Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
    Lär dig hur du uppgraderar till Windows 11
    Handbok för uppgradering till Windows 11
  • Respons
Åtgärder
Läser in...
Setting Up the Printer Hardware for HP Deskjet 1000 (J110), 2000 (J210), 3000 (J310), and HP Deskjet Ink Advantage 2010 (K010a) Printer Series
  varning!
Do NOT connect the USB cable now. If you need a USB cable to connect the product to the computer, you will be prompted to connect it at the correct time during software installation.
obs!
The images in some of these steps might not look exactly like your product, but the steps are the same.
Step one: Unpack the printer
  1. Remove the tape and cardboard from the outside of the product.
    Figur : Remove the tape from the outside of the product
    Illustration: Removing the tape from the outside of the product
  2. Open the output tray, open the cartridge access door, and then remove the tape and cardboard from inside the product.
    Figur : Remove the tape and cardboard from inside the product
    Illustration: Removing the tape and cardboard from inside the product
  3. Close the cartridge access door.
    Figur : Close the cartridge access door
    Illustration: Closing the cartridge access door
Step three: Connect the power cord and adapter
Connect the power cable to the back of the product, connect the power cord to the power supply, and then plug the power cord into a power outlet in the wall.
    Figur : Connect the power cord
    Illustration: Connecting the power cord to the back of the product.
  1. Connect the power cable to the back of the product
  2. Connect the power cord to the power supply
  3. Plug the power cord into an electrical outlet
Step four: Turn on the power
Press the Power button () to turn on the product.
Figur : Turn on the product
Illustration: Turn on the product
Step five: Select the language and region (HP Deskjet 3000 (J310) printer series only)
This step applies only to the HP Deskjet 3000 (J310) printer series. If you do not have a product in this series, continue with the next step.
After turning the product on, a list of possible language settings displays on the product control panel. Use the following steps to set the default language and country/region for your product.
  1. On the product control panel, press the button () next to the Down Arrow () to scroll through the languages, if necessary.
  2. Press the button () next to OK to confirm your selection.
  3. Press the button () next to the Down Arrow () to scroll through the regions, if necessary.
  4. Press the button () next to OK to confirm your selection.
    Figur : Select your language and region from the product control panel
    Graphic: Select language and region
Step six: Load plain paper
Follow these steps to load plain paper into the product.
  1. If the product is not already on, press the Power button () to turn it on.
  2. Lift the paper tray.
    Figur : Lift the paper tray
    Illustration: Lifting the input tray
  3. Lower the output tray, and then pull the tray extender out.
    Figur : Lower the output tray
    Illustration: Lowering the output tray
  4. Slide the paper width guide to its outermost position.
    Figur : Slide the paper width guide
    Illustration: Sliding the paper width guide to its outermost position
  5. Load unused, plain white, U.S. letter or A4 size paper in the tray with the short edge forward and the print side up.
    Figur : Load paper in the tray
    Illustration: Loading paper in the tray
  6. Slide the paper width guide to the right until it stops at the edge of the paper but does not bend the paper.
    Figur : Slide the paper width guide to the right
    Illustration: Sliding the paper width guide to the right
Step seven: Install the cartridges
  1. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before you continue.
    Figur : Open the cartridge access door
    Illustration: Opening the cartridge access door
  2. Remove the new cartridge from its package, and then carefully pull the pink pull tab to remove the plastic tape.
      varning!
    Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections.
    Figur : Remove the plastic tape
    Graphic: Remove tape from the cartridge
  3. Hold the cartridge by its sides with the nozzles toward the product, and then insert the cartridge into its slot. Make sure that the icon on the cartridge matches the icon on the slot.
    • The tri-color cartridge () goes in the slot on the left
    • The black cartridge () goes in the slot on the right
    Figur : Insert the cartridge into its slot
    Illustration: Inserting the cartridge
  4. Push the cartridge forward into its slot until it snaps into place.
    Figur : Snap the cartridge into place
    Graphic: Snap the cartridge into place
  5. Repeat these steps to insert the other cartridge.
  6. Close the cartridge access door.
Step eight: Align the cartridges
  1. Open the printer software.
  2. Double-click Printer Actions, and then double-click Maintenance Tasks. The HP Toolbox opens.
  3. Click the Device Services tab, and then click Align Ink Cartridges. The printer aligns the cartridges and then prints an alignment page.
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
