HP LaserJet Enterprise M607, M608, M609 - Removal and replacement: Control panel (4.3 inch display)
This document provides the procedures to remove and replace the control panel (4.3 inch display).
Mean time to repair: 5 minutes
Service level: Basic
When applicable, special installation instructions are provided for an assembly at the end of the removal procedure. Always completely read the removal instructions and follow all special installation instructions.
Before performing service
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts
Control panel (4.3 inch display) part number
5851-7252
Control panel kit (109.22 mm4.3 in display)
Required tools
  • #2 Phillips screwdriver with a magnetic tip
  • Small flat blade screwdriver
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
No post service test is available for this assembly.
  1. Remove the control panel (4.3 inch display).
    1. Raise the control panel screen in the direction indicated by the arrow.
      Figure : Raise the control panel screen
    2. Do the following:
      • Use a coin, or a small flat-blade screwdriver, to release the control panel cover in the direction indicated by the arrow.
      • Remove the control panel cover.
        Figure : Lift and remove the control panel cover
    3. Remove one thumbscrew (callout 1).
      Store the screw in a secure place where it cannot fall down into the printer.
      Figure : Remove one thumbscrew
    4. Do the following:
      • Lift the back edge of the control panel up (callout 1).
      • Slide the control panel toward the back of the printer (callout 2) to release it.
        Figure : Lift and release the control panel
    5. Do the following:
      • Turn the control panel over to gain access to the bottom side.
      • Disconnect two connectors (callout 1).
        Figure : Disconnect two connectors from the bottom side
    6. Remove the control panel.
      Figure : Remove the control panel
  2. Unpack the replacement assembly.
    1. Dispose of the defective part.
    2. Unpack the replacement part from the packaging.
      Some parts are sensitive to electrostatic discharge (ESD). Always perform service work at an ESD-protected workstation or mat. If an ESD workstation or mat is not available, touch the sheet-metal chassis to provide a static ground before touching an ESD-sensitive assembly. Protect the ESD-sensitive assemblies by placing them in ESD pouches when they are out of the printer.
      If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands before touching rollers or pads.
      Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
    3. To install an assembly, reverse the removal steps.
  3. Install the control panel (4.3 inch display).
    1. On the replacement control panel, connect two connectors (callout 1).
      Figure : Connect two connectors
    2. Install the tabs, on the front of the control panel, into the slots on the printer top cover.
      Figure : Install the control panel tabs into the printer slots
    3. Do the following:
      • Lower the back edge of the control panel down (callout 1).
      • Install one screw(callout 2).
        Figure : Lower the control panel and install one screw
      • Align the tabs on the front of the control panel cover with the slots in the printer.
      • Pivot the cover down, in the direction indicated by the arrow, to install it.
        Figure : Align the control panel cover and pivot down to install it
Country: Flag Serbia
