 2017 Updated firmware table, updated resolution mitigation settings; Version 4: 18 December 2017: Added a note before the table and updated entire table to include FutureSmart 3 devices and firmware versions.
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
