HP Chromebook x360 14c-cc0003nb Product Specifications
698F8EA
Intel® Core™ i3-1125G4 (up to 3.7 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores, 8 threads)
Intel® Integrated SoC
8 GB DDR4-3200 MHz RAM (onboard)
Video graphics
Intel® UHD Graphics
128 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, Corning® Gorilla® Glass 5™, 250 nits, 45% NTSC
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
2 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 headphone/microphone combo
32.15 x 20.6 x 1.79 cm
1.52 kg
65 W USB Type-C® power adapter
3-cell, 58 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours and 45 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by Bang & Olufsen; Dual speakers
Chrome OS™
