6K770PA
HP Pavilion Laptop 14-dv2034TU
Intel® Core™ i5-1235U (up to 4.4 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 10 cores, 12 threads)
Intel® Integrated SoC
8 GB DDR4-3200 MHz RAM (2 x 4 GB)
Video graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), IPS, micro-edge, BrightView, 250 nits, 45% NTSC
MediaTek Wi-Fi 6 MT7921 (2x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.1; 1 AC smart pin; 1 headphone/microphone combo
32.5 x 21.66 x 1.7 cm
1.41 kg
65 W Smart AC power adapter
3-cell, 43 Wh Li-ion polymer
Battery life mixed usage
Up to 7 hours and 45 minutes
HP Wide Vision 720p HD camera with temporal noise reduction and integrated dual array digital microphones
Audio
Audio by B&O; Dual speakers; HP Audio Boost
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion Laptop 14-dv2034TU Product Specifications
Windows 11 Home
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
