HP All-in-One 24-df1678in PC Product Specifications
Product Number
688C1PA
Product Name
23.8" diagonal FHD display
Display Specifications
23.8" diagonal, FHD (1920 x 1080), IPS, three-sided micro-edge, anti-glare, 250 nits, 72% NTSC
Motherboard
Row
Motherboard Specifications Link
Memory
8 GB DDR4-3200 MHz RAM (1 x 8 GB)
Memory & Storage
8 GB memory; 512 GB SSD storage
Internal Storage
512 GB PCIe® NVMe™ M.2 SSD
Processor Type
Intel Core i5
Processor
Intel® Core™ i5-1135G7 (up to 4.2 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Processor Family
11th Generation Intel® Core™ i5 processor
Graphics
Integrated
Graphics Card
Intel® Iris® Xᵉ Graphics
Ports
2 SuperSpeed USB Type-A 5Gbps signaling rate; 2 USB 2.0 Type-A; 1 HDMI-out 1.4; 1 headphone/microphone combo; 1 RJ-45
Expansion Slots
2 M.2 (1 for SSD, 1 for WLAN)
Network Interface
Wireless
Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
Optical Drive
DVD-Writer
Memory Card Device
HP 3-in-1 memory card reader
Dimensions
54.08 x 20.45 x 40.93 cm
5.85 kg
Power Supply Type
65 W Smart AC power adapter
Keyboard
HP 710 Black Wireless Keyboard and mouse combo
HP Wide Vision 1080p FHD IR privacy camera with integrated dual array digital microphones
HP Apps
HP Audio Switch; HP Connection Optimizer; HP Support Assistant
Software Included
Operating System
Windows 11 Home
