HP Pavilion Gaming Laptop 15-ec2115nm Product Specifications
6G1K3EA
AMD Ryzen™ 7 5800H (up to 4.4 GHz max boost clock, 16 MB L3 cache, 8 cores, 16 threads)
AMD Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce RTX™ 3050 Laptop GPU (4 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 300 nits, 72% NTSC
Realtek Wi-Fi 6 (2x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 USB 2.0 Type-A (HP Sleep and Charge); 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.7 x 2.35 cm
1.98 kg
200 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Battery life mixed usage
Up to 8 hours
Video Playback Battery life
Up to 11 hours
Audio
Audio by B&O; Dual speakers; HP Audio Boost
FreeDOS
