HP ENVY Laptop 17-ch1099nf Product Specifications
6J9T5EA
Intel® Core™ i7-1195G7 (up to 5.0 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores, 8 threads)
Intel® Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
Intel® Iris® Xᵉ Graphics
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
43.9 cm (17.3") diagonal, FHD (1920 x 1080), IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass NBT™, 300 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 Thunderbolt™ 4 with USB4™ Type-C® 40Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 10Gbps signaling rate; 1 HDMI 2.0b; 1 AC smart pin; 1 headphone/microphone combo
39.9 x 25.9 x 1.99 cm
2.54 kg
65 W AC power adapter
4-cell, 55 Wh Li-ion polymer
Battery life mixed usage
Up to 9 hours and 45 minutes
Video Playback Battery life
Up to 12 hours and 15 minutes
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost
Windows 11 Home
HP Audio Switch; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP QuickDrop; OMEN Gaming Hub; HP Display Control; HP Palette; HP Enhanced Lighting
McAfee LiveSafe™; 1-month Adobe free trial offer
Pre-installed software
Duet® for HP (30 day free trial); ExpressVPN (30 day free trial); LastPass Premium (30 day free trial)
