Make sure the printer is turned on. Press the Power button if it is not lit.Figur : Press the Power button if it is not lit
- Open the printer cover, then wait until the print cartridge cradle is idle and silent.
- ${title}
Läser in...
- ${title}
Läser in...
- ${title}
Läser in...
- ${title}
Läser in...
HP Deskjet 6540 Series Printers - Removing and Installing Print Cartridges
Step 1 - Open the printer
Figur : Opening the printer
Cartridge replacement animation
Click the play button above (
) to see an animation on how to replace print cartridges, or continue to the sections below for detailed instructions.
Step 2 - Remove old cartridges
Press down lightly on top of the cartridge latch.
Pull out the bottom of the latch to unhook it.
Slide the cartridge out.Figur : Open the cartridge latchFigur : Slide the cartridge out
Step three: Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
Figur : Insert a cartridge into a cartridge protector
Figur : To remove, press down on the latch
Step 4 - Make sure the new cartridges are compatible
Step 5 - Install the new cartridges
If you are installing a new print cartridge, remove the protective tape.
varning!
Do not attempt to remove the copper strip.Figur : Remove the protective tapevarning!
After the tape is removed, do not touch the copper contacts or the ink nozzles.-
Contacts
Nozzles
Figur : Contacts and nozzles -
Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
Cartridges marked with a triangle go into the left carriage slot.
Cartridges marked with a square or pentagon go into the right carriage slot.
Figur : Put each cartridge into the proper slot -
Push down on the print cartridge latch until it snaps closed.Figur : Slide the print cartridge inFigur : Close the latch
Close the printer cover.
Ytterligare supportalternativ
- ${title}
Läser in...
- ${title}
Läser in...
- ${title}
Läser in...
Land/region:
Sverige
- ${title}
Läser in...
hp-hero-support-search
- ${title}
Läser in...
