This document is for HP Deskjet Ink Advantage 2020hc and DeskJet Ultra Ink Advantage 2029 printers.
This document contains steps for replacing the cartridges.
varning!Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
obs!Insert the color cartridge in the slot on the left. Insert the black cartridge in the slot on the right.
