Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
    Windows 11
    Hitta vanliga frågor och svar här.
  • Respons
Åtgärder
Läser in...
HP Officejet 5600 Printers - Loading Paper
This document is for HP Officejet 5605, 5608, 5610, 5610v, and 5610xi All-in-One Printers.
Load paper into the main paper input tray.
  1. Remove the output tray and slide the paper-width guide to its outermost position.
    Figur : Removing the output tray
  2. Tap the stack of paper on a flat surface to align the edges, and then make sure the paper meets the following criteria:
    • Free of rips, dust, wrinkles, and curled or bent edges
    • Of the same size and type
  3. Insert the stack of paper into the input tray with the short edge forward and the print-side down. Slide the stack of paper forward until it stops.
    Figur : Loading paper in the input tray
      varning!
    Make sure that the product is idle and silent when you load paper into the input tray. If the product is servicing the print cartridges or otherwise engaged in a task, the paper stop inside the device might not be in place. You could push the paper too far forward, causing the product to eject blank pages.
  4. Slide the paper-width guide inward until it stops at the edge of the paper.
    obs!
    Do not overload the input tray. Make sure the stack of paper fits within the input tray and is no higher than the top of the paper-width guide.
    Figur : Adjusting the paper-width guide
  5. Replace the output tray.
  6. Flip the output tray extender up and toward you to open it.
    Figur : Opening the output tray extender
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
