Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
HP Officejet J3600 All-in-One Series - Installing Print Cartridges
Follow the instructions below to install the print cartridges for the first time.
Installing print cartridges
Step one: Install the print cartridges
Follow these steps to install the cartridges.
  1. Open the cartridge door.
    The carriage moves to the far right side of the product.
    Figur : Open the cartridge door
    On the right side of the product, raise the cartridge door
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
      Figur : Remove tape from cartridge
      Remove protective tape from the cartridges
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
      varning!
    Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
    Figur : Do not touch the ink nozzles or copper contacts.
    Do not touch the nozzles or electrical contacts with your fingers
  3. Slide each new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figur : Insert the cartridge
    Insert the cartridges into the appropriate slots in the carriage
  4. Close the cartridge door.
Step two: : Align the print cartridge
The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or by using the software you install with the product. Aligning the cartridges ensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
obs!
If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
