Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
    Windows 11
    Hitta vanliga frågor och svar här.
  • Respons
Åtgärder
Läser in...
HP Photosmart 325, 335, 375, and 385 - Installing Print Cartridges
  1. Open the print cartridge access door, then wait until the print cartridge carriage is idle and silent.
    Figur : Opening the print cartridge access door
  2. Press down on the end of the cartridge to release it.
    Figur : Releasing cartridge
  3. If you are installing a new print cartridge, remove the protective tape.
    Figur : Removing the protective tape
  4. Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
    obs!
    Avoid touching the nozzles or contacts!
    1. Contacts
    2. Nozzles
    Figur : Installing the cartridge
  5. Press the cartridge into the carriage until it snaps into place.
  6. Close the print cartridge access door.
Åtgärder
Läser in...
Åtgärder
Läser in...
Åtgärder
Läser in...
Land/region: Flag Sverige
Åtgärder
Läser in...
